I have a Palm Tungsten E. Whenever I try to hot sync there is always this error message as follows; An error occurred in the application you are using Note the error code and contact the developer of this application (Sys 0505)(0,746) What should I do to get rid of this problem?
    Genius:
  • 3,422 Answers
The Graffiti and the Backlight applications are not compatable and must be deleted.DO a hard reset (Press power button and reset until the Plam Logo screen shows, press up button - this brings you back to original factory setting, and potentially undoes all the stuff you did when trying to make the thing work), synchronize, hit home icon, press menu button, select delete, find Backlight, hit delete, find Graffiti, hit delete, and sychronize again.
Posted on Oct 12, 2008
Upgraded from tungsten e to tungsten t5 did first hotsync but subsequently get error message line:4038 error launching application
Hello.
From Palm Support:
When you upgraded from the E to the T5, did you precisely follow the upgrade directions? These steps include the following actions:
Did you install the new Palm software that came with the T5? Did you rename the Backup folder on your computer before you synced the T5?
If you did not rename the Backup folder you have installed system and preferences files from the E that are not compatible with the T5 and NVFS.
Advise that you hard reset to return the E to factory condition and precisely follow the upgrade procedures.
Hope this helps.
Jan 05, 2010 | Palm Tungsten T5 Handheld
Tx will no longer sync with outlook 2003 or outlook 2007 calendars. Software reinstalled, tx reset, latest updates for syncing with outlook 03 and outlook 07 loaded, still won't sync to outlook calendar...
I would recommend contact the palm free chat. Here is a link for that. I have a TX and have used the chat feature myself and always with good results. Scroll to the bottom of the page and then you will see Palm chat. From there click on chat now and follow the directions. Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/tx/unlocked/supportservices/page_en.html
Nov 18, 2009 | Palm TX Handheld
I cannot sync my Palm Tungsten E with MS Outlook.
  1. Step 1 Install the Palm Tungsten software. This software is required in order to sync Palm Tungsten with Outlook Express. To install the software, place the CD-ROM in your PC and follow the on screen instructions.
  2. Step 2 Use the HotSync cable included with your Palm to plug into the USB port of your PC. You will then plug the other end of the cable into your Palm Tungsten.
  3. Step 3 Open the HotSync Manager program on your PC through the "Start" menu or clicking on the icon. You can manage the different programs available for synchronization through this program. Select Microsoft Outlook as one of the applications that you want synched onto your Palm Tungsten.
  4. Step 4 Turn on the Palm Tungsten. You will see a star icon on the menu of your PDA. Tap this star with your stylus to start syncing Microsoft Outlook Express. A dialog box will appear on your PC during the process to know the progress of the synchronization.
  5. Step 5 Unplug the cable from your PC and Palm Tungsten once the sync is completed. As the Palm resets, you will now notice that Microsoft Outlook Express is available on the PDA.
Jun 25, 2009 | Computers & Internet
Tungsten V
Re-arrange port configuration, install latest version of palm desktop. Right click on palmsync icon on system tray and check "Local Serial" . You may also use IrDa as alternate sync method
Apr 04, 2009 | Palm Tungsten E2 Handheld
Need Hot Sync module on backup PC
Plug your E2 into your pc and when it says new hardware found, install the cd. Do not continue till you have verified sync connection between pc and pda
Dec 11, 2008 | Palm Tungsten E2 Handheld
Fatal Alert when doing hot sync on palm tungsten e2
you gotta do a hard reset. i had the same problem. go to the palmone website and look up how. make sure you back your stuff up in case you can't get things back. once you perform the hard reset the error should go away.
Nov 09, 2008 | Palm Tungsten E2 Handheld
I own a Palm Tungsten E2 when I go to hot sync I get an error message that states the connection between your device and desktop could be established please check your setup and try again
1. Go to your desktop program
2. Go to top and select HOTSYNCH
3. Select Set Up
4. Select the port your E2 is attached to
5. Theres more but I need to know how you are to this point or go to live tech support and ask for Just_Bobz
Sep 24, 2008 | Palm Tungsten E2 Handheld
HotSync error ((sys 0505) (0,841)
I also had this problem. Searched for a solution and found that the error message refers to older programs incompatible with newer models of the palm. If you do a Hot Sync on a different and/or newer model palm device there may be these incompatibilities. The usual problem programs are mypalm and mytreo. You need to delete them by
first doing a Hot Sync
going to Applications on the palm
tap on the menu icon (or the left upper corner of the display)
tap on Delete
go down the list to delete each of these programs.
Hot Sync problems should stop
If not, you need to do a hard reset and then slowly add third-party software one by one and look for problems.
Jun 23, 2008 | Palm TX Handheld
Error message using IrComm port
Hi, Right click on hotsync manager at the bottom right corner of the pc , make sure only local serial and ir is having a check mark , if anything else has check mark , just go to that and do a left click , it will get unchecked . On the handheld tap on home , on the main page u will see hotsync icon , tap on that , on the hotsync page make sure via ir , and not cradle or cable , then at the top u will see hotsync in words , tap on that , in the drop down u will see lan sync pref, tap on that and make sure lan sync is highlighted , and not local hot sync , since local hotsync is usefull only when u perform cradle or cable hot sync using usb , then click on ok , try a hotsync . If this doesnt help and again u get the same error , do a soft reset on the handheld and on the pc , go into hotsync manager , click on setup , choose local , change the com port to a different port and reduce the speed to 9600 , click on ok restart the pc and again perform a hotsync . The error u got was coz of this , on ur pc a ir port is not been assigned .. Try this it should work .. Regards
Sep 11, 2005 | Palm Tungsten T3 Handheld
Cannot hoysync with outlook 2003
After installing, reinstalling, deleting, hard resets, hitting head against wall... I tried installing the Pocket Mirror conduit as a last ditch effort. An error message popped up saying it could not find the mapi32.dll file. I looked at another PC, located that file in the windows32 directory, copied it to my PC, and I was able to hotsync with Outlook. To test this, I uninstalled the Pocket Mirror and Palm desktop SW, then deleted the mapi32.dll. Installed the Palm 4.1.4 sw, outlook 101 update, plus the conduit update, had same error messages. Added the mapi32.dll to the windows32 directory - was able to successfully sync with Outlook!
Sep 11, 2005 | Palm Tungsten E Handheld
Computers & Internet Logo
David Payne
David Payne
