Question about Canon Office Equipment & Supplies
My canon pc 425 copier = paper is not feeding
2 Suggested Answers
  • 186 Answers
SOURCE: canon d660 laser copier
Open doc feeder cover and try cleaning all rubber rollers and pads with alcohol.
Posted on Jan 17, 2008
  • 566 Answers
SOURCE: my canon printer/copier does not feed paper in
1. Try cleaning the paper feed rollers
Instructions how to clean the paper feed rollers.
If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the Printers folder.
    - For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
    - For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
    - For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
    - For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
  2. Right-click the icon of the printer for paper feed roller cleaning, and select 'Properties' from the displayed list.
  3. Click the 'Maintenance' tab and click 'Roller Cleaning'.
    Remove all sheets of paper from the rear tray, then click 'OK'.
  4. Confirm the message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
  5. Confirm the message, and click 'OK'.
    After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  6. Confirm the message, and click 'OK'.
    Note: “Feed roller cleaning is completed” message is displayed when the paper is fed and ejected.
    Click 'OK'.
Roller Cleaning is completed.
Posted on Sep 06, 2009
How do you take out the registration roller to replace the roller guide? Canon pc-425 fb2-9596-000
You have to take off the top cover. There are tabs all around the outside and there are two tabs on the inside one is on the left under the cover where you insert the paper the other is on the right right before the white lever. I will try to post photos.
Feb 11, 2011 | Canon PC-425 Color Copier
I have a Canon PC425 copier which pulls the paper in part way, and then says it has a paper jam. There is no jam, and repeated switching on and off gives the same result. Is there a fix for this?
I have same problem, but I order spring and new bushing, but I am unable to free side by the gears so I can replace bushing. Were you able to fix this problem?
Oct 17, 2010 | Canon PC-425 Color Copier
Canon pc 940 no paper pick up and a signal of P in the display panel
You may have a blockage in the paper feed path, or a worn out paper feed roller, or a faulty paper feed drive clutch / drive mechanism.
Can you see if the paper feed roller rotates in contact with the paper?
Are you using plain paper?
Dec 07, 2009 | Canon Office Equipment & Supplies
Paper jams - we got copied from mom that passed away - no manual. We don't know what the symbols mean. Trying to score a manual but immediate problem is that paper stops feeding. Error message says there's...
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=336&modelid=1936
Unfortunately, I can't direct you where to score a manual either. The jam in this case means that paper did not travel far enough into the copier within the correct amount of time. It is possible to clean the feed roller, (with enough patience) I suggest using IPA (rubbing alcohol). Hope this helps.
Aug 06, 2009 | Canon PC-425 Color Copier
Canon Pc 25 not pulling paper completely through from tray or from manual feed tray.
hi,clean feedrolls & paper transportation.clear any misfeed sheet in paper supply section.send me result.
thank you.
May 28, 2009 | Office Equipment & Supplies
Canon pc 420 paper feeds only part way
I had the same problem. I found a parts diagram here http://techno-parts.org/canon/220/320_220.php which showed that the springs hold the bar down. On mine, on each side, one of the spring tabs was broken.
I made a metal pin for one side and insert a screw on the other. Be sure and wrap the spring over the nylon bushing.
May 26, 2009 | Canon PC-420 Copier
Paper will not feed from drawer
Pull the paper tray out of the machine. On the right side underneath you should see a rubber paper feed roller. Clean this off with a slightly damp cloth until it is "squeaky clean". Also, look about to be sure there is nothing blocking the paper path. Sometimes paper gets torn off and left in the machine when clearing a jam.
Apr 21, 2009 | Canon PC-941 Copier
I'm suddenly getting uniform black lines on copies when using my canon pc 425 monochrome personal copier
remove toner cartridge, and look at the drum (on the bottom of cartridge). If there are toner streaks on it, it is failing and needs to be replaced.
*please rate me :)
Mar 26, 2009 | Canon PC-425 Color Copier
52 people viewed this question
old marine
old marine
Corne Viljoen
