Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Got color curves on Pioneer SDF-P5107
The color distortion started few inches from the bottom, went away for a couple weeks and now is back and it almost half the screen. Have heard about replacing convergence ICs, is it applicable to this model? or do I need to replace the whole assy, which i read cost about $350.00? Is it be a costly repair? Thanks a lot.
  • endy_seeckts Oct 20, 2008
    I checked out the convergence fix site (it looks easy to do) and opened up my tv. mine I guess is different that I only found 1 IC behind a silver heatsink (STK4274) on the top of the board and another IC located on the under side of the board which is bigger (STK 4277). And this board assembly I accessed from the front in between the speakers. Since the locations of the ICs and how it is accessed (all different from the site instruction) now I'm wondering if these are the same two ICs that I will need to replace? Can you please help me out with this.
    Thanks again,
  • 136 Answers
Check out this link for your type of problem it also has the directions on how to repair it manually
yes it will be a costly repair.but it is worth reparing the unit as it will be perfect after u get it repaired.
Posted on Oct 12, 2008
Indesit iwme12 fills with clean water when not running
sounds like a faulty valve. it maybe weeping, leaking water in.
Jun 20, 2013 | Washing Machines
My Samsung T4665F has a start up problem. Initially Relays click then eventually it starts up but with colored pixels over the whole screen. Then I have to switch off/on one more time and the pixels go...
This tv 100% have power supply board problems and might also have the T-CON decoders board problems too.The power supply board,that the board,where the power a/c cord plug into it.The T-CON decoders board,that the board sit wright in the middle bottom of the LCD screen panel.Tries websites like, to buy a whole refurbish power supply board for the replacement.Replaced the power supply board,should get ur tv power up right away and work,no more series of clickings noises.But,if the tv still have alots colored pixels lines on the screen.The T-CON decoders board it also dead.Replaced the T-CON decoders board too.
Oct 29, 2010 | Samsung LN-T4665F 46 in. LCD Television
I plugged my laptop in today and the colors on my monitor are extremely bright and distorted. I rebooted with no improvement. Help
  • Hi, "right click on a empty area of the Desktop Screen, when the window opens, select the Personalize Icon, it should be at the bottom, in the next window, click on the "Display Settings" category. Now you'll be in the Display window for the "Monitor; by trial bases select the "Resolution," move the (arrow to the highest setting, 1366 by 768 pixels... ), after doing this click on the "Apply and OK buttons, so that the change will take effect. "You can go back a couple and do this a few times to get the right visual settings. You can also adjust the [Color], example: [16 to 32 bits], and the "Color" in the [Advanced] area by clicking on the [Color Management] button. "Any other areas "I do not "recommend making changes." Try making a note of the changes you made; just in case! Note: You may need to restart the computer, if you don't see the changes right away! "Rating the solution for its "helpfulness, is appreciated, thanks."
May 16, 2010 | Dell G2210 22 inch Monitor
Pioneer Pro 700HD picture distortion
horizontal capacitor parts should be replaced...
Dec 31, 2009 | Pioneer PRO-700HD 64" Rear Projection...
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
GE 52 inch projection tv picture is dancing
First a couple of things:
1) Could you please try to describe the picture a bit. Is it curved toward the center from the top and bottom?
2) Can you please update this with the model number?
With the description thus far, I suspect a few bad connections in the convergence circuit, but with the info requested above, I should be able to confirm that and provide you with some repair options.
Hope to hear back soon.
May 05, 2009 | GE Televison & Video
Sudden discoloration, ghosting, bowed horizontal lines in top and bottom of picture
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Nov 10, 2007 | Samsung PCL6215R 62" Rear Projection...
Dropped camera, took awful pictures for a while
Possibly who can tell - probably a connector came loose and you smacked it back Lucky old you.
Sep 07, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Tv turns off, volume adjusts incrementally then shuts off, screen is tinted blue
there is a defecton the small signal panel. most of the time caused by power surge..john
Aug 30, 2007 | Insignia IS-LCDTV32 32 in. Television
Distorted picture and multi-color words
ive got the same problem on mine ita a 2001 model and also mine when you turn it on it goes off by itself and wont stay on.also mine has multiple pictures one green and one red almost as if 3d im not sure what it cost to fix it but tvs have come down so much i might just buy a new one. good luck with yours
Aug 12, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
140 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
