Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Get a Professional
Find a Solution
Most Common Problems for:
Generic problem for all Microwave Ovens
Sharp carousel microwave R-1514 F
frkwan27 on Oct 12, 2008
sharp carousel microwave R-1514 F one touch door release button is stuck
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Oct 13, 2008
Helpful)
MicrowaveSvc
Rank: Guru
Rating: 88%, 4456 votes
What usually breaks is the door open lever.
On an over-the-range model, only the control panel needs to be removed in most cases.
Please unplug the oven first.
At our site, we now have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
We have 2 service manuals that are very close to this model have uploaded it them our site here to help you. You will need the free Acrobat Reader to view or print them.
http://www.microwavedisplay.com/r1500_r1501_r1505_r1506_sm.pdf
http://www.microwavedisplay.com/r1512_sm.pdf
(Note: do not rely on the part numbers shown in the manual. Verify them at the Tritronics site mentioned below)
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) to open the door.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
Comments:
Nov 14, 2008
- You can call Tritronics toll-free at 866-779-5835.
Jan 02, 2009
UPDATE: Tritronics is now
Encompass and you can order from them here or by calling 866-779-5835 toll-free.
Was this helpful?
Yes
No
Related Problems
Everything seems to work but cannot heat anything up
It takes much longer to heat than it used to. (!0 minutes...
Have a GE microwave spacesaver oven/Model #JVM1660B5,Light...
The keypad does not work. The display screen says "Press...
My touchpad is not working. The time is displaying and the...
Can you Help with these Microwave Oven problems?
ge profile, it come on but dont heat...
Solve
its a ge profile, it come on but dont heat and the plate dont turn when on what should i check
in the inside of the microwave there...
Solve
in the inside of the microwave there is this paper like thing that has a hole in it and not the... (More)
smoke came out of the door of the...
Solve
smoke came out of the door of the microwave oven and the smell was horrible = the electic is finebut... (More)
Our microwave went dead.
Solve
Our microwave went dead. It's only three years old. My husband put some chicken wings in, closed the... (More)
have a brand new UCA2000NT2 Amana...
Solve
have a brand new UCA2000NT2 Amana microwave working on half power. I think I might have a diode... (More)
Sponsored Links
Describe your Microwave problem:
Select a Category:
Top Microwave Oven Experts
Rank: Guru Guru
Solutions: 2826
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more Microwave Oven Experts
Top Small Appliance Repair
(800) 341-6361
Mr. Appliance Corporation is one of the largest...
Mr. Appliance
(866) 895-9295
Rest assured, when you place an order for parts it...
Easy Appliance Parts
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
