Firmware upgrade failure
I followed the instructions to upgrade the firmware on my DVR recorder. At the end of the upgrade process both the on screen instructions and the paper instructions told me to hold down the power button until the unit went off. The paper instructions said then the unit would display "wait" until it was done updating, then the disc tray would close. Neither the "wait" instruction ever appeared, nor did the tray close. The unit is now inoperative, any ideas on how I might be able to make it operative again?
  • 12 more comments
  • dcalhoon Oct 12, 2008
    I have unplugged it and it does not restart. The unit I have is a Toshiba RD-KX50SU, DVR with a hard drive disk.
    Tried disconnecting the hard drive, and nothing has changed. I do not think I included the fact that the power light comes on, but it will not go any further than that. I cannot get it to access the DVD/recorder or the hard drive, or any screen menus, nothing works except the clock and the power on/off light at the power switch.
    How do I get the upgrade restarted since the tray is closed, and it would not close to restart the upgrade process. I also do not understand how the upgrade was interrupted since I followed the on screen directions as well as the printed directions
  • dcalhoon Oct 13, 2008
    I talked with someone at Toshiba today, who told me the firmware is on the hard drive of the unit. What I was thinking of doing was reformatting the drive with a computer and trying to install the firmware again through the computer. Does anyone have experience with doing this? Will it work? Any ideas are cheaper than the "official" service center's $140 charge to make this work again
    These solutions all seem to require the machine to be operational. This machine will only power up and the clock works. Need a fix that does not require an operating machine
    The issue does not have anything to do with the mechanical opening of the tray, the firmware update caused the malfunction.
  • dcalhoon Oct 14, 2008
    I cannot install the firmware to the machine since it doesn't operate. I removed the hard drive and put it on my computer, the computer recognized the drive, but windows did not recognize the drive to assign it a drive letter. Since windows did not recognize it I could not format it in windows. Should I maybe download a Seagate tool to reformat it, and will that make the machine work?
    These two sites do not have any kind of firmware update for my machine. Seagate support does not know anything to tell me.
    The qualified technician is not close to me, must send it to Massachusetts. They also want $140 to get it to work, not spending that on a firmware update that they caused.
    Which is the processor board? Is it the one with the main power and fuse in it? More information appreciated
  • tlyons2ton Nov 28, 2008
    Memorx mvdr2102 dvd tray stuck half open, will not close or open? What can I do. Ted
  • Clevor Mar 21, 2009
    I had the same problem with my RD-XS52. Toshiba refused to fix the problem at no cost, referring me to Tops Electronics for a $143 repair fee. But I am at an FPO AP address overseas and freight both ways to MA will cost me $50-100!!! Can you tell me how you resolved this issue? My unit is still broken: locks up randomly, loses audio, although it does turn on, but it was working flawlessly for 3-4 years until I did the firmware upgrade. I am really upset about this and about how Toshiba refuses to accept responsibility. Really terrible customer service!
    Brigadier General:
  • 6,966 Answers
If I may add...
As the Toshiba support explained, the Operating System is stored in the hard drive (or part of it). To my knowledge, once the unit is powered ON, then said OS is transferred to the random access memory which the built-in processor uses. Treat it like a computer, In a computer this would call for a clean/fresh install. Unfortunately, it does not use DOS or Windows based partition and format since it is a "non standard" drive formats. From this, very limited options:
  • send the unit back for re-programming/loading of the OS to Toshiba, Call 1-800-631-3811 or 1-800-319-6684;
  • reference this site. try procedures for the KX50SU which includes the Seagate utilities;
  • borrow an existing/operational unit and clone the HD though there are some challenges. Pls reference this thread. It is for another model with similar features.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 14, 2008
  • 899 Answers
If you no longer have function to the menu , the door will not open or close , hard drive power not comming on , video output missing to the tv , then power is missing to those boards and a fuse or pr has burnt out or the power transformer is not supplying power out of those wire windings for that part of the system.
if the software did not stall properly , the process board will lock up and cause problems. there may be a set of reset pins on the processing board , if not then unplugging the data and power lines will reset the board ( capacitors still holding energy ) .
but if there is a power problem to those boards then the power circut will need testing or even replacement of the processing board!
do not try to use the computer to re format this kind of a hard drive!!!
