Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE PROFILE PSW26SGRB SS
Last week the freezer temperature increase to more than 45 degrees , I found out that the cooling coils in the freezer back walls were frozen. I take out all the food and defrost with a blower the coils. The cooling coils are getting frozen again and the temperature is increasing again, the load in the freezer is small and no food is against sides or back of the freezer. The fan in the freezer side is working.
The temperature in the refrigerator side is normal and fluctuates between 37 and 45 even with heavy door opening.
  • 2 more comments
  • cesarnieve Oct 13, 2008
    The problem is that the freezer is getting warmer abouth 45 degrees nevertheless the refrigerator is working unde 37 degrees. Also the cooling coils in the freezer are getting frozen, buth the refrigerator part is ok
    The evaporator is clean, no lint or dust, was cleaned with a vacuum cleaner and a air compressor. By the way, neither the ice maker is making ice. And the freezer side is freezing the cooling coils again. The cooling coils were defrost with a blower last week. It is a side by side refrigerator.
    i WILL FIX THE THERMOSTAT AND LET YOU KNOW IF IT WORKS OR NOT.
    tHANKS
    Top Expert:
  • GE Master
  • 77,499 Answers
Do you mean the temp is decreasing, if so then try the defrost timer as the faulty part.
Posted on Oct 13, 2008
    Genius:
  • 1,124 Answers
This is a problem of thermostast which is not working properly. Replace or fix it and this will be fx your issue.
    Sergeant:
  • 352 Answers
What you have sounds like "jelly roll" issue. This is whent the evaporator becomes so caked with lint and dust and dirt that it cuts of air flow that is neccessary for the evap. coils to stay un frozen and working porperly. Pull out your frig, you may have front of back access the the evap. condenser coils, and clean the dust bunnies away. Cheap, simple fix.
anaanymous
Posted on Oct 12, 2008
  • anaanymous Oct 12, 2008
    ...clean everwhere including the coils a vacuum works real well. and that was "front or back"
    anaanymous
    Genius:
  • 3,422 Answers
If your frig is freezing the food in the chilling compartment as well as the freezer, it means one thing--its thermostat isn't shutting down the compressor when the set temperature has been met. You stated that you had it checked by, I assume, a professional service technician. Being a retired tech myself, I'm surprised that he didn't check this out and discuss it with you. Check the temperature in the freezer! If it is less than 10 degrees F., turn the thermostat to "warmer". If the temp in the freezer is 10 degrees F., leave it alone and go to the temp control in the frig, which is a damper that controls cold air flow from the freezer compartment. Close this damper until your temperature in the upper part of the refrigerator is 38 to 40 degrees F. If these efforts don't shut down the compressor and correct your problem, then the answer is simple. Your thermostat is bad and needs to be replaced. It isn't expensive, and should cost you less than the labor for a tech to install it. Good luck!
  • Priya darshan Oct 13, 2008
    I told you first that your thermostat is the issue.Dint i?then why did you reject my solution?
GE Profile freezer won't maintain temperature
clean the dust from underneath and make sure fan in freezer is working.
Feb 06, 2014 | Refrigerators
I have a 3 yr old ge Profile side by side refridgerator model #psc23sgrdss with the following problem. on 3 occasions in the last 3 wks I've found the temp. in the refrig section very high ( 56 degrees and...
I had same issue this past week. Refrigerator up to 45 freezer up to 15. Ice would melt and then everything would get cold again. Ice formed on everything. Next thing you know it was warming up again. I knew the rubber seal on door flap that opens to let ice out warped during summer months because I keep it 78 in summer. Had that replaced today. Temperatures have gone back to normal and stayed ALL DAY (knock on wood). Check door flap seal sticking your hand up making sure you don't push in the water tab. You should be able to feel if it is warped/wavy like an old LP or not. Good Luck.
May 20, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not geting cold
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
May 19, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE Profile PSC25 won't cool past 45 degrees
With that model that is a sign that defrost is not happening on time or the beginning of the problem. Temperatures in fresh food compartment above 38 are not safe. Look into the back of the freezer compartment and let me know if you see a frost line buildup. If yes it would be a good idea to manually defrost the freezer so you can remove the rear panel and check the defrost heater and defrost thermostat. It's also important that with this model that the problem be resolved quickly. I can help you if you want. The defrost heater will be easy to see if burned out because it has a glass tube around the heating element. If you replace the defrost heater you should also change the defrost thermostat. Fan motors going bad on that refrigerator seem to always damage the control board and if the board is replaced the the fan motor should also. Let me know if you want me to help you, Thanks, Sea Breeze
Nov 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE 24 Profile refrigerator: The freezer part
my refrigerator goes into auto defrost every 60hrs for 45 minutes or till the bi metal(defrost thermostat) says it had enough....recently i had ice built up on the coil because my defrost thermostat was stuck open...
ice builds up because the moisture that comes from opening the door or food condenses on the cold coil...tempurature of the coil is below 32 degrees which will ice up the condensed moisture...
defrost is timed to remove this build up
Oct 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile side-by-side fridge and freezer not cooling properly
Could be a few things. Condenser coil clean? Is the back panel cover of the compressor panel in place? It could have a bad part in the defrost system and it's built up with frost on the coil. To see if this is the problem, unplug the refrigerator and leave the doors open for 24 - 36 hrs. then plug it back in. It should work normal again for a few days until the frost builds back up. If this is the case the defrost system needs repair.
Aug 21, 2009 | GE Profile¿ Arctica® Energy...
Refrigerator and freezer running warm
Check and make sure fan in frezer section works properly.you should be able to hear fan slowing down when you open freezer, or find door switch and press and hold..hope it helps you..
Jul 07, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
PTS25LBM GE Profile Defrost cycle messed up
The GE Profile Refrigerator has circuit boards and sensors are in the freezer that sends a signal to the circuit board to begin and end the defrost cycle. It is very possible the sensor or the circuit board are defective and will need replaced. I will help you solve this if you like. This refrigerator is complex and will take more discussion with you to complete the repair, I am here to help, let me know, Thanks, Sea Breeze
Feb 05, 2009 | GE Refrigerators
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
292 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
