Question about Whirlpool Duet GHW9150P Front Load Washer
How do i remove the front panel
Could you please explain what screws to remove to take off the front panel to check the inside and which is the front panel is it the hole front or just part? thanks
    President:
  • Whirlpool Master
  • 2,651 Answers
Along the front bottom there are( 3) torx 20 screws to remove the lower acess panel
Posted on Oct 14, 2008
Please explain how to remove the LH front door panel on a 2008 Toyota Auris to check a problem with the power window
the actual armrest on the panel will lift off with a little lifting under edge after making sure there are no screws holding it down, depending where car was assembled, it can have screws or it may not have any at all fsatening it to panel, underneath the armrest will b two philips head screws holding panel to the door
, remove them as well as any other visible fasteners and it will lift away from door
Dec 05, 2012 | Cars & Trucks
I need to replce the drivers side mirror. Just seeking instructions on how to.
Remove front door handle bezel screw cover Remove inside handle bezel screw Remove inside handle bezel Lift upward on the rear of the front door inside handle bezel Disconnect electrical connector Remove handle screw cover
Remove handle screw Remove door trim panel upper screw Remove door trim panel lower screw Remove door trim panel (pull the door trim panel outward to release the pin-type retainers)Remove front door sail panel
Disconnect mirror electrical connector Remove 3 exterior mirror nuts and exterior mirror
Mar 07, 2011 | 2009 Ford Fusion
Hi there, Please could you explain how to change belt on Whirlpool dryer, model AWZ3413? Many thanks.
I will also include a link to check out the routing of the belt
http://www.applianceaid.com/images/belt-config.JPG
If you hear a loud bang while your dryer is working, and you notice that the
drum has stopped turning, chances are the drivebelt has snapped.
Fortunately, replacing the belt is a fairly straightforward operation that
can be handled with a few simple tools.
First, unplug the dryer. Lift the lint-screen cover and pull out the lint screen
If your dryer has a lint screen on the inside of the door, skip this step.
Then remove the two screws that are under the cover. To unlatch the dryer top,
insert a thin-blade putty knife between the top and front panel,
about 2 1/2 in. in from one corner. Push in on the knife to release the locking
clip, lift the corner, then release the clip on the other side. Swing the top
up and lean it against the wall.
Next, move to the lower toe panel. Slip the putty knife between the lower panel
and the door panel at one side and twist the knife to release the clip
Then release the opposite clip and lift the panel up and off the hinge springs.
To support the dryer drum while the belt is being replaced, place scrap wood
under the front of the drum.
Loosen the two screws at each side of the bottom of the front panel.
Move to the top of the panel and remove the screws from the inside of the
cabinet that hold the front panel to the sides.
Slide the old belt off the drum.
Installing the belt
Lean the front panel out slightly and allow the drum to rest on the scrap wood
support. Drop the new dryer belt between the front panel and the drum, and
loop it over the drum. Then, lift the drum slightly while pushing the front
panel back into position.
Replace the screws at the top inside of the front panel, tighten the lower panel
screws and remove the scrap wood from under the drum. Check to make sure that
the rear drum seal fits properly over the lip on the rear bulkhead.
Position the new belt where the old belt was, with the grooved side of the belt
facing down.
Now, move to the motor area and pull out the old belt. To route the new belt
around the idler and drive pulley, first pass the entire belt, doubled up,
under the idler pulley. Then, push the idler belt toward the motor, slip the
belt around the motor pulley and release the tension on the idler pulley.
Open the dryer door and rotate the drum counterclockwise a few times to make
sure the belt is tracking properly. Lower the top and press down at each
corner to engage the clips. Lift the lint-screen cover, replace the two screws
and reinstall the lint screen. Finally, secure the lower front panel and turn
on the dryer for a test.
This is a FREE answer
Please RATE me
Jan 13, 2011 | Dryers
How do i get the panel off to work on it?
If you are referring to the CONTROL PANEL, follow these steps:
1. Locate and remove the three screws that hold the top panel in place in the REAR of the washer. With the screws removed, the panel will slide back, then lift off.
2. Open the dispenser drawer and push the release tab in the back to release the drawer so it will come out.
3. Remove any panel screws behind the dispenser drawer and along the bracket inside the washer directly behind the control panel.
4. Insert a putty knife directly above the door in the seam under the control panel. There is a release tab that you need to depress and the panel should pop loose.
Use caution not to stress any of the wires.
If you are referring to the LOWER TOE PANEL directly below the door, you need to you will need to remove the access screws (7mm or T2 Torx type) that are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off.
If you are referring to the REAR PANEL, remove the series of screws around the perimeter of the panel and remove. You normally do not have to disconnect the water lines to accomplish this. However, shutting off the water and removing the hoses can give you better access.
