Back to:
Tags:
Lexmark Refurbished MARKNET X2000 SERIES PRINT SERVER  Print Server
Lexmark Marknet unable to connect to Netware 5.1...
By Bray - usenet poster
I???m having some problems with Lexmark Marknet print servers. We are using
Netware 5.1 servers with ipx print queue???s. The print servers are MarkNet
X2000 series and MarkNet Pro3 Series from Lexmark. The print servers are
being serviced by a Netware 5.1 server. (server a) I use the MarkVision
Printer Utility to setup the printer server.
We are having a migration project from Windows NT workstations to Windows
XP workstations. We have made new print queue???s for the XP environment. We
also want to use an other server (server b) for servicing the print
servers. I have made al the new queue???s on the volume on the new server
(server b). When I use the markvision to add the new server (server b) to
the existing print server it doesn???t connect. Could there be a problem in
de IPX environment ?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 27, 2006
Not Rated (0)
paulrmc
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Any reason why you dont want to use NDPS with IP? Most print servers like
lexmark will work with IP/LPR printing all you need to do is find out
what the name is for the port. Some use raw others use printer etc..
The print queues can easily be attached to the ndps printers within the
NWADMIN (workstation client MUST have ndps installed prior to assigning
queue).
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Lexmark Marknet unable to connect to Netware 5.1 server with IPX:
I don't want to Accept this solution
Can you Help with these Print Servers problems?
Print Servers
examples of graphs of the fundamental functions and...
Lexmark Refurbished MARKNET X2000 SERIES...
I have just purchased this device and have rest the IP...
Print Servers
I've changed the cartrige and I did remove the tape before...
Print Servers
code sc990
Print Servers
We have the card. What else do we need
Loading problems.
Repair Service
Find Print Server Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
