Ac doesnt cooling a room.how much cost to repair?
  • Ernest London
    Ernest London Oct 17, 2017
    It is a bummer that your AC isn't working right. I can't imagine how frustrating it is to not be able to keep your home cool! I don't know much, but it sounds like you might benefit from calling a professional. It makes sense that they would be able to easily diagnose the problem. Good luck! http://a-1heatac.com
    Master:
    Sergeant:
  • 394 Answers
There could be lots wrong or it can be as simple as getting a recharge. But more info is needed to assist you. Like what ac make and model are you talking about?
AC Repair Pro FL
Posted on Apr 12, 2015
    New Friend:
  • 27 Answers
I agree with Neil. More information is needed to properly advise.
Posted on Apr 04, 2015
  • 3,368 Answers
Remove the front and filter(s). Clean them better yet replace them. In the back (outside) there is a coil be sure it is clean. If this does not help contact your local refrigeration ac service.
Posted on Apr 02, 2015
  • 750 Answers
Hello ufor23
Welcome
You said, your Ac doesn't cooling a room.how much cost to repair?
I need more info to advise you correctly!
What is the:
Model number and Year or age of your AC unit
Waiting for your response,
Huuum
Posted on Oct 12, 2008
  • shincirlik Aug 31, 2010
    mine isn't cooling well either anymore. it's a goldstar wg5005y7 window unit. age is unknown, it came with the apartment, at least 3 years old. does it need recharging?
Not cooling room and every 45 seconds it makes a hum noise
window unit ac !! not a fridge . the hum you hear is the ac compressor trying to come on , but due to loss of gas charge it shuts right off again , this will require a professional ac repairman to fix this , 1st he needs to find leak then repair leak then add back lost gas charge , watch cost of all these services vs cost of entire new unit , it could get expensive
Jun 24, 2015 | Refrigerators
Tip
How to cool big home with small air conditioner(s)
A lot of people have only one or two rooms that can take an air conditioner in the window. Often times, the air conditioner is also rated at a cooling power that would make you believe that there is no way that it can to cool the whole house/apartment. You can crank it to the max to try to cool as much as possible, but then this makes one room too cold and the others still stay too hot. You can try blasting the cool air down a hallway with a fan on maximum speed, but that only works so well. And, it's noisy, too. Well, I have two 260 sqr ft rated room air conditioners and I am cooling 2000 sqr feet of house to a comfortable 72 degrees in all rooms and it's been 95 outside all day. How to do it?
The trick is setting up your home to take advantage of laminar air flow. Set your air conditioner to say 68 degrees and start it in the middle of the morning before it feels hot outside. Put the AC deflectors pointing downward and towards the door. Put fans in the doorways pointing out of the rooms that have the AC. Point them level to the floor (not up) and put a fan to one side near the end of long hallways. Set the fans on the lowest power setting (not high). If the hallway branches out into a bigger room, put a fan in the room that is blowing across at a right angle to the entry, pointing the air flow parallel to the wall. This will circulate the cool air around the room. Keep the fans on low and pointed parallel to the floor, not up!
What you have created is a re-circulating air flow system, much like the North Atlantic Current that moderates the temperatures of Europe. You can check this by taking a tissue paper and holding it up to the top of the doorway. The air flow should be pushing the tissue away from the room without the AC and toward the room with the AC. This happens because the warmest air will be toward the ceiling and you want that warm air to make its way across the ceilings and back to the room with the AC, so that it can be cooled again. The cooled air from the AC will sink to the floor and the fans will gently push the air out of the room with the AC. It will stay low and travel along the floor in the opposite direction and into the warmer rooms. If you crank your fans up, you will create turbulent flow and that will not cool your house as efficiently as will laminar flow. Monitor the outside temperature and when it gets cooler outside by a few degrees, turn the AC to fan for about 10 minutes to eek out the last of the cooling. Then open the windows for the night to take advantage of the free cooling that nature provides. That's it! Enjoy the summer!
on May 25, 2015 | Heating & Cooling
What is wrong with and Air Conditioner that continues to freeze up?
the ac cant keep up,you need a bigger ac or a smaller room,if the ac needs to keep cooling,it doesnt have a chance to cycle
Jun 23, 2015 | Norpole 5000BTU Mechanical Window Air...
