Cars & Trucks Logo
Posted on Sep 11, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replaced slave cylinder, now suddenly it won't start. Has no spark
4 cylinder, 2.5.. turns over good, normally starts right up pretty good. now since we've done this it won't start. no spark. what could i have knocked off to cause this to happen. also this is the 3rd slave cylinder I've went through. i've had this truck 3 years. and all 3 have happened this year. any idea why i keep going through them.
Bill George
Level 3:
  • Jeep Master 2,517 Answers
  • Posted on Sep 11, 2017
Bill George
Jeep Master
Level 3:
Answers
2517
Questions
Helped
543730
Points
7493
If your buying cheap parts you will have this problem.
Vernon Taylor
Level 3:
  • Jeep Master 7,446 Answers
 Vernon Taylor
Jeep Master
Level 3:
Answers
7446
Questions
0
Helped
1956084
Points
26207
Can't help you with what you might have knocked or damaged while replacing the slave cylinder.
A slave cylinder is an uncomplicated piece of kit that usually gives good service for many years and few things shorten that life. One of these is using fluid that is incompatible with the seal, another is overtravelling and a third is corrosion.
When the first replacement failed it would be usual to dismantle the failed cylinder to discover the cause of failure, which with only (usually) a single seal to examine would be fairly obvious and might or might not be a reason for a warranty claim.
5 Related Answers
Anonymous
  • 6982 Answers
  • Posted on Jun 11, 2009
SOURCE: 93 wrangler no spark
I'm certain that there is an "official" test for this sensor. I generally quick check by attaching a volt meter set to millivolts to the sensor leads and check for a pulse voltage when cranking. If in doubt and you don't want to spend big$ on the part, you can get an entire distributor at a scrap yard likely for half of the price of the new sensor.
Anonymous
  • 13 Answers
  • Posted on Jul 31, 2009
SOURCE: 06 wrangler 4 cylinder... keeps going thru spark
Pull the plugs and compare them to the pictures in repair manual, ie: Chilton's or Hayne's. May be a bad injector flooding them or an intake leak causing a lean condition.
Anonymous
  • 4669 Answers
  • Posted on Sep 02, 2009
SOURCE: 89 wrangler 2.5 5 speed.replaced crank sensor last
It sounds like your new crank sensor is defective. It should be under warranty.
Anonymous
  • Posted on Jan 05, 2010
SOURCE: Have a 1996 4 x 4 Jeep Country with a snowplow.
sounds like tps sensor mine did that if you push on gas pedal will start
ZJLimited
ZJ Limited
  • 17989 Answers
  • Posted on Jul 02, 2010
SOURCE: I have Grand Cherokee 1999 V8 4.7 220700
P0505 - Idle Air Control System Malfunction The PCM attempts to control engine speed during KOER self-test. The test fails when the desired rpm could not be reached or controlled during the self-test. IAC circuit open
VPWR to IAC solenoid open
IAC circuit shorted to PWR
Air inlet is plugged
Damaged IAC valve
Damaged PCM
The IAC solenoid resistance is from 6 to 13 ohms.
Check it.
3answers
1989 D21 4 cylinder started and ran fine yesterday. Got up this morning and it started just fine. Began to go down the road and it started spark knocking and had no power. I replaced the spark plugs and...
Maybe a clogged fuel filter....easy to replace. If no better, check the compression in each cylinder. If it's normal (>100psi), I think you are probably on the right track with electricals--it's probably the points/condenser and/or the spark plug wires. See if replacing these doesn't help.
Engine won't start
the spark plug wires can be confusing but a 4 cylinder is not that hard from the front of the engine being where the pulleys & belts are its 1,2,3,4 on the coil or distributor it can be in counter or clockwise rotation 1&3,2&4 or 1&4,2&3 likely its 1&3,2&4 hope you find this helpful
1999 Chevy Blazer S10.. Won't start.. It was
sound you have a blown clutch slave cylinder
2000 jeep wrangler wont start
If it won't crank, check clutch safety switch and cables for the starter.
If it cranks but won't start, you'll need to find out if it is ignition or fuel to know where to look next.
Slave cylinder troubleshooting
I'd be happy to help you solve your problem, but you kind of sow confusion. So I ask, does the engine crank over at its normal starting speed when you try to start it? And despite the heading reference to the clutch slave cyliinder, the problem is the car won't start? I'll tell you where to start troubleshooting every problem with the car not firing up. That is to check the battery's present condition. If the battery is low on charge you cannot rely on any further testing. So have the battery charged up or check it with a voltmeter to see if it needs charging. Is your problem a one time problem, or any events leading up to this that may have effect? If the engine started and ran fine before, and you heard no noise of an abrupt failure, then it most likely lost either fuel or spark (ignition) to the cylinders.
95 mitsubishi manual. Shifting problems. Changed slave cylinder and bled line and it worked perfectly . Today it won't shift unless engine is off. Should I bleed line again? What else might be wro
Check the slave cylinder is coming out when you push the clutch down ,without my head under the bonnet its difficult to say but either you have lost the fluid or the thrust bearing has now pushed through the pressure plate with the correct pressure .
1helpful
My 1998 Honda civic ex won't move but the motor
Have you just replaced the clutch? Taken out the transaxle, and put it back in? Are you sure transmission was in good condition before this? If so, review your procedure carefully to be sure you got it all back right.
Watch the slave cylinder while someone depresses clutch. You should see the little plunger move slightly out and move the clutch lever back. The lever moves the release bearing inside bell housing into contact with the pressure plate. If slave cylinder doesn't move at all, try bleeding again. The plunger has to move when clutch is engaged.
I'm not sure what you mean by "will shift but won't go into gear". You mean it's actually going into a gear position and car won't move? Or it won't go into any gear, period. As if you had no clutch?
2helpful
3answers
1988 toyota camry 2.0 turns over but won't start. Car has been driving like a champ and one morning wouldn't start. Turns over fine but won't fire. Tested for spark by removing spark plugs...
Fuel pressure at idle is normally 30-35psi. Start by taking the gas cap off, and putting it back on. That will De-pressurize the fuel system. Also, make sure you have gas in the car. I have seen gauges on these cars read wrong. I hope this helps.
1helpful
2answers
2001 won't start. turns over but doesnt even act like its firing. sometimes there is a smell of gas like it is flooded. started back in jan when it was cold. replaced battery and spark plugs to no...
check the color of your spark if it is blue your good if orange replace coil dependig on your setup and if you have 1 coild or 8 coils you many have to check each cylinder seperate just pull out spark plug replace the spark plug wire have someone try to start car and lood at color of spark i should note dont hold the wire just let it rest close by
if that is ok replace your crankshaft postion sensor as it tells the cars ecu when and to what cylinder to fire spark to faulty crankshaft postion sensors 99 percent of the time wont allow car to start or very hard starts the other 1 percent
if it helps please leave good review 4 thumbs
Top Jeep Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jeep Expert? Answer questions, earn points and help others
