Question about HP Computers & Internet
I start up my computer, I get a black screen that says press F1, after I do that I get a black screen with a message that reads, operating system not functioning
  • 84 Answers
Have you take note the error message about the operating system? does it say a corrupted windows file?
With regard to the error message about F1 to continue, i would say that your hard drive is looking for the operating system. There is a possibility that your operating system is corrupted due a virus infected file or a system file was accidentally deleted from your computer or it could be an issue with your hard drive itself.
You may need to check also if your hard drive is detected by computer. You may call your computer manufacturer if your system still under warranty. In case the hard drive need to be replaced.
I suggesst to run a system diagnostics first to check if the hard drive still functioning before you run windows repair using the operating disc you have with your system.
Keep me posted.
Posted on Oct 12, 2008
Startup screen
select the first boot option and press enter
Dec 02, 2013 | Gateway Computers & Internet
Troubleshooting Error Messages on a Black Screen that may Occur During Startup...
<b><u>For Hp Laptop</u></b><br /><br />There are many reasons that a computer does not startup or boot into the Windows operating system.<br /><br /><b><u>Resolving Start Up and No Boot Problems Checklist</u></b><br /><b></b> <br /><b>Perform a Hard Reset</b><br />1. Disconnect all peripheral devices and remove all USB devices and media cards.<br />2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds.<br />3. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.<br />If computer does not start normally, identify the specific problem symptom listed below and take the recommended actions.<br /><br /><b>Symptom: LED lights do not glow, display is black, computer does not start<br /></b>If LEDs do not glow when power button is pressed, there is no power available to the notebook. Check AC adapter wiring and power connection to the notebook. Connect a different AC power adapter and remove battery. Connect a different battery and disconnect AC power adapter. If there is no battery or AC power at the notebook, contact HP for technical assistance.<br /><br /><b>Symptom: LEDs glow, but computer fails to startup or boot, and displays a black screen</b><br />Usually occurs if a component is installed incorrectly, or there is a device conflict or failure. Connect an external monitor to check display Remove all CD/DVDs, SD cards, USB devices, peripherals and do hard reset If memory or hard drive components were replaced, reinstall original components Remove memory modules and replace one-at-a-time If possible, boot to BIOS mode (f10) and run Memory Test and Hard Drive Test If all other methods fail, use recovery disk to recover the computer to original condition.<br /><br /><b>Symptom: Computer displays a blue screen or continually re-starts</b><br />Trying to restart the PC after an error message can usually bypass the error and the PC can run in Safe mode to install an update or patch. <br />Boot to BIOS Diagnostics (f10) and run memory and hard drive diagnostic tests Boot to Windows Advanced boot options (f8) and:<br />o Select Disable automatic restart on system failure to view error message<br />o Run Repair Your Computer<br />o Run Last Known Good Configuration (Advanced)<br />o Select Boot into Safe Mode and then Run a Microsoft system restore<br />o Select Boot into Safe Mode and then Uninstall recently installed programs<br />o Select Boot into Safe Mode and then run Windows Update<br /><br /><b>Symptom: Computer displays the Windows logo screen and stops responding</b><br />Boot to Windows Advanced boot options (f8) and select Disable auto-restart to view error message<br />Boot to BIOS mode (f10) and Restore the BIOS defaults (f9) Boot to BIOS mode (f10) and run Hard Drive Test Boot to Windows Advanced boot options (f8) and select Last Known Good Configuration (Advanced) Boot to Windows Advanced boot options (f8) and select Boot into Safe Mode and then Uninstall recently installed programs<br /><br /><b>Troubleshooting general black screen errors on an EFI-based computer</b><br />The Extensible Firmware Interface (EFI) is available on select HP Notebook PCs manufactured in late 2008 and beyond.<br />To access the Startup Menu and the troubleshooting options on an EFI-based computer, press the power button and immediatly press the ESC key. If computer does not display a EFI Startup Menu, it may a non-EFI computer.<br />The EFI environment allows you to select from the following options:<br />Press f1 for System Information .<br />Press f2 to perform System Diagnostics .<br />Press f1 for System Information System Information.<br />Press f2 to perform the Start-up Test .<br />Press f3 to perform the Run-in Test .<br />Press f4 to perform the Hard Disk Test .<br />Press f11 to view the Error Log .<br />Press f9 for Boot Device Options .<br />Press f10 for Bios Setup .<br />Press f11 to perform a System Recovery .<br /><br /><b>Troubleshooting general black screen errors on non-EFI based computers<br /></b>The Extensible Firmware Interface (EFI) was not available on computer manufactured in 2008 or earlier.<br />When you try to start your computer, it may appear to stop responding with an empty, black screen before reaching a blue screen or the Windows logo. If there is no specific error message provided, there are several things you can do to troubleshoot a black screen. <br />Remove a non-system disk from the computer <br />To remove all non-system disks and reboot the computer, follow the steps below:<br />Disconnect any eSata, USB, or 1394 (Firewire) devices that are attached to the computer.<br />Remove any CD / DVD discs or memory cards from the drives if present.<br />Press and hold the Power button for 30 seconds to turn off the computer. Then, press and release the Power button to turn on the computer. <br /><br /><u> NOTE: During startup, a computer checks several devices for an operating system in a pre-determined order. You can change the order that the computer uses in the system BIOS. </u><br /><b>After removing any non-system disk:<br /></b>If the computer starts up normally to the Windows desktop, no further action is needed.<br />If the computer still stops at the black screen continue by restoring the BIOS default settings.<br /><br />for re-installation bios process, waiting for next tips. <br /><span>Thank you</span> <span>for taking</span> <span>the time</span> <span>to</span> <span>read. H</span>opefully these tips beneficial to you to solve your hp laptop.<br /><br />Regards<br />Multilinkent
on Mar 08, 2011 | Computers & Internet
How do you get into the bios on a 785gt-e63 msi motherboard? read the book it said at start up press f1 did not work.