Lg 14000 portable Hvac
Is your room sealed well?. With out that information i cant help you with your ac repair problem. If you need more information on Air Conditioning Repair please check us out.
Jun 12, 2014 | LG Heating & Cooling
Not cooling 110 sq ft room
The smallest retail AC unit will cool down a 110 sqft room if...
1. It is installed in a way as to dump heat outside... 2. There is actually cool air coming out of the AC (it is working)... 3. The windows and doors are tightly closed... 4. There are no major drafty leak issues (i.e. hole in a wall)... 5. You're not adding substantial heat energy into the room (such as having 10 sweaty fat men eating food while watching Super Bowl on a 56" LCD TV)... 6. The room has at least minimum insulation (the walls are not just plywood)... Seriously, if HEAT is leaving the room by way of the AC, the room temperature HAS to decrease, unless HEAT is being added back into the room in some way. This is basically the 1st law of thermodynamics.
Jul 24, 2011 | Heating & Cooling
AC was cooling fine. Now, won't cool room even though cool air comes out. Exhaust hose is extremely hot.
Check filter, if you have a 5000BTU unit (small) and it is extremely hot, then it wont work great for a big room. BTU is the rate of what the AC will put out. 5000 BTU is good for a small single room. 10,000 will cool a bigger room and 18,000 btu is meant to cool a home.
Jul 07, 2010 | Whirlpool ACP102PS Portable Air...
Split system getting cold at first then just not cooling the room
Split Air Conditioners are not meant to run constantly. so check this first . you may have a faulty component i.e. compressor, condenser, evaporator, or evap fan. Depending on your technician you may have gotten ripped off. You need to find out if he checked the system for refrigerant (gas) leaks. A good way to tell if your ac is leaking is feel the low and high side copper pipe in between the inside and outside units.
the smaller pipe (high side) should be hot be carefull maybe touch it with an ice cube. The Large pipe should be cold but not iced over.
if there is ice on any component you should call a qualified tech. you probably have a leak. you should also clean your air filters which are right above the vents. I am a certified AC mechanic and i have seen this problem. in Iraq because of ambient temperatures being high the systems take alot of abuse and we dont fix them because repair costs exceed replacement costs alot of the time. good luck.
Nov 19, 2009 | Mitsubishi MSZ09UN Air Conditioner
I have a 1999 Honda Accord. The AC Fan stopped working except on High speed and the AC is no longer cooling, only room temperature air.
This will be 2 separate problems.
The blower motor operating only on high speed can be fixed by replacing the blower motor resistor.
There are several reasons why your A/C is not getting cold. The most probable cause is that there is a leak in the system and the freon has leaked out. The size of the leak and where it is leaking from can vary immensely, as will the cost of repair. You might get away with just a recharge for a while, but that will not FIX the problem...it will definately do it again if the problem is not repaired properly. A small leak, costing $150 to repair right now, could easily end up costing $1500 or more if not fixed properly.
Nov 08, 2009 | 2004 Honda Accord
My frigidaire window AC is not cooling anymore
Does it get cold? You can try cleaning the fins-both inside and outside, with windex. Smoling & cooking will create a sticky deposit that will make dist that gets through the filter stick and it won't cool properly.
If it doesn.t get cold any more, try replacing the starting capacitor. About $5. If that doesn't take care of it, just replace the unit. They are cheap enough these days, that you can replace a unit with a more energy efficient unit for the same cost or less as a repair would cost.
May 25, 2009 | Frigidaire FAC084N7A Air Conditioner
Goldstar Room Air Conditioner problem...
It sounds to me like you have a weak run capacitor on the compressor. This will cause the compressor to be able to run for a short period, but it will be overworking itself to compensate for the weak capacitor. It overheats, shuts off to protect itself, cools down and restarts again. If you have it set to 10 I don't think you would be comfortable in the room if the thermostat was satisfying and turning the unit off. An a/c tech can replace the weak capacitor, but the cost of repair will probably rival that of a new unit.
Jun 10, 2008 | Heating & Cooling
Heating & Cooling Logo
273 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