If none of these are the panel you are referring to, please post back and elaborate a bit more and explain WHAT panel you are trying to remove. I hope you find this information helpful.
Aug 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How to fit a belt for a indesit dryer ISL70c
Hi
Thanks for using FixYa. Please follow the step-by-step procedure---
1. Remove the front panel.
2. Reach underneath drum and behind motor to locate idler pulley. Push idler pulley to left to release drum belt tension. Remove the belt from the motor pulley.
3. Remove the drum and belt from the cabinet.
1-- Prepare for replacing the dryer belt by lifting the lint-screen cover on the top of the dryer. Then remove the lint screen. Skip this step if your lint screen is inside the door. Remove the 2 Phillips screws inside the door instead.
2-- After removing the lint screen, lift the cover and remove the screws that hold the lint-screen housing to the dryer top.
3-- Slide a putty knife between the front panel and the top near a corner. Lift the corner and repeat on the other side.
4-- To remove the lower panel, insert the putty knife between the panel and each side. Then twist to release clip.
5-- Place a few wood blocks under the drum. These support the drum when the front panel is moved away from the sides.
6-- Loosen the screws that secure the bottom of the front panel to the dryer sides. Do not completely remove the screws.
7-- Remove the screws that secure the front panel to the dryer sides at the top. These are accessed from the inside of the cabinet.
8-- Lean the front panel away from the sides and slip the new dryer belt over the drum. Then re-secure the front panel.
9-- Check that the lip on the back of the dryer drum fits properly against the seal on the rear bulkhead of the dryer.
10-- Locate the original position of the old belt, and slip the new belt in place. Keep the grooved side of the belt down.
11-- Push the idler pulley toward the motor and loop the doubled-up belt around the idler pulley. Slip belt around motor pulley.
12-- Rotate the drum counterclockwise a few turns to check belt tracking. Then replace remaining components and test run.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 20, 2010 | Washing Machines
My Kenmore 80 series gas dryer will turn on but won't spin
Hi, Sounds like the belt broke.
UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off.
There should be instructions that came with the belt. I will try and explain how this goes on. The idler pulley fits in a slot right in front of the motor. Put the belt over the drum with ribs touching drum. Now, thread the belt through the idler pulley wheel and bracket and set the belt on the motor pulley. The ribs should rest in the grooves on the motor pulley.
I hope this helps you. If I can assist you further, please let me know. Please rate me performance so that others as well as myself will know how I am doing.
Thanks
Vic
Feb 10, 2010 | Kenmore Dryers
When I try to start my washer it beeps and flashes f then dl. I lost the owners manuel. What does this error message mean and how can I fix it?
The error codes are not listed in the Owner's Manual, they are listed in the Technical Data Sheet. "Fdl" is a door latch error code. This is an indication that the door latch is broken or the Central Control Unit (CCU), which controls the latch is not working properly. The technical data sheet that comes with the washer explains all the error codes, diagnostics steps and troubleshooting procedures on how to determine which component has failed. The tech sheet is located inside the washer behind the lower toe panel directly below the door. If not directly behind the toe panel, it will be affixed to one of the interior cabinet walls. To remove the toe panel, you need to locate and remove the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off.
NOTE: For better access to the toe panel screws, you can prop the two front feet of the washer up. (A 2x4 works well for this).
Inspect the door of the washer to ensure the latch pin is intact and not broken. Then, inspect the latch mechanism on the front of the washer to ensure nothing is lodged inside. Last of all, remove the top and panel of the washer by locating the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, then lift off. Locate the connector plugs that run between the CCU and the door latch. Unplug each connector (one at a time) and plug them back in to make sure they are seated properly and making good contact.
If you determine the latch is broken, the following link explains the steps necessary to replace it:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
If you have any questions, please let me know. I hope this helps you.
Sep 25, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool dryer len2000pw0, starts fine, heats up, but will not spin?
Hi, you will need to change the belt. Here is how:
Normal 0 , UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off.
Thanks
Vic
Jun 05, 2009 | Whirlpool LEN2000PW Dryer
Need to replace the front felt seal - GE gas dryer
since you got the top opened, now look inside the front panel toward top remove screws or hex screws now you can remove the front panel. Undo the door switch wires before removing the front panel. The felt seal should be glued to the front panel aroun the opening to the drum you should be able to tell where it was.
Mar 01, 2009 | GE DVLR223 Dryers
Getting inside my washer
remove 3 screws back on the top remove top but all you need to do is remove all the rear screws holing back panel on roll on the new belt to the pulleys
Mar 01, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
551 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