  • 2 more comments
  • jason Oct 14, 2008
    looking from the front of the device the main processing board is in the middle area and has alot of on board chips plus one lager chip ( the main processor )
    the transformer board converts and purifys the ac power to dc power
    also if you see a little battery on the board then that will have to be unsoldered to reset the board
    can you upload a pic?
    the main power board with the fuse converts the ac power into dc power then it purifys and divides power to the different boards.
    the main processor board will be hooked up to the dvd drive and the hard drive and the video ouput board plus the display panel in front
    the power plugs on the hard drive , dvd drive are set up like this:
    black = ground
    red = 5v dc
    yellow = 12v dc
    for testing power output
    Scholar:
  • 136 Answers
    Genius:
  • 1,124 Answers
Holding down the button ON/Standby for a 10 seconds force to DVR to turn off the power. This action could cause several damage to your disks or data. However the unit must be re-starting normally after that with no problems (not in your case) or the unit in another cases after that action re-inicialize your HDD.
In your case the update obviusly was not completed (causing some internal conflict in your unit) or you could be skiping some steps during the updating process. At this point the unit must be reseted. Unplug the unit during at least 3 hours and try again. If still doesn't work need to be serviced.
Posted on Oct 13, 2008
    Sergeant:
  • 352 Answers
Additional Information Requested:
Make and model of dvr?
What version firmware did you upgrade with?
What site did you download from? The reason I ask this question is depending on what country you live will determine the type or version that will work with your specific model. You can post your response straight to me by choosing find experts.
anaanymous
Posted on Oct 12, 2008
  • anaanymous Oct 12, 2008
    p.s. I realize you have the install cd, and it didn't work, so I figure this couldn't hurt either, Good luck.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Hi can u reset ? if not remove your hard disk & power it or you press hold on the power & plug to mains .if it oprate now you can off it & fix your hard disk & power on again .
  • 19,396 Answers
If firmware upgrading has finished (ensure it) , try unplugging power cord and connecting it back. See if it restarts.
  • Ginko
    Ginko Oct 12, 2008
    That is because the upgrade procedure was interrupted.
    You need to restart the unit with an upgrade disk inside, the problem is that image disk are only provided to Toshiba authorized repairer.
    The unit is at this point faulty, you will have to decide if calling the number listed on the owner manual, and get details about repair service, guaranty, and ask information on eventual extended guaranty if provided.
  • Ginko
    Ginko Oct 14, 2008
    There is no processor board, that is called the main PCB.
    The problem is that the software/firmware on your unit is corrupted. Call back toshiba and ask them a bootable disk to reinstall the software image onto your unit, that is all.
  • 171 Answers
AREN'T THESE GUYS GREAT. LAME.
It pays to read the directions, completely.
DO NOT UNPLUG, TURN OFF, OR USE ANY OTHER FEATURE OF YOUR PLAYER DURING THE FIRMWARE UPDATE PROCESS. Doing so will cause the writing of the firmware update to the player to be halted and the player may no longer operate properly. If the player stops working, please contact Toshiba Customer Solutions at 1-800-319-6684 or HD-DVD Concierge at 1-888-MYHDDVD(1-888-694-3383).
  • 2 more comments
  • Todd Gale
    Todd Gale Oct 14, 2008
    Ginko, wrong, she was sent the disk you moron.
    anaanymous - You are totally clueless, stop acting like you know anything, you don't.
    PABLOCSA - What happens in three hours that would not happen now, you may grow a brain?
    ready2helpu - Your answers are inappropriate and you need to not come back here. Should you, I will have you removed, permanently.
    You guys are going to be liable for a lawsuit real soon as you are advising people incorrectly about how they can utuilize these drives in their systems, so stop it. This is not a Windows or Unix based drive and telling a client they can use it or at least fix it in their computer without some understanding of assembly l,anguage is irresponsible and dangerous. So, stop acting like you know it all and help people you can help. Last time I tell you this.
