Epson stylus CX3200: Red error light is on and I can't reset. Just changed the color cartridge and forgot to remove the tape on cartridge. Was able to remove tape but still unable to reset and return printer to service.
    Brigadier General:
  • 6,966 Answers
May I offer an alternative possible solution...Pls try:
  • Download, Install and run the SSC Service Utility;
  • Function of the utility is explained here;
  • Reset the Protect Counter;
  • Perform an actual reset on the printer (triangle & color buttons).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 13, 2008
  • 659 Answers
Unplug your unit form the wall and let it sit for about 5 minutes and hopefully it will reconfigure itself on startup.
Posted on Oct 12, 2008
  • Wesley Gardner
    Wesley Gardner Oct 13, 2008
    also is the red light solid or flashing?
    Novelist:
  • 159 Answers
Unplug the power for a minute to see if it resets.
If it gives you the same error light, Remove the cartridge Unplug the printer, and clean both the rear of the cartridge nontact and the contacts in the printer with a lint free cloth and a LITTLE warm water. Then Dry it and try again.
Good luck
Fran
Bought new cartridged, replaced the old one but the content is not getting printed
Check the control panel for error indicators. The error light is to the left of the display and is marked "Error," it will illuminate. The error will appear on the screen and is in plain English, so very simple to interpret. An example is "Color or Black Ink Out," meaning there's no ink.
  • 2 Verify that the Epson Stylus CX3200 is connected to the printer with a cable. Try connecting without a USB hub while troubleshooting---that way you can identify if the problem is with the hub or printer. Replace the cable, it may be bad.
  • 3 Print a nozzle check pattern to determine the extent of the problem. The nozzle check will allow you to determine whether the printer will print at all, and the results will give you a good indication of print problems. Press the Menu button on the Control Panel until you see Nozzle Check and press the Color Copy button.
  • 4 Replace the printer cartridges if the Control Panel suggests you do so. Press the Menu button until you see "Change Cartridge" Press the Color Copy button and the cartridges will move to their change position. Lift the scanner and unclamp the cartridge. Replace the cartridge---color is on the right and black on the left. The Epson Stylus CX3200 will start charging the cartridge and after about thirty seconds the printer will be ready for use.
  • Feb 07, 2011 | Epson Stylus CX3200 All-In-One InkJet...
    Epson cx3200 printer has printing problem
    Hello cockie ,
    You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
    If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
    It may also be helpful to try running a printer nozzle check.
    See the following message problems and solutions:
    Error Message Probable Cause No color or black ink cartridge - - >
    Press the Color Copy button to install a new ink cartridge.
    The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
    Press the Color Copy button to begin replacing the ink cartridge.
    The indicated cartridge is out of ink Ink cartridge error - - >
    There is something wrong with the ink cartridge. Paper jam or misfeed - - >
    Press the Color Copy button and clear the paper jam by hand if necessary.
    Paper is jammed. Press the Color Copy button to clear the jam.
    See the User's Guide for more troubleshooting tips.
    Paper out - - >
    Load paper in the sheet feeder and press the Color Copy button.
    Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
    Close the scanner unit.
    Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
    See your documentation and call Service if necessary.
    Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
    Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
    Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
    Green and red lights on solidly, error message saying 'cartridge not recognized' even when it is a brand new Epson cartridge! Tried a reset but it doesn't make any difference
    When you installed the cartridge, did you check for any protective tape on the cartridge at the bottom. This is a common missed item in the installation process. If there is tape on it, check instructions and remove it. The cartridge will not work otherwise.
    Feb 02, 2010 | Epson Stylus Photo 1290 InkJet Printer
    Epson Stylus C3200 Red Error Light Stays On
    Ink level at chip reach zero. Reset ink level counter using hardware resetter. Or Use CISS chip with autoreset.
    Jun 15, 2009 | Epson Stylus CX3200 All-In-One InkJet...
    Error inkcartridge
    Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
    Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
    Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
    Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
    Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
    Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
    Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
    Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
    Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
    Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
    Error Message: Scanner unit open -- > close the scanner unit
    Solution: Carefully close the scanner and press it down until it clicks securely into place.
    Error Message: Scanner error -- > See your documentation and call service if necessary.
    Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
    Error Message: Printer error -- > See your documentation and call service if necessary.
    Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
    Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
    My scanner
    Open the scanner lid and slide the transportation lock back to the hw_translock_1.gif unlock position.
    I will appreciate a Fixya rating if I were able to resolve your concern.
    Oct 22, 2008 | Epson Stylus CX3200 All-In-One InkJet...
    Help Epson CX3200
    I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
    Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
    May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
    Color, black ink cartridge error
    contact epson support
    they may replace your cartridge
    Oct 24, 2007 | Epson Stylus CX3200 All-In-One InkJet...
    Printer fails
    Need more info. than this. What exactly is the issue - is the printer feeding paper? Is the ink not printing etc.
    Aug 26, 2007 | Epson Stylus CX3200 All-In-One InkJet...
    312 people viewed this question
    k24674
    jasbo
    jasbo
