Question about Cameras
Tried to take film out before I used all 24 shots. Didn't completely rewind. Are pictures taken at the end that has already rewound and will I be able to save them?
    Sergeant:
  • 196 Answers
You may have a little light damage on the last shot or two that are wound but the first ones on the strip should be ok still
Posted on Oct 12, 2008
I have a 36 exposure film in the camera with 25 pictures taken and I want to remove the film without taking more photos. How do I rewind?
To rewind the film mid-roll, press the two film rewind buttons simultaneously for one second. The two buttons are marked with a red film symbol, and double as the Auto Exposure Bracketing button to the left of the viewfinder and the Aperture/Exposure Compensation button to the right of the control panel.
The film is completely rewound when a blinking "E" shows in the control panel.
Sep 08, 2010 | Nikon F65 35mm SLR Camera
Camera does not rewind after end of film it spins, but does not engage the film. Joe M.
it is likely that this model of camera spins the entire roll onto the take-up spool, and then slowly rewinds one frame at a time until the last picture is taken. Then it has already almost rewound,
This shows up when you load the film. The cameras digital counter counts up to the number of pictures available, and counts downward each picture taken.
Sep 08, 2010 | Canon Sure Shot 80U 35mm Point and Shoot...
The Rewind has broken
The first thing you need to do to establish whether there's really a problem is to replace the film. It seems like after the battery change the camera simply rewound the film.
If the shots are special and you don't want the risk of ruining them, open the back of the camera in total pitch black darkness and then feel to check whether the film is rewound or not.
May 28, 2010 | Konica Minolta Maxxum 4 / Dynax 4 QD 35mm...
My Canon AE-1 Program will not rewind. I shot the whole roll, rewound a little, and then accidentally opened the back cover. The counter reset to S, and the rewind crank just unscrews when I try to...
I think you have already ruined the film except the frames that are rewind back to the film cartridge.
You can take the film out from the camera, push in the rewind button at the bottom, pull out the film from the film take up reel.
On the film cartridge, turn on the long tube in the middle clockwise to wind all the film back into the cartridge.
If you had the back opened briefly, do manual film rewinding in the dark room.
May 21, 2010 | Canon EOS-AE-1 35mm SLR Camera
Film has not rewound but has 'reverted' to showing
On the toplate of the camera, to the left hand side, is a button which slides to the left. It is marked with a film cassette outline, and two arrows to the left <| <|
At any time, you can use this button to rewind the film back into the cannister. It should make a whirring noise for 5-10 seconds, and will stop automatically.
If it makes no noise, you may have a flat battery, or the film may already be rewound.
You can insert new power (battery) without affecting the film cassette, if need be.
However, if really unsure, then:
1) Slide the rewind button to rewind(i.e. to the left).
2) Familiarise yourself with where the back opening latch is.
3) Go into a pitch black room. Preferably under a quilt in a pitch black room.
4) Open the back and take out the cassette. If it comes freely, its probably fully rewound. If its still attached to the take-up spool by film, then (holding the film by the edge only) pull on the film to release it slowly from the take up spool. Whilst it can be quite a tug, they are designed to let go of it "under protest". (Do not pull it so hard that you strip the gears, but fairly firmly).
5) Using the spool winder on the top of the cassette, wind the trailing film back into the cannister. If you've never seen a 35mm cassette, then in the dark one end has an elevated round part, the other end has a void into the cassette. You can tell the elevated part, and start winding - it should only wind one way and feel like its winding onto the reel (wind the other way and it feels like its unwinding - even in the dark!)
6) Only when you are sure film is in the cannister, can you turn on the light.
Films are very sensitive to light, so if you do not feel comfortable doing this procedure in total darkness, go to a photo processing store who will do this for you, usually for no charge (other than the hope you'll let them process the film). They put your camera in a sort of black pillowslip, but the procedure is the same.
Hope this helps
Jan 20, 2010 | Olympus SuperZoom 700BF Film Camera
Need to take old film out of camera
Usually when the film is shot (you may get more frames than the indicated 24/36 or whatever on the film canister) it will automatically rewind. If not, there's a button in the bottom of the camera you have to press - or other switch-like thing with a symbol 'o__' for rewinding the film.
Beware not to open the back of the camera before you are surethe film is rewound.
Apr 09, 2009 | Photography
Minolta Maxxumm 4 - rewinding too soon
Hey Pix4me,
I would make sure that the manual rewind button on the back of the camera is not stuck in, or you're not accidentally hitting the manual rewind button. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 06, 2008 | Konica Minolta Maxxum 4 / Dynax 4 QD 35mm...
Film Rewind
check the mechanism inside the film compartment, it may have a broken rewinding gear, if there's nothing broken clean the contact point inside the film compartment, use cotton buds and alcohol or fluid.
Aug 26, 2007 | Canon EOS-30 35mm SLR Camera
Problems rewinding film.
Your film is already rewound (if I understood you correctly). Your camera is beeping because the film is rewound and there is no film for the camer to take the photo on since it has been rewound.
Jul 09, 2007 | Canon T70 35mm SLR Camera
The film automatically loads then rewinds when a new film canister is added
Hm. Well, the way this camera works is actually very clever. When you first load a film into it, it winds the entire film out of the cassette and into the camer. As each shot is taken, the film is rewound back into the film cassette. The advantage of this is that if the back of the camera is accidentally opened, the shots which have already been taken are already safely back in the film cassette and will not be damaged by the light ingress. However, your camera is behaving strangely. I would check that the electrical contacts where the film cassette goes in are clean. You can clean them using a cotton bud moistened with methylated spirits.
Apr 13, 2007 | Canon EOS Rebel G 35mm SLR Camera
Cameras Logo
29 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