  • Todd Gale
    Nick, you make me laugh, your the pro. Dude, stop fronten. You are the biggest BS'er on the service and we have had many talks about much you BS, that would be Lauren and I. Dude, do your self a favor, stop trying ot act like you are mor ethan a 35 year old flunkie who can't make a living at anything else. Thank god you have your mothers basement to live in.
  • Todd Gale
    First of all, Nick, you have already instructed her t odo the worng thing. I am not going to pick up the pieces of your failed attempts at trying to remedy this by pulling the hard drive, as opposed to the obvious solution, which is to slide the DVR drive slightly out of the chassis as to allow the disk to be put in, once that is completed, the system will actually boot to the Firmware DVR and fix itself, which is how this needs to be fixed. No other way will you get this problem done. Sorry, but it is true. I sent her to Toshiba, because you guys have already caused enough damage and she is frustrated and just wants the unit fixed, not you geussing at her expense. Good Enough.
  • Todd Gale
    Good luck Nick, you are done.
    Sergeant:
    Champion:
  • 334 Answers
Hey when u stick that drive to windows is the jumper set at slave not master on ide cable u must do this 1st then windows will see it then u can formatt iit ok bud
  • 13 more comments
  • nick helpap
    nick helpap Oct 14, 2008
    end if ide cable that drive is master with jumper pin on back hard drive ok middle of ide cable u must set hard drive to slave on jumper pin if it dint come with pin use one off older or other coputers hard drive one that cover up 2 litte pins on back of hard drive ok u nee dto do this 1st get that right so windows sees it ok then u can formatt it
  • nick helpap
    set jumpers on hard drive one u pulled out to slave sl meens slave ma meens master over 2 pins with platsic jumper like your other hard drive has ok then u can do quick formatt in my computer u will see it and windows will install it ok try this 1st still nowt get back with me i have more ideas
  • nick helpap
    DRUMMERNICK2002@AOL.COM NICK_HELPAP ON YAHOO MSG AIM-DRUMMERNICK2002 ADD ME I CAN HELP U THROW ONE THOSE CHATS IF U NEED ME BUT THIS WHAT U GOTTA DO GOTTA GET JUMPER ON HARD DRIVE U PULED TO SLAVE WHEN U STICK IT IN YOUR COMPUTER OK
  • nick helpap
    YES U CAN US ETHIS IN YOUR COMPUTER IF ITS IDE REG HARD DRIVE SURE CAN USE IT JUST NEED JUMPER RIGHT BOSS K GET WITH ME
  • nick helpap
    NTFS QUICK FORMATT U CAN DO IS THERE STANDERD WHEN U BOOT IT BACK IN DVDR IT WILL REDO IT WITH NEW FIRM WARE U DID
  • nick helpap
    HEY TODD YUR SUPPED TO BE THE PRO MAN WHATS UP WITH SENDING HER OFF ON # WHEN SHE PAID US TO FIX GET LOSE TODDG
  • nick helpap
    HEY TOODG YOUR LAMEST ONE SENDING HER OFF TO SUPORT WHEN WERE THE PROS U DORK HOW ABOUT U STAY OFF POST U CANT FIX RATHER THEN COPY PASTE FORM GOOLE OK THX FIX YA
  • nick helpap
    DUDE LOL THIS IS A SEAGATE IDE REG HARD DRIVE GO READ UP ON THIS UNIT YOUR DUMBEST KID EVER LOL
  • nick helpap
    YTOUR NUTS LOL IM 29 YRS OLD RUN GREAT COMPUTER BUSSNESS LOL HELP PP ON SIDE ON HERE YOUR OUTTA CONTROL U NEE DTO GET OFF FIX YUR LAME *** SEND PP SERV CENTER # NO **** SHE KNOWS TO CALL THAT THIS REG DAM DRIVE GET JUMPER RIGHT FORMAT THAT TO NTFC WHAT IT SAYS IT IS LOAD BACK IN REBOOT BIOS IT WILL OR U CAN DROP PARTIONS CLEAN IN WINDOWS SEAGATE TOOLS HAVE DRY PARTION OK THEN SHE CAN LET DVR FORMATT IT WAY IT WANTS LIKE NEW MACHINE U NEED GET LIFE DUDE BIGGEST LOSER ON HERE TOODG GO HELL AWAY MAN LOSER U DONT SEND PP OFF TO SERV CENTER WHEN WE HELP SO SHUT STFU
  • nick helpap
