Question about Motorola Mobility RAZR V3x Cellular Phone
V3X My phone wont come on. Was working fine till I foolishly tried to remove sim card without turning phone off or even removing battery. When pressed to turn on it lights up for one second and nothing else. It wont take charge either but I no there is enough life in the battery. Can you help.Many thanks My email add is: mn2986@msn.com
    Novelist:
  • 111 Answers
Hi Bilkow..
In attempting to remove the SIM card without removal of the battery you could have potentially broken an electrical link in the main circuitary or caused a fault within the battery compartment.
i would suggest checking out the Motorolla website to see if there are any FAQ's or solutions for you there. if the problem persists, i would contact your Mobile carrier for assisstance.
hope this helps
Posted on Oct 27, 2008
The unlock switch wont work so i can look at anything of my nokia nuron
First switch off the phone then remove battery and sim card and memory card. then turn on the phone without this. try to lock.if it again unables to lock then insert the sim card, memory card and battery.
May 04, 2011 | Nokia 5230 Cell Phone
My sony ericsson vivaz is not sending text messages..my sim card is working..
Please try to check the SMS network configuration settings of your phone through your Service Provider. They need to reconfigure your account to activate this feature on the phone.
If this seems to be fine, then try the following:
1) Go to your outbox and cancel sending the message. It should have an X on it or something.
2) Take out your battery without turning it off first.
3) Remove your SIM card and put your battery back in.
4) Boot your phone back up without the SIM card.
5) After it boots all the way up, remove the battery again without turning your phone off.
6) Put your SIM card and battery back in and turn your phone back on.
7) Go to your outbox and delete your canceled message(dont try sending it again).
May 01, 2011 | Sony Ericsson Vivaz Cell Phone
My phone shows "please insert
You could try to remove your sim card.
Install battery and turn on phone without sim card.
Use phone without sim card and do some operations.
This will check if you phone is working correctly.
Turn phone off and install sim card.
Made sure sim card is install correctly.
If this does not work, it could be the sim card is bad.
Jan 15, 2011 | Cell Phones
HELP!! my nokia 6500s wont allow me to get on the menu screen,, whenever it starts up,, it shows Push to talk,, and it wont go away,, ive restarted it several times,, it still shows push to talk,, push to...
Try doing this. Turn off the unit, remove the battery, press and hold the power button (while battery is out), then put the battery back and turn it back on. If that doesn't work, just repeat the steps including removing the Sim Card. Or turn on the unit without a Sim Card.
You can also try using reset codes but that would reset EveryThing back to default settings which might include losing the settings of your provider which is not recommended. But the initial step is safe to use.
Hope this helps.
Nov 16, 2010 | Nokia 6500 Slide Cellular Phone
How do you change a sim card in a motorola v3
Hello
If you want to change a sim, switch off the phone, remove the back cover, remove the battery gently remove the sim an place the new sim.
Put the battery again, cover the phone and switch it on.
Thanks.
Aug 11, 2010 | Motorola Mobility RAZR V3x Cellular Phone
Phon is turn on for few hours only
I guess the problem might have occuerd because you must have left your mobile aside without removing the battery for quite sometime... try recharging your mob for about 4-5 hrs... even if the problem prevails then I think that you need to go for a new battery..
Jun 21, 2009 | Sony Ericsson W350i Cell Phone
....motorola v3xx won;t turned ON!!..HELP
Have you tried replacing the battery? Also try this first - remov battery and SIM card. Wait 1 minute. Replace battery and SIM and power on. See if that helps.
If problem persists, you may have to repair the phone.
Oct 25, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola RAZR V3x Cellular Phone Won't turn on
i have the same phone. it is motorola faulty built of chipsets. just return the phone for a next one
Feb 12, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Nokia 6288 wont turn on
If you encounter situation like below on your phone,
1. Blank screen phone unable to reboot.
2. Phone only able to boot-up to "Nokia" word screen.
3. Install some program but not able to uninstall it after that.
4. Error messages such as "Child Installer" keeps popping-up.
Do a Full phone formatting on your phone! as steps below,
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your phone.
4. Press and hold 3 keys;
Green dial key, * (star key) & no. 3 key and then press the power on/off to swtich on the phone.
Remember, do not let go all of the keys and hold keys until you see a formatting word screen show!
Nov 14, 2007 | Nokia 6288 Cellular Phone
Motorola Mobility RAZR V3x Cellular Phone Logo
57 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
