Question about Compaq Presario SR1810NX Sempron 3200+ 1.8 GHz Desktop PC ( Monitor Sold Separatley) (ER912AA)
It wont boot up
The computer keeps beeping, and the monitor keeps saying that it is going to sleep
  • brentober Oct 14, 2008
    The computer will not boot up. There is a consistent beep as soon you turn the PC on. Windows, the monitor, nothing comes on. I have unplugged everything and plugged it back in, but nothing. Ideas?
  • candysucreri Apr 09, 2009
    no enciende solo pilla son pitidos cortos y repetitivos permanece asi sin poder arrancar, no identifico de donde proviene ese sonido, ya cambie la pila, verifique la memeroia, este problema venia pasando ya hace tiempo pero desconectaba la computadora de la fuente electrica pk segun yo a lo mejor estaba sobrecargada, funcionaba pero ya no lo hacee permanece asi ya hace varios meses....
The power supply unit is bad. You will have to replace it. Also, it is custom specific ~ write down the specs of the PSU and order it from legendsmicro.com. This recently happened to me.
Posted on Dec 16, 2008
    Scholar:
  • 136 Answers
If it is beeping:
a) 1 long beep and 3 short beeps it is the graphics card. It might have been moved when replugging the monitor cord. Just remove the card and put it back in place. Stupid trick, but usually works;
b) 3 long beeps it is a RAM problem. Sometimes the same trick of removing and replacing works, but if not, it might be a faulty memory module.
Keep in mind (if you are a newbie) to unplug the power cord and to touch the metal casing prior to handling the graphics card or the memory modules! Do not get yourself electrocuted or destroy the components by discharging static electricity on them!
Posted on Oct 14, 2008
My monitor keeps going to sleep it will not stay on for a minute. I was wondering how can I factory reset my Windows hp w1907 thank you
It's not the monitor. Right click in an open area of your home page once the device is done booting up. Look for something that says something like preferences or customize in the box that opens up. You didn't say your operating system so going to do some fishing. look under screen saver or sleep settings. Increase the time until it goes to sleep and your problem should be solved. Good luck.
May 17, 2015 | HP Computers & Internet
HP w2207 monitor keeps "going to sleep" then it will not come back on and says no input signal.
most times this is indicator of a video card problem, most times you try booting in to vga mode and see does it go to sleep. if it does not go to sleap you video driver is bad and needs to be reinstalled. if it does go to sleep it is usually video card issue. to boot in to vga mode turn ur pc off and once u press on to put it back on start pressing button F8 and advanced menu will come up and you have to choose boot in to vga mode. if this does not work same way go to safe mode with networking and reinstall video driver by going in to device manager.
Nov 27, 2009 | HP w2207 Monitor
My computer keep shuting saying monitor going to
start button >settings >control panel > Power Option > set time for monitor to sleep if inactive...if you dont want the computer to sleep go up to the hibernate tab and uncheck it. If you want the computer to stay on regardless, move all drop down menus to "never" instead of a time.
Sep 01, 2009 | HP w1907 LCD Monitor
Monitor going right to sleep mode on start up
Sounds like a bad graphics card. Try using monitor wit another computer and see if the problem still exists. This rules out the display.
Jul 25, 2009 | HP w1907 LCD Monitor
Computer beeps when I turn it on and keeps beeping the monitor
take your memory out and reseat it otherwords
put back in make sure its in all the way
Jul 20, 2009 | HP Compaq WF1907 Monitor
My 19mvwk is saying no signal going to sleep
Check the data cable is properly fixed. Can you hear the beep sound while booting. Check the ram inside the cpu.
Jul 06, 2009 | AOC 19LVWK LCD Monitor
Monitor keep going into "sleep" mode
Check the power setting in control panel of windows. If you have a monitor from another computer swap them and see if the problem stays with the computer or monitor.
May 12, 2009 | Dell Dimension 3100 PC Desktop
HP Proliant ML350 G5 wont boot ,just spining.
The G5 Series is fairly new, if you're within warranty, call 1800-okCompaq.
Could be a bad cable, a bad monitor, or bad computer hardware. Any display at all or any beep codes?
On the back, the ml350 G5 will likely have an additional Network interface jack-- this may be labeled ILO. The ILO network connect allows you to use another PC on the same network to access this system (like a remote control via VNC or RDP) even if it won't power up--literally. Inside the ILO page, (you'll need the IP address of the ILO, the default account is administrator, and the default password is listed ona paper tag attached in the rear or on a sticker. If you can get into ILO via web browser: https://ipddress of ilo, you can check the Integrated log, which can shed some light on any failures.
Mar 19, 2009 | HP Compaq ProLiant ML350 G5 Server
My W2207 monitor keeps going to sleep
Hi,First there is no signal from the PC . check if the display card has come out while moving the monitor, or just reinsert the display card in the PC , then boot the pc .
Jan 14, 2009 | HP w2207 Monitor
Try to start my computer but tower keeps on beeping and monitor keeps saying going to sleep. What could be the problem?
Probable reason for the beeping sound are:
  • defective, dirty or faulty seated memory sticks; clean, re-seat or replace (most likely);
  • defective, dirty or faulty seated video card; clean, re-seat or replace (likely);
  • corrupted BIOS; flash or replace motherboard (least likely).
The monitor going into sleep mode is because it does not sense any usable video signal from the computer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 10, 2008 | Computers & Internet
Compaq Presario SR1810NX Sempron 3200+ 1.8 GHz Desktop PC ( Monitor Sold Separatley) (ER912AA) Logo
217 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