    U AND I DONT CARE ABOUT WHO U TALK ABOUT THATS ALL U GOTTO DO TALK ABOUT PP NOT HELP SEND PP SERVICE # S HOPING U GET SUM YOUR LOSER MAN SHOULD TEACH YA LESSON
  • nick helpap
    DUDE I DONE IT BEFORE SHE HAS THE RIGHT IDEA U JUST DONT WANN TRY **** OK I GET MY HANDS DIRTY SHE CAN TRY BLANK PARTION COREPPED HARD DRIVE SYSTEM FREAKS OUT SO YA SHE CAN TRY THIS BEFOR EPAYING 140 U DUMB ASSS STAY OIUTTA HERE
  • nick helpap
    YOUR DONE U STUPID SOB KISS MY *** U DONT KNOW WTF YOUR TALKING ABOUT OK TOODG YOUR MORON
  • nick helpap
    dcalhoon SORRY ABOUT TOODG DONT LISTING TO TIS LOSER TERIST ******* OK JUST SENDS PP OFF TO SERVCIE CENTER NO HELP IS IT U WER EON RIGHT TRACK JUST IGNORE WHAT HE SAYS
  • nick helpap
    could also buy new hard drive for it also read old one get sumthing simlery
  • nick helpap
    thats why she can stick har drive in computer like she said on mater or slave the del partions on it make new ones but dont formattt le dvr formattt it to what it wants simple as that
    Scholar:
  • 142 Answers
If your computer recognizes the Seagate drive in the setup menu you can format the drive using DOS.
But, I agree with "Ginko"... ask Toshiba for warranty repair due to "special circumstances". I worked in a Sony Authorized Service Center for many years and in circumstances like yours they readily provided it because they didn't want to lose a single customer. Sony would send a Letter of Authorization to the customer and the person would bring their unit to us for a "one-time" warranty repair. Call Toshiba and threaten to "Never buy another Toshiba product the rest of your life!". That should do it...If not...too bad for Toshiba! I wish you good luck!
barneyluc
    Genius:
  • 1,913 Answers
    Top Expert:
  • Televison & ... Master
  • 68,097 Answers
You missed a step, try again to install firmware, take your time read and make yourself familiar with the instructions before you start.
  • yadayada
    yadayada Oct 14, 2008
    I think you should have a qualified technician fix it, you may cause a further problem with hard drive.
  • yadayada
    Try our live chat session for this problem, that way you can fully explain what is the problem in real time and get answers in real time, it is well worth it, request a refund for the premium session.
  • 2,071 Answers
If for some reason you would opt for user performed action, then pls try: 1. reset, unplug from the mains for at least 4 - 6 hour and try it again; 2. check if there is a slide switch of some sort at the rear of the unit; 3. check if there may be a pinhole somewhere along the bottom of the loading tray where a blunted point safety pin maybe inserted; 4. Unplug and open the top cover and move the gears manually to open and leave the tray in eject or open position and plug it on,try to see if the tray is closed it back and working. 5. check internally if there is a mechanical problem such as a slipping/cut belt, gears that do not mesh correctly; 6. if the unit has been in use for some time, it may simply need cleaning and re-application of lubricant in the mechanical assembly. The slider mechanism, depending on the age of the unit and , consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn?t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There?s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also. Hope this may help; Regards, VOTIT
I had a new dvr added to my TWC cable services,but installer did not totally explain how to record or find recordings after taping. Can anybody tell me how to remedy this problem?
http://www.timewarnercable.com/en/support/faqs/faqs-tv/on-screeng/iguide/how-do-i-record-a-show-using-m.html
How do I record a show using my DVR and i-Guide?
