Proscan 19LA25Q my tv power cord is plugged in but i cant get it to power on i heard a loud crackling when i was playing my games on it then it wouldnt power back on
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
No stress, change your power module
Posted on Oct 12, 2008
JUST STOPPED DO THE HAVE USES ITS A VIBELIE MAX PRO R209F
Check for a fuse holder near the power cord on the unit. If you do not see one, chances are that there is not one that is user changeable. If you heard crackling on the radio, chances are that it is not a fuse. Fuses open immediately to protect the equipment, so a long duration of noise would indicate a different electrical problem.
If you have your manual, please consult it about a fuse.
Apr 29, 2015 | Exercise & Fitness
TV popped when turned on
bad manin bord poped the main power transister we nee dto replace that with spare part .
Feb 03, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Crackling when turned on then high pitched howl and sound like vinyl being played loud and having stylus dragged across it is the only way to describe the noise after howl. was being used and did crackle...
You didn't say whether it was one or both channels. The word to describe the noise when using a turntable, back in the days, is called Acoustic Vibration. Your issue is not that. I can be an amplifier oscillating, for the high pitched sound and the crackling could be DC Offset*meaning a damaged amplifier) If you need further assistance, or would like to inquire about a repair, please visit my website at audioserviceclinic.com. Thank you.
Oct 26, 2014 | Audio Players & Recorders
I bought my 19" Proscan LCD (19LA25Q) used from a
The Proscan 19LA25Q came with a remote originally. Unless the IR receiver has failed, it should work with a universal remote. (Note: if the TV is newer than the remote (or released less than 6 months before the remote was programmed), the remote codes for your TV may not be included.) Since the code lists on universal remotes do vary depending on the age and model, please give more information than just the brand. GE remotes usually have a version code label in the battery compartment. This version code is needed to look up the correct code lists. Some GE universal remote built by Jasco codes are here: https://byjasco.com/support/ge-universal-remote-codes.
The Proscan 19LA25Q was probably built in 2007, since there are reviews from 2007. That was also the year when this size TV had to have an ATSC tuner. So if your remotes were programmed before July 2007, they may not be compatible. Some of the current Proscan TVs probably use the same parts as some Sylvania, RCA and Curtis TVs.The 19LA25Q was warranted by On Corporation which has control of the RCA brand now. However, I don't know when they bought the label.
Amazon lists a few direct replacement remotes for the 19LA25Q. See https://www.amazon.com/Original-Proscan-Control-E20F-19LA25Q/dp/B00KQVDRNK and https://www.amazon.com/PROSCAN-Replacement-Remote-Control-19LA25Q/dp/B009H5QVIO . Remotes.com also has a replacement remote: http://www.remotes.com/SearchResults.asp?Search=19LA25Q .
I hope this helps.
Apr 21, 2017 | Proscan 19LA25Q 19 in. LCD Television
While playing call of duty 4, the explosions make the TV's speaker go to a loud crackling noise, Only this game does it.
That's because explosions are pretty much only low frequencies, otherwise known as bass. Your tv crackles because the low frequency emitters of your tv are either of low quality or malfunctioning. If you lower the volume of your tv it should fix the problem.
Mar 25, 2010 | Sony Playstation 3 (PS3) Console
Tv blew up
Power board probally have burn capacitors.Take the tv aparts,check for puff up or burst open capacitors.Know how to solders? Replaced these capacitors well get ur power back.Or replaced the whole power board buy it at Shopjimmy.com,Ebay.com.
Jan 24, 2010 | Hitachi 60SBX78B 60" Rear Projection...
I need a new power cord with the box and cant find anywhere, please help.
The TV needs 12vdc 5A switching power supply, http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=1952370
You still need to get the main input power cord for it which you can get from local PC repair shop. One thing about this TV is that the backlight inverter board goes bad on most set.
Jan 24, 2010 | Proscan 19LA25Q 19 in. LCD Television
Need new power cord and remote dog chewed proscan model # 19la25q where can i get them at
Try website 1-800-Remotes Factory original.For the remote.Try Partstore.com,Amazon.com,and Shopjimmy.com.For the A/C power coard.
Jan 01, 2010 | Proscan 19LA25Q 19 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
