Question about Abit VH6 Motherboard
Red light flashing on motherboard
Me again, just posted the problem about the pentium 3 on an abit vh6 motherboard... tried to add more ram and it stopped beeping, bios, and booting.... when I turn it on, the fans spin. HD spins. cd-rom spins.. but no post beep or display??? which it had previuosly before the ram incident... now I look at the motherboard and a little red light flashes by the ram slots.. dont know what it means so please help me!!!!!!!!! ( I have audio production software on this computer and need to start using it again.....) P.S. everything booted up correctly before the extra ram insertion
4 Suggested Answers
  • 17 Answers
SOURCE: Abit AN7 motherboard does not boot - POST code AF
I think is a bios problem, a ram failiure would be C1 post code.If the bios is corrupted, try a blind bios update or if it doesn't want to, you must do a hot flash update.For more details google search for award bios hot flash.Or dump it and buy a new one.Usually when the post doesn't change at all or if it stops to 90 is a bios problem.I had a similar problem, mine hang at 90-after a complete check of uguru.In your case might also be the uguru chip.I hot flashed the bios.I used an abit nf7s 2.0 to start and then put in my bios.It worked and i also made a backup.Your chip is Winbond-4 mb capacity.
Posted on Jul 11, 2009
  • 27 Answers
SOURCE: Post code 99 in motherboard abit al8
check your motherboard's owner manual. Try removing the processor/ram/video card to see if that will give you any clues.
Posted on Sep 30, 2009
  • 1138 Answers
SOURCE: abit av8 bios post codes 8.3 - 8.6 - 9.C
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
Posted on May 24, 2010
Abit as8 post codes 21
Hello here is the homepage:
Post code 21, is a memory/ chipset problem.
It could be a problem with a ram module, or a Pci sound card or a graphic card. or powersupply.
Try to remove any add in cards, and try to boot with only one stick of ram.
Good luck
Jan 12, 2013 | Abit AS8 Motherboard
Hi.. I have a server system having Intel Pentium 4 processor. The following details are written on the Processor. Intel (m) (c) '03 PENTIUM (R) 4 2.8 GHz, IM1800, jl79k MALAY, Q417A92 t417b040 ...
you can on this motherboard models for your intel Pentium 4 processor,
1. ASUS P4P800 Deluxe
2.MSI Neo2-FIS2R
3.ASUS P4C800 Deluxe
4.Intel D865PERL
Feb 16, 2011 | ASUS Support Intel Pentium M Processor and...
My PC with an ABIT motherboard makes a cont beeps although my speakers are off. The beeps stops sometime and then start again. Do you have an idea what should I do. Regards Doron
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 30, 2010 | Abit BG7E Motherboard
My PC will no longer boot up and I am sure its the motherboard at fault. I get a beep every 2 or 3 seconds and there is a red warning light on board. What are these symptoms telling me?
That the memory is inaccessible - try to boot using another memory, if it's the same then the northbridge has failed = replace the motherboard.
Sep 02, 2010 | Abit BH7-E Motherboard
Abit NF7-s v2- hynix ram support problem
your system does not support the dual ddr ram unless you have a add-on VGA card
I have included the link to the user manual ... see chapter 1 section 1-1 Features and Specifications
Abit NF7-S v2
Supports DDR 400 only when using an add-on VGA card (NF7-M)
Feb 13, 2010 | Abit NF7-S V2 Motherboard
Hey guys would you be so kind to try to help me out? a friend brought me a pc with an abit IS7 motherboard it can't boot instead, all fans start working then a red light, 3 short peeps and it stops. What...
The beeps might indicate the problem with RAM. Try plugging out the RAM modules and insert them back in one by one in different slots and then check.
Jul 17, 2009 | Abit IS7 Motherboard
i think thats memory so try removing your ram and re installing it. maby its not pushed in all the way.
May 09, 2009 | Abit AN7 Motherboard
Don't understand?
take the extra ram board out
when a system fails to boot properly, it indicates a problem hard drive (HDD)
cmos batteries just keep the program for the chip operational and nothing more )
take it in to a computer repair shop for a proper diagnosis
if it is the hard drive ( has all of the operating system , files and folders ) replace it with a solid state hard drive (SSHD) as it has no spinning disc to fail
Apr 19, 2017 | Abit VH6 Motherboard
Abit VH6 Motherboard Logo
204 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