There are multiple ways to do this:
  1. Press the RECORD button on your remote control while watching a program to begin recording. An overlay will appear on your screen to let you know you have started recording.
  2. From the TV listings grid, highlight the show you want to record and press the Record button.
  3. From any program information screen, highlight the Record icon and press the OK/Select button on your remote to schedule a recording. Follow the on-screen prompts for additional recording options.
Manually schedule a recording for a specific time or channel:
  1. Press the MENU button on your remote control then select the DVR icon.
  2. Or, if available, press the My DVR button on your remote control.
  3. Select the start time, end time and day that you want to record.
  4. Press Confirm.
  5. In the channel list that appears, select the channel to record from.
  6. Select Record to confirm your settings or select Recording Options for additional options.
and:
Video:
How to video DVR
Jul 12, 2016 | Televison & Video
D3 will not show option to do firmware upgrade from 1.0 to 2.02
Copy just the AD3_0202.BIN file to the top level of a formatted CF card. Insert the card and select Firmware from the Setup menu.
Repeat the process using just the BD3_0202.BIN file.
Full instructions are here.
Oct 23, 2012 | Nikon D3 Digital Camera
La impresora 4345mfp se bloquea y nose como hacer la actualizacion del firdware.
Upgrading the firmware
The MFP has remote firmware update (RFU) capability. Use the information in this section to
upgrade the MFP firmware. The overall process involves the following steps:
1 Determine the current level of firmware that is installed on the MFP.
2 Go to the HP Web site and find out whether a firmware update is available. If an update is
available, download the latest firmware to your computer.
3 Transfer the new firmware from your computer to the MFP.
Determining the current level of firmware
To determine the current level of firmware, view the configuration information on the MFP control panel. To view the configuration information, follow these instructions.
1 Press MENU.
2 Touch INFORMATION.
3 Touch PRINT CONFIGURATION. The configuration page prints.
4 The firmware datecode is listed in the section called Device Information. The firmware
datecode has this format: YYYYMMDD XX.XXX.X. The first string of numbers is the date, where
YYYY represents the year, MM represents the month, and DD represents the date. For example, a firmware datecode of that begins with 20040225 represents February 25, 2004.
Downloading the new firmware from the HP Web site
To find the most recent firmware upgrade for the MFP, go to www.hp.com/go/lj4345mfp_software.
This page provides instructions for downloading the new firmware version.
Transferring the new firmware to the MFP
Use one of the following methods to update the firmware.
Using FTP to upgrade the firmware on a network connection
NOTE The MFP can receive an .RFU file update as long as it is in a "ready" state.
The elapsed time for an update depends on the I/O transfer time, as well as the time that it takes for the MFP to reinitialize. The I/O transfer time depends on a number of things, including the speed of the host computer that is sending the update. If the remote firmware update process is interrupted before the firmware is downloaded (while Receiving Upgrade appears on the control-panel display), the firmware file must be sent again. If power is lost during the flash DIMM update (while the Performing Upgrade message appears on the control-panel display), the update is interrupted and the message Resend Upgrade appears (in English only) on the control-panel display. In this case, you must send the upgrade by using the parallel port. Finally, any jobs that are ahead of the RFU job in the queue are completed before the update is processed.
Follow these instructions to perform the upgrade by using FTP.
To upgrade the firmware on a network connection by using FTP
1 Take note of the IP address on the HP Jetdirect page. The HP Jetdirect page is the second page that prints when you print the configuration page.
NOTE Before upgrading the firmware, make sure that the MFP is not in Sleep mode.
Also make sure that any error messages are cleared from the control-panel display.
2 Open an MS-DOS command prompt on your computer.
3 Type: ftp <TCP/IP ADDRESS>. For example, if the TCP/IP address is 192.168.0.90, type ftp
192.168.0.90.
4 Press Enter on the keyboard.
5 When prompted for the user name, press Enter.
6 When prompted for the password, press Enter.
7 Type bin at the command prompt.
8 Press Enter. The message 200 Types set to I, Using binary mode to transfer files appears in
the command window.
9 Type put <filename> where <filename> is the name of the .RFU file that was downloaded
from the Web, including the path. For example, type put C:\LJ\4345FW.RFU, and then press
Enter.
