Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gold start button flashing dishwasher won't start
The start button keeps blinking when i aattempt to start the cycle and the mashine wont go on at all
  • 2 more comments
  • chrissssssey Oct 20, 2008
    The green start light on my dishwasher flashes four times and won't start
  • pblair36 Jan 25, 2009
    My Whirlpool Gold Silent Partner III is 4 years old and has never been any good at cleaning the dishes. Now, it just blinks and can;t be started. I strongly encourage those searcing for a new dishwasher to consider another brand.
  • crltkcagle Apr 11, 2009
    I keep pressing the start buttong and it won't start! GRRRR
  • Anonymous May 12, 2009
    WHRILPOOL DISHWAHSER QUIET PARTNERS I CLEAN LIGHT KEEPS BLINKING. DISHWAHER WON'T TURN ON. CAN'T FIND MANUL.
Press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Posted on Apr 12, 2009
  • 725 Answers
PROBLEM: WON’T START AND START/RESUME KEY LED FLASHES
3 TIMES WHEN START/RESUME KEY IS PRESSED.
Control programmed to
not start if it suspects
door switch is stuck
closed. Control looks for
switch to open between
cycles.
■ Customer didn’t open
door between cycles.
■ Door switch contacts
are stuck closed.
1. Open and close door and then press
Start/Resume key. Instruct customer.
2. Unplug dishwasher or disconnect power.
3. Check resistance across door switch in
Power Up circuit. Confirm proper latch
assembly operation.
Faulty control.
1. Unplug dishwasher or disconnect power.
2. Check/replace control.
PROBLEM: WON’T RUN AND LED FOR START/RESUME KEY IS
BLINKING SLOWLY
By design, if the door is
opened or power is
interrupted during a cycle,
the user must press the
Start/Resume key to
resume operation.
Instruct Customer; refer to Use & Care manual.
The door must be latched
for the Start/Resume key
to work.
NOTE: For models with all
keys on top of the door,
the Start/Resume key can
be pressed with the door
open but the door must
be latched within 3
seconds.
Confirm door is closed properly before pressing
Start/Resume key. Instruct Customer; refer to
Use & Care manual.
Door switch not making
contact:
■ Faulty door latch
assembly.
■ Faulty door switch.
2. Measure resistance of door switch contacts
while checking mechanical operation of latch
assembly. Confirm switches not loose from
assembly.
Posted on Oct 21, 2008
Worked for me too...just did it,.
Posted on May 16, 2009
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
How do I reset a flashing green start button
Blinking start button usually means a bad door switch cannot reset the control does not see the door as closed
Aug 14, 2014 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
I have a Whirlpool gold Quiet partner III. The Normal button of the cycle is blinking and I can't start the dish washer. What is going on?
most likely the door switch is not making contact or is faulty. Shut the door tightly and see if it makes any difference.
Please provide the full model number of the dishwasher in case you need further help.
Aug 26, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gold
First press your "Sani-rinse" button and the your "Heat Dry" button and toggle between them a couple times. This will reset your control module. If the clean light continues to blink then it means that your heating element needs replacing.  This is not a big job, either. You will need to order a new element and come back for instructions if you can't figure it out quickly....
Dec 16, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Gold Quiet Wash Plus GU940SCGZ3
Press the cancel button, Then cut power to the dishwasher for a period of time. restore power to it then try a cycle.
Jul 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
WHIRLPOOL ADP 8540 dishwasher has blinking light on all the time (blinking in cycles of 4). When you turn it on (by holding the button down for around 4 seconds) it wont complete the cycle and you need to...
WHIRLPOOL ADP 8540 dishwasher has blinking light on all the time (blinking in cycles of 4). When you turn it on (by holding the button down for around 4 seconds) it wont complete the cycle and you need to keep restarting it. can anyone let us know what the problem may be. Thank you
Jul 17, 2008 | Whirlpool Dishwashers
Whirlpool gold- quiet partner III
An angel of mercy on another blog posted this solution and it worked for me as well. My Whirlpool Quiet Partner Dishwasher would not work due to the CLEAN light flashing in 7 interval sequences. I followed these steps and my dishwasher is not working perfectly...hope it works for you:
"Well for mine which is a Whirlpool Gold Model # GU2400XTPS3, I found the seq of buttons that I had to push to reset the curcuit board. I think it may of been in this forum somewhere. But I had to push - Sani Rinse, Heated Dry, Sani Rinse, Heated Dry, and then the dishwasher went through it's diagnostic cycle and then after that the light stopped blinking and the dishwasher works great. Supposily, there is a Product Tech Sheet behide the kick panel of every dishwasher, but mine was gone so I had to find the information on the internet. You might want to do a serach for the correct seq of buttons you have to push to reset the curcuit board. If you know for sure that the heating element is bad, you will have to order one. "
Mar 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
7,195 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
