Question about Toshiba Televison & Video
Not a valid disk
WE have a toshiba DVD player (sd-4980su) and every time we insert a disk we get "not a valid disk" and disks all play on our other DVD player.
    Novelist:
  • 159 Answers
Dvds are formatted in different formats.
Your player may not recognize the format on that dvd disk.
If it does it with too many disks then the optical eye on the dvd plyer may have gone bad or it isn't reseating in the start position correctly.
Hope this helps
Fran
Posted on Oct 12, 2008
    Genius:
  • 3,422 Answers
HI,
The problem is with the DVD player.Pleas use a leans cleaner to clean the lens.
I will give you more home remedies if they don't help then you will have to get this repaired.
  • Priya darshan Oct 12, 2008
    see if the player tries to read the disc. Load a disc and listen.
    Does
    the player make squealing noises or is it totally quiet? Squealing
    noises may indicate that the player is trying to synchronize with the
    disc but can't due to an obstruction on the lens or in the laser path
    inside the pickup or a defect in the pickup. This can also be caused by
    an intermittent signal problem due to a faulty ribbon cable.
    Totally
    silent means that the photo sensor is not getting any usable input from
    the laser at all, meaning that the pickup is "blind" for lack of a
    better word.
    This can be caused by an obstruction of the beam by
    foreign matter on the lens or inside the pickup all the way to a
    marginal or failed laser diode and/or photosensor array. This can also
    be caused by a bad ribbon cable with one or more severed traces.
    You
    could try to clean the optics. This is the most common malfunction as
    far as i know in all disc players. It would involve taking the cover
    off and finding a way to expose the lense, and then cleaning it with a
    very gentle brush. some players have a cover for the lense that swings
    to the side during playing, this greatly reduces the chance of dust
    accumulating, but its still worth the try.
    If you actually see dust on the lense, then its just that simple. clean, close, play.
    It may also be worth your while to check on the small shafting that
    guides the carriage of the laser pickup. Dirt, grome, dust and
    solidified lubricant can cause stoppage of the carriage and the laser
    eye then fails to read the next track. Please refer to the image i have attached.
    This is the image:
My toshiba bdx2000 won't play the expendables.
Because of the lack of internal memory on this player and the mass of content on this and some other newer disks, you have to ensure that you have an SD card inserted with at least 2GB capability.
Nov 26, 2010 | Toshiba BDX2000 Blu-Ray Player
Toshiba SD-K625 5 disk player won't play DVD but will play CD
Could be that the laser mechanism has lost its ability to focus properly on the dvd disks. U might want to try a firmware upgrade just in case the player has corrupted software. If not effective, then it is time to go shopping since a repair is not cost effective.
Mar 31, 2017 | Toshiba SD-K625 Multi-disc DVD Player
Toshiba sd-r2002 - won't recognize blank CD when trying to write files to a CD
right click on the drive.... go to properties... under tab recording, remove tick "enable CD recording on this drive" and press apply... after that tick "enable CD recording on this drive" and press OK.
It should work.
Jun 01, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Toshiba sd-r2002
I'm very late to your question, but the problem is that this drive doesn't burn DVDs (i.e., it was not designed to do that). It's a CD-RW, DVD-ROM (read only).
Apr 03, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Dvds wont play
Check out the link I have posted below.
http://www.homemovie.com/compatibility.htm
according to the list, your in the 5% area of dvd players that won't read burned home made disks-DVD's
Sorry Pal your in the same boat as myself.
I have a Toshiba SD-2107 --- We're both aout of Luck :(
Looks like it's time to invest in a new DVD player.
Aug 05, 2008 | Toshiba SD-2109 DVD Player
No Valid Disc - Toshiba SD-P1900
Yep sone of a gun ! With the Toshiba Portable DVD Player, hold the "Mode button" down for several seconds and it will make a chain saw noise take your finger off, hit it again once and bingo now it works. I was ready to throw this player in the trash!
Jan 17, 2008 | Toshiba SD-P1900 Portable DVD Player
Error message
i think your problem is that your lens( laser lens) that reads the disk is dirty. Try this get q-tip and put just little rubbing alcohol and clean the lens.
May 30, 2007 | Toshiba SD-K620 DVD Player
Cd's are ok but no dvd's...
Had similar problem. Found the disk was not rotating. Adjusted the torque on the hold down screws of the drive unit allowed the disk to spin. Still had some motor noise, but DVD would load.
Apr 09, 2007 | Toshiba SD-2800 DVD Player
Toshiba SD-3980
If the disk is not dirty, smudged up or scratched -- it is likely the laser pickup getting weak or the spindle motor not keeping at the right speed. If you have to clean the disc, wipe from the center out with a clean soft cloth.
Jan 13, 2007 | Toshiba SD-3980 DVD Player
Televison & Video Logo
138 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