NOTE If the file name or path includes a space, you must enclose the file name or path
in quotation marks. For example, type put "C:\MY DOCUMENTS\LJ\4345FW.RFU"
The following series of messages appears in the command window:
? 200 PORT command successful
? 150 Opening BINARY mode data connection
? 226 Ready
? 226 Processing Job
? 226 Transfer complete
Then, a message that contains the transfer-speed information appears.
10 The download process begins and the firmware is updated on the MFP. This can take
approximately five minutes. Let the process finish without further interaction with the MFP or
computer.
NOTE The MFP automatically turns off and then on again after processing the upgrade.
11 At the command prompt, type: bye to exit the ftp command.
12 At the command prompt, type: exit to return to the Windows interface.
Using MS-DOS commands to upgrade the firmware
To update the firmware by using a network connection, follow these instructions.
1 From a command prompt or in an MS-DOS window, type the following: copy /B <FILENAME>
\\<COMPUTERNAME>\<SHARENAME>, where <FILENAME> is the name of the .RFU file
(including the path), <COMPUTERNAME> is the name of the computer from which the MFP is
being shared, and <SHARENAME> is the MFP share name. For example: C:\>copy /b C:
\9200fW.RFU \\YOUR_SERVER\YOUR_COMPUTER.
in quotation marks. For example, type: C:\>copy /b "C:\MY DOCUMENTS\3500FW.RFU" \\YOUR_SERVER\YOUR_COMPUTER.
2 Press Enter on the keyboard. The control panel shows a message that indicates the progress of the firmware upgrade. At the end of the upgrade process, the control panel shows the Ready
message . The message 1 file(s) copied appears on the computer screen.
Jul 15, 2011 | HP LaserJet 4345mfp Printer
Getting firmware problem and can not use mp3 player how do you reinstall firmware
  • To install this firmware update, do the following:
    1. Download the ZenMicroP4S_PCFW_L16_2_21_02.exe file into your local hard disk.
    2. Connect the player to your computer.
    3. Double-click the firmware upgrade file and follow the instructions on the screen.
  • If a dialog box appears, telling you that an application is interfering with the update process, do the following:
    1. Launch Creative MediaSource Player/Organizer.
    2. Click Tools -> Settings.
    3. Click the Detector tab.
    4. In the Device(s) to Detect window, make sure that the Enable Detector checkbox is not selected.
    5. Restart your computer.
    6. Install the firmware update again.
Apr 06, 2011 | Creative Labs Zen Digital Media Player
I have tried downloading from the samsung website lastest firmware update, which is an iso file when extracted it saves it to disc as a xuf file and the blu ray wont read this what am i doing wrong??
Read the Upgrade Guide (PDF) for instructions on how to do this. It says to burn a CD. The ZIP file extracts to ISO type. The guide tells you what format it needs.
http://www.samsung.com/us/support/search/supportSearchModelResult.do?menu=SP00&searchWord=bdp1400&searchInputBox=bd-p1400&find_button=
READ the PDF file under Upgrade Guide. Make sure you designate the proper file type when burning CD. Check your burning software.
How to make a firmware update CD
Please follow the below procedures.
1 Download the new firmware file from www.samsung.com
2 If the firmware file is compressed (*.zip), the file should be uncompressed to CD image file
(*.iso).
3 Please burn the CD image file on a blank CD-R/RW disc
1) Recommended CD Burning Program is Nero Burning ROM.
2) Burning Options (in case of using Nero Burning ROM)
A. ‘Recorder’ menu ?? ‘Burn Image…’ ?? Select an uncompressed image file(*.iso)
B. Please check ‘Finalize CD (No further writhing possible!)’
C. Please refer to your own CD burning Program Manual if you want to use any other
CD burning program for burning ISO image file.
D. Make sure if the downloaded software is eligible for your BD-P1400.
E. The System Upgrade will not be executed if using the update CD made with NOT
following the upper procedures.
Warning
The following events may interrupt the upgrade process and MAY RESULT IN PERMANENT
DAMAGE TO THE UNIT WHILE UPGRADING.
