Question about Apple iPod nano
IPOD NANO my ipod went in the wash n everything is fine but when i trun it on i cant see what is displayed on the screen its is soo dark i can only see it when i put it to the light
  • 4 more comments
  • humied21 Oct 13, 2008
    what would they do
  • humied21 Oct 16, 2008
    is it possible for me to change the circut because i dont know where to go for the service
  • humied21 Oct 18, 2008
    are u happy now
    nahhhhh idont know were it is n it might cost alot so ill just steal 1
  • humied21 Nov 06, 2008
    thankss mannn ur the best fixya person even thou u didnt fix my problem lol but ur seem lyk a good friend
  • humied21 Dec 02, 2008
    lmao
    niceee jobbb mannn
    aii so do i go to 6th ave to get my ipod fixed
    yooo sometimes the light jus starts flickering n then thats it
    President:
  • 2,712 Answers
Your backlight has shorted out or is failing. There is no way to do anything, except a service. You will have to take it to an authorised service center..
Posted on Oct 12, 2008
  • 3 more comments
  • Swilin Sampson
    Swilin Sampson Oct 13, 2008
    They will replace the backlight circuit. BTW, why a Thanks for Trying rating? Thats a negative rating. Kindly change it to at least Helpful, if you don't mind.
  • Swilin Sampson
    Swilin Sampson Oct 16, 2008
    If you are in the US, put in your zip code in the box at the right marked "Repair Service", and it will give you a list of service centers nearby. And I do hope you can change my rating. Thanks for trying is a negative rating, and I did not do anything negative here. I gave you all the info I could based on your input..
  • Swilin Sampson
    Swilin Sampson Oct 18, 2008
    Thank you. Were you able to find a local service center?
  • Swilin Sampson
    lol
  • Swilin Sampson
    Swilin Sampson Nov 06, 2008
    Cheers! Thank you for the comment..just made my day :)
Ipod was in washer (and dryer) and works fine, just no backlight, any way i could fix it myself?
I dont know how U can fix it but one thing your Ipod rocks mine went throught the waster & dryer and broke apart
Apr 03, 2010 | Apple iPod nano 4th Generation
My ipod wont play on my ihome
no you cant reset. call apple they will send one free
Oct 25, 2009 | Apple iPod nano
My Apple ipod display screen shows lines (coloured one),, cant see menu or anything..but the songs play
Sounds like a bad display. You can get replacement displays here http://www.ifixit.com/iPod-Parts/iPod-Nano-Gen-2-Color-Display/IF199-000
-=/ Daft Tech /=-
Oct 24, 2009 | Apple iPod nano
Need unlock code for ipod
have you tried syncing it on a different computer? cuz if you do that it erases everything and starts over. it could work
Jun 09, 2009 | Apple iPod nano
Perfume leaked into my ipod nano
it might have probably occured as some of the droplets has gone into the inerfacial of the lcd and the chip..(I SUPPOSE SO)... i would advice you to give it to a service shop and ust clean the screen inside... pls do reply if this works ...
Apr 10, 2009 | Apple iPod nano
Screen gone dark
It is natural to ipod the screen will be dark if has no power unless the LCD of your iPod is defected even it has a power its remain dark that’s the symptom of defected LCD screen. I hope your problem is a power failure only. Make sue your iPod is fully charged and then toggle the hold switch on and off. Then reset your iPod nano; Toggle the Hold switch on and off,(Slide it to Hold then it off again). Then press and Hold the Menu and Center (select0 buttons simultaneously until the apple logo appears ,about 6 to 10 seconds .You may need to repeat this step . If you having difficulty resetting your iPod set it on a flat surface .Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel,and not near the center. Then If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try your iPod nano with a different USB port on your computer, not a USB port on your keyboard or hub. iPod will stop charging if the computer, or portable computer, it's connected to enters standby, hibernation, or sleep mode. To charge your iPod, connect it directly to a computer's USB port and make sure standby, hibernation, or sleep mode is turned off. If using a portable computer, make sure it is plugged in to a power source and that the lid or display is open. If the lid is closed the computer may go into either standby, sleep, or hibernation mode and iPod will not charge properly. If you have an Apple iPod USB power adapter you'll be able to charge your iPod without leaving your computer powered on. If all procedure above for power to on is not working then its better to replaced the battery with anew one so its works normal again.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Apple iPod nano
I have a problem
ifyou still have the receit return it
Sep 29, 2008 | Apple iPod nano
Help to solve my iPod Problem
first connect it to the computer, check to see if it's recognized by the computer. Make sure everything else is working fine, like transferring songs, video, sound, everything. If the ipod's still doing the same thing I would suggest reformatting the ipod.
Mar 04, 2008 | Apple iPod nano
Apple iPod nano Logo
100 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
