Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser not working
GE model GSL25IFRF BS. Icemaker works fine. Water comes from solenoid pump through water line going to door but water doesn't dispense.
  • 120 Answers
2 things i want you to try before you call a tech out first under frezer door there is a connector where the 2 lines connect disconect both off now actuate the water at door if you get water out the line that means your line inside door is frozen 2 if you don't get water that means your water reservour is frozen so to solve problem cheapest way is to derost it by unpluging it for maybe 2 days and if it was frozen it should go back to normal and this time keep your temps in right settings refrigerator section at 37% and freezer from 0 to 4 % at all times that will keep lines from freezing
Posted on Oct 12, 2008
  • berklee Mar 30, 2011
    Guru. You Rock! Took me 5 minutes to fix it based on your advice. If I was Hugh Hefner I would invite you to the mansion. Let me know if you have any online website or business so I can repay you some how. Thanks!!!!!
    Electro
Everything normal on my GE Profile Model PFSF6PKWBBB French door bottom freezer refridgerator except the water dispenser just quit dispensing water. Is it frozen? How do I fix it?
The paddle that you push the glass against to dispense water activates a microswitch. Sometimes this switch can break off it's mount and drop away from it's intended position. The microswitch operates a solenoid valve near where the water line enters the back of the fridge. Then there's the wiring in between them. The water line doesn't go through the freezer. It runs through the refrigerator in a coil of tubing then into the door of the dispenser. Check the paddle switch, the water solenoid and the wiring and you'll find the reason it doesn't work
Mar 05, 2016 | GE Refrigerators
The water on the freezer door will not work ice does dispense. this is a ge side by side model GSL25JFTA BS. kbaker23322@yahoo.com
most likely you water solenoid is bad. need to make sure you get voltage(120v) to water solenoid. if voltage then the only other thing that could be wrong besides the solenoid. would be a kinked hose or the line (has a small chance) has frooze inside the door panel if sprung a leak.
Aug 01, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have A GSL25IFRF bs side by side fridge with ice and wter dispenser on the outside and I am not sure how to connect it to work so I can get ice and water
On the back right side facing the refrigerator at the bottom is a connector for a quarter inch water line. Sometimes you have to loosen the back to access this. Hook your water line up here.
Jun 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator is not pumping water through the door. It is making ice properly. What would cause that? Thanks GE GSL25JFPR BS
If this is a newer fridge, less than 10 years old, the problem likely lies within the freezer door itself. Underneath the freezer door, behind the toe plate, is a water line union, either a screw in type, or blue, push-in type of connector, with 2 white collars on either end. push these collars toward each other while pulling the water line out of the connector..if its the screw in, simply unscrew it by hand. once you have it seperated, put the water line NOT coming out of the door into a bowl on the floor, and actuate the water lever, does the water fill up the bowl? Then your door's insulation has pockets of air, which over time build up with ice, and then freeze the water inside the door, preventing it from dispensing..
There is no fix for this, other than replacing your door, and i couldnt even tell you if the new door will solve the problem.
My advice, complain to GE.
Apr 07, 2010 | GE CleanSteel GSL25JFTBS
I have a GE model GSL22JFPH BS refridgerater and
Then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . There is a heater for the water dispensor tube , pt # WR49X10173 , which should keep this from happening again .
Nov 18, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE REFRIG MODEL GSL25KGRB BS 4 YRS OLD. PROBLEM: WATER IS NOT DISPENSED BUT THE ICEMAKER IS WORKING. CHECKED ALL THE WATER LINES. LIGHT WORKING ON THE CONTROL PANEL. GETTING WATER TO THE QUICK CONNECT...
Found another post that says the water line is froze in the freezer door. They said to turn the night light on for 24 hours and see if that helps. I'll give it a try.
Dec 03, 2008 | Refrigerators
Icemaker works fine, only dispenses water
make sure that the ice shoot is not clogged up with ice or the in the ice basket where the ice goes through. Sometimes the ice can be stuck together and jam and nothing will come out.
Nov 25, 2008 | GE GSS25JEMWW Side by Side
Ice will not dispense GE model GSL25IFRF BS
well if you trouble shoot the board at the back to see if you are getting voltage if you are then use a jumper on that conenctor and see if the auger motor runs or remove auger motor and check voltage there while pressing the lever for ice usually 100% of the time that board controls everyhting water and ice
Nov 17, 2008 | Refrigerators
Water dispenser in fridge door
Email me for the bulletin on water line freezing. Try turning on the dispenser light for 24 hours this should defrost the line.
amasuperbike@comcast.net
Jan 15, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
836 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