1. Unplugging the power plug
2. Power outage
3. Dirt or scratches on the burned CD-R/RW disc
4. Closing or opening a disc tray during update processing
How to upgrade the BD-P1400
1. Press OPEN/CLOSE button to open the disc tray.
2. Insert the upgrade CD.
3. Press OPEN/CLOSE button to close the disc tray.
4. Please wait about 6 minutes while verifying.
Verifying Firmware Version.
5. When below message box comes up, please check the date of the Firmware version.
Do you want to update Firmware?
>Current Version : 070730.02_XAA
>New Version : 070903.01_XAA
Yes No
6. Press ‘Enter’ button to choose ‘Yes’ for upgrade and please remove the disc on the tray.
If you select ‘No’, BD-P1400 will be automatically powered off.
If you don’t see above message box, try another disc. Generally, this is caused by disc
quality or a disc creation problem.
7. Please wait for about 7 minutes.
Firmware Update.
Now, Processing…
Please, do not turn off the power.
8. When finished, the screen and the power will turn off automatically.
9. Turn on the unit again. The tray will close automatically. Below screen will show up. Please
select the language you want with a corresponding number button.
MENU LANGUAGE SELECTION
Press 1 for English
Pulsar 2 para Español
Touche 3 pour Français
Macrovision : BSS01
10. If you want to do System Upgrade through the network, please refer to ‘System Upgrade’
Article on the User’s Manual.
Aug 18, 2010 | Samsung BD-P1400 Blu-Ray Player
I have a US Robotics usr5461 wireless router. It
You might want to check your firmware version to make sure you have the lastest.
BETA Firmware Version 3.93.35.0.9This firmware fixes the following issues:
  • Printing issues with CUPS version 1.2.
USR5461a-v4.3.93.35.09.usr 1.8 MB 06-05-08
Firmware Version 3.93.35.0.8This firmware fixes the following issues:
  • DST (Daylight Saving time) Firewall issue with how IAC (Internet Access Control) works.
  • PPPoE server disconnect/reconnect
  • PPPoE inactivity timer
  • PPTP client disconnect/reconnect
  • backup/restore settings
Note: If upgrading from Version 3.91.37.0.3, follow these instructions before proceeding.
  1. With a thin tool, such as a paper clip, briefly press the RESET button on the back of the router.
  2. Wait about 30 seconds.
  3. Continue with instructions below.
Important: To ensure a successful upgrade, please perform the firmware upgrade from a client that is physically wired to the router. A wireless client may become disassociated from the router during the upgrade process resulting in an incomplete upgrade.
  1. Download this file to a temporary location on your computer's hard disk drive.
  2. To upgrade your USRobotics Wireless MAXg Router with all operating systems, open an Internet browser and enter the router's IP address. The default IP address of the router is 192.168.2.1
  3. Enter your User name and Password. Click OK.
  4. Click Device in the main menu.
  5. Under the "Upgrade Router" section, enter the location of the USR5461-v3.93.35.0.8.usr file in the text box, or click the Browse button to search for the file. Then click the Upgrade button to begin the upgrade process.
  6. When the upgrade process is complete, the router will reboot. To re-establish a connection with your router, wait approximately 15 seconds and click Continue.
USR5461-v3.93.35.0.8.usr 1.8 MB 10-25-06
Dec 31, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
Nextar ma852-801 mp3 freezing...reset?
Hi.
Welcome To Fixya Community.
Solution 1:
  • Try to Turn it ON/OFF(Reset).
If that isn't Working try This:
Solution 2:
  • You are going to upgrade the Firmware of your Mp3 Player in order to perform that follow these Steps:
  • Installation of the Upgrade Tool:
  1. Download the Upgrade Tool application (the download link is in the bottom of this Solution) to your computer.Double click the application.Follow the instructions shown on the screen to complete the installation.Firmware Upgrade:Note: All the existing files in the player will be erased while upgrading,please make a copy of your files before doing this.Turn on MA852-801 player. Press and hold the MENU button todisplay the main menu. Select “Settings” → “System” →“Upgrade” and press the MENU button to confirm. Select “Yes”and then connect the device to a computer via USB interface once you see the following window:
2. Select ”Program files” 􀃆 ”Firmware Update” from the Start
menu or double click the “Firmware Update” icon on the
desktop. You will see the following window shown on the
screen:
6fc021c.jpg***************************************************************************************
3. Click Open button, and specify the upgrading firmware with
the extension “ .rfw ” (Please download the firmware from
Nextar website named MA852-801 – updated firmware.rfw).