As soon as you turn on the computer start tapping (not fast, but steady) the F1 key, you could try F2, DEL, and other various keys that work on other boards.
Usually the screen will show you what to press in the corner or somewhere on the screen.
F12 for boot / F2 for BIOS / etc
Or it might say Press F1 or F2 or something to enter Set-up.
You have to catch it before the computer starts to boot into your operating system.
At this point you can push the power button for half a second and the computer should turn off instantly as you have not started booting up the computer.
Then you can try another key to enter the BIOS.
After locating the manual and skimming through it, I see that it states you need to press the DEL key to enter setup (BIOS).
Hopefully that helps.
Aug 26, 2010 | Intel Motherboard
There might be a wrong setting at the bios in my friends computer but don't know how to fix it. there's NO bios settings when hitting F2 or del to enter the BIOS settings. Everything else when press sends...
its the virus problem in the operating system.if there is no virus then its the fault in the hard disk or mother board.replace one by one and check out. check out.keep updated.thanks.
Apr 02, 2010 | Computers & Internet
Amillo pro 2010 screens gone black
Check by rebooting it to BIOS--Press Del or F1 during boot....
Choose F8 option during startup intial stage-Windows
Choose Safe Mode----If it works---then No Problem with Hardware,,but with Operating System--Repair or Reinstall Operating System using Valid XP Serial Key
Oct 01, 2009 | Computers & Internet
Appear F1 to continue
becasue defaults bios settigns are loaded.
Wehn u power up press "del" key then u enter in bios setup
then press "F10" key then save settigns then exit
then it message not comes.
May 30, 2009 | Computers & Internet
When i try an open system restore the window appears blank, an my laptop doesnt no what the internet is when i try an open internet explorer it asks me what program to use, all this started after i ran i...
You might want to print this out:
1) Turn off your laptop.
2) Press the "on" button on your laptop, and *immediately* start tapping on the F8 key on your keyboard. This should bring up a black screen with white text on it.
NOTE: You may get a message saying "keyboard error, press F1 to continue." If this happens, press F1 and then keep tapping on the F8 key.
NOTE: If the Windows screen comes up, turn off the computer and try again until you get to a black screen with different startup choices on it.
3) Once you have reached the startup choices screen, use the arrow keys on your keyboard to highlight "safe mode." Press the Enter key. If you are asked to choose your operating system, just press Enter again.
This will start a lot of text scrolling on your screen. Just be patient. When it stops, you will see a login screen. Log in under your name (sometimes this is "owner").
4) You will now be logged in to you computer in Safe Mode. A message will pop up asking if you want to use Safe Mode or System Restore. Click on System Restore.
5) You should now have the option to undo your last System Restore. Choose this option and follow the instructions on your screen to get back to where you were before you tried to restore your laptop.
If you need further help after that, please reply with the name and model number of your laptop. For example, "Dell Inspiron 530," or "Compaq Presario 3000." Also let me know what version of Windows you are using, for example "XP" or "Vista."
Jan 08, 2009 | Computers & Internet
My pc problem
Your description is too vague. Please advise what error messages you get, what the screen says, what make and model of PC you have, what operating system you are using, what hardware or software changes you have made recently etc etc etc
Oct 14, 2007 | Computers & Internet
Computers & Internet Logo
63 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
