Question about Kitchen Ranges
Ignitor sometimes clicks, sometime not
When you turn gas on, ignitor works intermittantly. sometimes its normal and it lights, sometimes its a fainter click and does not light. maybe something is dirty? maybe the ignitor needs to be replaced? Does the 6 burner model viking have a central igniter that feeds the others at the burner. it seem if it works it will light for any of the 6 and when it doesn't it wont work for any of them. Also, i've noticed there is some failsafe that once lit, the clicking will stop automatically. As though it has a sensor. maybe the sensor is dirty? I have a viking six burner range, the ignitor doesn't work at all on all burners and the oven, is this a easy fix or do I need a Viking service repair person.
    Sergeant:
  • 314 Answers
You will need the ignition bird located il under the cooktop
Posted on Mar 28, 2017
hotuna
  • 288 Answers
SOURCE: Viking Range
The clicking is the electrode arcing. when the burner lights, a sensor tells the electrode to stop sparking after is heats up a little, that's why is clicks a little after the burner lights, but then stops. If the spark keeps going, the sensor is not registering the flame. The ones that do not click could be the ignite coil, the wire, or the electrode.
Posted on Nov 15, 2007
thaurfen
  • 623 Answers
SOURCE: Viking model VGR48 stovetop burners will not ignite?
First shut off the gas supply & disconnect electrical power to the range.
  • Remove all the burner control knobs, grates, burner caps & trim rings.
  • Remove the 2 screws securing the manifold panel, one from each corner. The panel will drop down.
  • Remove the screws from each manifold pipe mounting bracket. Remove 1/4 inch hex head bolt from the center of the manifold pipe. Push supply tube back to release from manifold pipe. Lift the cooktop assembly at the front to clear the 1/2 inch locator pins attached to the top of the bodyside.
  • Place cardboard between each side of cooktop & bodyside to prevent damage.
  • Move the cooktop to one side, being careful not to put stress on the wiring harness on left side.
  • Remove the wire from the electrode.
  • Remove the screw from the electrode mounting bracket to release the electrode.
You can replace the electrode & reassemble following instructions in reverse order.
Posted on Aug 20, 2008
SOURCE: burner ignitor will not turn off after the burner lights Viking
replace the electrode that's the wire or pilot tip, it has a sensor built in, when it gets hot it stops automatically. if the electrode is between the front and rear burners, there are small holes on the burners going down on the side of the burner facing the ignition. they need to be clean. try a paper clip and insert the clip in side the holes.
Posted on Dec 14, 2008
  • 42 Answers
SOURCE: My Viking range top grates are dirty
viking advises using nothing but warm soapy water. grate polish works very good to bring that deep black shine to the grates again
Posted on Dec 21, 2008
  • 10865 Answers
SOURCE: viking range burners won't light
All of these ranges have a spark module at each burner sight and they all click when ever you attempt to light one burner. Therefore, it can not be assummed that the spark module for those nonworking burners are actually clicking. Remove the burner covers and actually look for the sparks. If there is no spark make sure the connections are nice and tight. IF they are, you most likely need to replace the spark module.
Posted on Apr 30, 2009
Why won't my dryer heat up sometimes?
It may be a cracked ignitor. check the ignitor and look for any white spots. these can be an indication of a crack which can cause intermittent problems. Replace if necessary. Hope this helps.
Bob
Jul 18, 2014 | Maytag MDG16PD Gas Commercial Dryer
Troubleshooting
One or more Problems could cause this
1) I believe you have an HSI Ignitore in your Oven These sometimes Crack and will glow enough to ignite the burners before they stop working completely. Your burner tube might be Dirty or Clog and needs to be cleaned as well as the orifice face. Check it out let me know if this was the Problem.
Oct 15, 2013 | Estate TGS326TD Kitchen Range
Gas dryer burner intermittently lights. Foul gas
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 17, 2010 | Estate TGDS680EQ Dryer
The gas does not always ignite
Replace the ignitor. If the ignitor is not working correctly it will not turn the gas on. Sometimes it can be the gas valve.
Gas dryer's are really dangerous, please take precautions.
http://www.pdxappliance.com
Feb 27, 2010 | Kenmore 75922 Gas Dryer
Oven takes forever to pre-heat and then doesn't keep the temp constant. turning on stove burner helps sometimes, and sometimes it works fine. do we need new thermostat or...? not sure if i have right...
Very common problem, I would replace the oven ignitor first as they get weak with time and cause intermittent burner lighting. Good Luck, Appliance Specialists
Dec 31, 2009 | Maytag MGR5750 Gas Kitchen Range
The oven will not heat up. I can see the pilot or
The gas valve operates on "passed through" electricity from the ignitor - if you have a marginal ignitor, then the valve will give you problems. Intermittent problems are the worst to diagnose, but the way you are describing it, my first action would be to replace the ignitor. If it doesn't work after that, then try the valve, but be prepared for the price tag cause it's kinda scary. Good luck.
Sep 06, 2009 | Kenmore 71042 / 71044 Gas Kitchen Range
Burners sometimes will not light
You can check the ignitors/wiring by switching
the output wires at the spark module. If the
front ones work & back ones stop working, change
out the module. If no change take a look at the
ignitor(remove screw on bottom to remove
ignitor), ignitor wire & ground wire by removing
the burners.
Possible Causes Of Continuous Sparking:
Defective spark wires.
Continuous high heat can cause spark wires to
degrade. Use volt/ohm meter to determine
continuity
of spark wires. Look for obvious cuts/ abrasions
or pinch points. A defective wire can allow
spark voltage to transfer through insulation to
ground prior to reaching spark electrode. Under
normal circumstances all igniters fi re together
and if the burner in question has found an
easier
ground path the spark will go there. It will
not, however, in most cases have found a
CONTINUOUS
ground path such as what the fl ame would
provide under normal circumstances. This will
cause
the spark module to re-ignite.
Sep 01, 2009 | Viking VGIC485-6G Gas Kitchen Range
Kenmore gas oven intermittently not lighting
Replace your oven ignitor. It has to draw enough current to open the gas valve. it is only drawing enough current 85 percent of the time so the other 15 percent it wont light the oven (Gas valve wont open) The part number for the ignitor is 8190618 and is 55 bucks at sears.com
Nov 21, 2008 | Kitchen Ranges
Igniters are not working right
when you turn any burner control to lite all ignitors should click this is normal industry wide. the ignitors are controlled by switches that are placed over the valve shafts they are wired up together so thats why they all click when you only operate one valve don't worry about it. the ignitor stays on untill you back the valve off a tad this is also normal.
Apr 15, 2008 | Cooktops
Gas range (oven)won't lite (gas broiler works fine)
Sounds like an ignitor problem or possibly a dirty orifice. Model #'s are usually on the frame behind the bottom drawer.
Oct 04, 2007 | KitchenAid KGSI901PBS Gas Kitchen Range
Kitchen Ranges Logo
90 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