Click Update button to start upgrading.
Note: This process may take about 2 minutes depending on the
computer system you use. Please don’t disconnect while upgrading,
it may cause serious damage to the player.
4. Once it shows "Firmware update successful"wording in
“Update Info” window, then click Exit button to finish
upgrading.
*************************************************************************************(5) 5. Safely remove the player from the PC.
6. Turn on the player. Please wait about 20 seconds for the
player to automatically initialize settings.
Downloads:
Upgrade Tool.
Firmware File.
Additional Help:
Nextar Ma852-801 Mp3 Player Manual Guide.
please don't hesitate asking me if you need any Further Info.
Thank You For Using Fixya.
Good Luck.
Nov 04, 2009 | Audio Players & Recorders
Hello! I have a RC79T and I cannot record one of my cable channels. It is the national grograhic channel. everytime I try to record it get a pop up and says that this is copy right program, cannot be...
I have the same problem with FX. I e-mailed LG customer service and recieved this response,
We’ll be glad to assist you with this situation. A firmware upgrade will be required in order to correct the problem that you are experiencing.
Please reply this email with the following information:
Model number
Serial Number
Date of Purchase: 09/13/09
Firmware/Software version of the unit
Physicall address to send you the firmware upgrade
To get the Firmware/Software version of the unit try the following steps:
1.Select TV Aspect from the Setup Menu.
2.Highlight the 16:9 Option
3.Type in the code 1397139.
4.The System Information Screen will appear.
From this screen ask the customer to read
the current Firmware/Software version of the
unit.
Once we have all the product information we will be sending you a firmware upgrade, that will solve the issue that your unit has. I replied to the E-mail and now awaiting the arrivial of a disc with the firmware upgrade. Hope this gives you a starting please.
Aug 11, 2009 | LG RC897T DVD Recorder/VCR Combo
I am trying to find a firmware update for my Ellion DVR-515A.
HI
GO TO THE ELLION WEBSITE AND DOWNLOAD THE UK FIRMWARE ONTO CD. PUT IT IN THE MACHINE FOLLOW THE ON SCREEN INSTRUCTIONS AND IT WILL PROBABLY RECORD FROM ANY DISC MANUFACTURER. "THIS IS NOT ESSENTIAL UNLESS YOU WANT TO RECORD UNBRANDED DISCS"....ALSO THE THE MULTI REGION CODE IS AS FOLLOWS. TURN ON THE MACHINE WITH NO DISC, WAIT UNTIL THE DISPLAY READS "NO DISC" THEN PRESS 7 TWICE ON THE REMOTE CONTROL. REGION 0 SHOULD THEN BE DISPLAYED ON THE TV. PRESS ENTER, THEN OPEN TRAY AND PUT ANY DISC IN. IT WILL NOW PLAY ANY REGION.
HERE IS THE ELLION WEBSITE WHERE YOU CAN DOWNLOAD THE FIRMWARE>>>>>>>
http://www.elliondigital.com/eng/product02.html
GOOD LUCK (OPPS CAPS ARE ON LOL)
Jul 14, 2009 | Televison & Video
Cyberhome DVR 1600, where can I get the firmware update
Hi there
The best bet now the company has gone bust is trawl through the forums to see in anyone has a firmware upgrade saved and available for download. Here is a good start.
http://www.avforums.com/forums/index.php
Good luck and thanks for using Fixya!!
Feb 19, 2009 | Cyberhome DVD Recorder - DVR1600
Televison & Video Logo
1,418 people viewed this question
Top Televison & Video Experts
Electro Med Services...
