Question about Toshiba Satellite A105 Notebook
Toshiba satellite a105 blank screen, blinking battery light
I'm restating this problem because I accidentally posted a comment to solution number 2 as a solution number 3.
The problem is that after a few hours of running with the power cord plugged in the screen goes black, the power light blinks yellow, the machine will not start again even from power. The machine is completely cool.
When I first ran into the problem, I changed all the power options to "never"--the computer is supposed to be always on unless I turn it off.
When the computer is in extended yellow blink mode, pressing the power button doesn't work. If it has been on battery, when I plug it in and then press the power button, it sometimes turns green and works. I don't recall but I think this is only occasional.
A possible clue I just discovered today is that even while the machine is working and the power cord is plugged in, the battery icon on the system tray reads that the power source is the battery and that only 53% of charge remains.
  • 659 Answers
Well to me either there is a issue with the power supply or the power cord. I have had a bunch of laptops where the power cords have to be a certain way or nothing will respond. this could be and since it is thinking that it is running in battery mode then it drains and then causes the laptop to turn off or go into hibernation due to the fact that the setting you set for the battery where probably on the "when plugged in" not the running off the battery mode.
it leads me to think that its the power supply because its the most common issue with this but I think that the best solution would be to either find someone that can test the power supply and find the break in the line or buy a new one to test ushally if you buy one from a store bigger named store outfit and use the power supply to test you can ushally get your money back or goto a local computer shop and get them to match up the power supply or see if they have a adaptor loose that can be used for testing.
These could be possible solutions but like I said I am almost 100% sure that its the power supply and not the laptop because even if the battery is not in the laptop the unit should still power up. on most laptops that is.
So that might be another thing that you would like to check but I highly doubt that it is that. because even a dead battery will allow the power adaptor to run on the laptop even if it dosent charge.
hope this helps and hope it works for you. let me know how you make out and if this made any sort of sence to you haha
Posted on Oct 12, 2008
HOW TO REPLACE SPEAKERS IN TOSHIBA SATELLITE A105 S-2716
Muhammad,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
1) This is Page 1. Page 2 and 3 are listed at the Top and Bottom of the page -> Page 1:: Page 2:: Page 3:: Find another model
2) You can click on any photo to enlarge.
3) Stop at Step 19
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 06, 2012 | Toshiba Satellite A105-S2716 Notebook
What did toschiba satelite 8100 lap top model number psaane/03j02gen transpose to
The Model Name and Model Number is Satellite A100-033.
It's one of the Satellite A100 series of Notebook PC's.
http://icecat.com.ua/en/p/toshiba/psaane-03j02gen/notebooks-laptops-satellite-a100-033-796649.html
1) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
2) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
3) Free Service Manual for the Toshiba Satellite A100 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Go down to the line that starts with Satellite A10. Scroll across, and click on A100.
This is a PDF file.
It may take up to 30 seconds before the first page comes up. It may also take additional time to fully download
{Service Manual for your daughter's laptop. I gave a solution to another one of your posted problems}
Regards,
joecoolvette
Jul 17, 2011 | Toshiba Computers & Internet
Toshiba Satellite® A105-S4274 laptop first it would turn on but not boot up. and keep restating ,but wouldn't boot. now it looks like it powered up but i have a bark screen and hd light is not on or...
This sounds like you may have a faulty RAM module. Often times when one or both sticks of RAM in a system go bad it will prevent the system from fully coming up. In order to test if this is the issue, follow the below instructions and as always if you do not feel comfortable working with this stuff you should consult a local technician for assistance.
  1. Remove power cable and battery from system. Ensure the system is completely turned off.
  2. Flip the system upside down and remove the RAM compartment door. See graphic below.
3.If you have two sticks of RAM in your system, you should remove one and try to boot the system. If the same issue occurs, swap out the sticks and try again.
If the issue remains, Toshiba has an alert on their website about updating your BIOS firmware. Fill out the appropriate sections on the Toshiba support website for your model for more details. Comment back if you would like further assistance.
Good Luck,
NOLA Tech
Jan 28, 2010 | Toshiba Satellite A105 Notebook
Toshiba 16''laptop. Image sideways on LCD Rotated 90 dergrees. Was on Walmart web site and when I searched the site for an item the screen turned sideways Model satellite A105-s4334
Many video card's software utilities include keyboard combos that can flip or rotate the screen. Try to go into the video properties by right clicking on a blank part of the desktop and selecting PROPERTIES. Look around on the Settings > Advanced area for rotation options. Chances are that you accidentally hit the right key combo to rotate the screen and it had nothing to do with the website that you are on.
Jul 07, 2009 | Toshiba Satellite A105-S4024 Laptop PC...
Toshiba Satellite Laptop refuses to allow Dual Monitors
I have an A105 set up on dual screens, and it works great. As I recall, you have to do the dual screen setup in the control panel, display, settings.
Mar 17, 2009 | Toshiba Satellite A105-S4074 Notebook
Toshiba a105 s2194 won't turn on.
Please try to remove the battery and just connect the power adapter to turn it on. You shoudl get the screen to work. After which, power off and then connect the battery back.
If this does not work, it maybe a hardware proble with the screen or the inverter
Mar 10, 2009 | Toshiba Satellite A105 Notebook
When reinstalling OS on toshiba satellite a105 it blue screens
most probably its a bad disk...try another one...
if it still repeats then note down the error number (every blue screen has one) and then post back with it.
Feb 17, 2009 | Toshiba Satellite A105-S4334 Notebook
Satellite screen is blank & won't shut down
Don't know why the screen is blank. Toggle the F9 key to make sure you didn't accidentally toogle off the screen.
As far as turning off the power and shutting down the computer, the old stand-by is to take out the battery and then pull the plug. The computer will power down. Replace the battery, replace the plug and then push the start button. You may have to start it up in SAFE mode since the shut down process was not the "normal' process the computer expects to follow.
Dec 13, 2008 | Toshiba Satellite A105 Notebook
Problem with laptop- no power
The battery needs to be taken out once in a while. It is possible to use the ac adapter and power cord without the battery to power your laptop. Please press on the power button for 10 seconds for your computer to turn on. Check if you can see any message on the screen.
Sep 04, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Notebook Logo
459 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
