Question about Canon Cameras
Somehow when I put the CF card in, I bent one of the pins all the way down. Not sure if it can be straightened or it might need new set of pins.
  • pinc Oct 12, 2008
    This is the canon rebel xti (400d). Any instructions to open and fix this? Or what is the going rate for repair?
  • 489 Answers
Hi
Not sure what model you have, but the answer can change depending on model.
You can definitely try bending the pin back straight by sticking something down there; hopefully it won't snap off and all will be well.
If you need the card reader replaced, some come right off without too much hassle and no soldering... If you have a Canon EOS Digital Rebel for example though, the CF pins are soldered onto the PCB and it must be un-soldered then the new unit soldered back on... not an easy task.
We are an affordable digital camera repair business, if we can help please let us know.
Google: Darntoothysam com
Thomas
Posted on Oct 12, 2008
How to fix cf reader pins
If they are only slightly bent you may be able to straighten them with a small flat screwdriver blade. If they are bent all the way down they will have to be replace - not a job for an amateur! If the two center pins are bent over and touching other pins, then there may be circuit damage - they are the power pins and touching other pins that are output pins blows part of the CF control circuit. This would require replacement of the rear circuit board, which requires programming with Canon software (which they do no supply to anyone)
Feb 11, 2013 | Canon Rebel XT / EOS 350D Digital Camera
Err cf have changed compact flash cards. every
check deep inside the card slot to see if you have any bent pins. They can often be straightened out with a thin screwdriver.
Sep 05, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS/Rebel XT won't power up
Joe, this happened to me, just tonight... I got a new CF card and stuck it in, turned it on and one CF card flash. Completely dead from there. I found one of the CF card pins bent over, shorted out the socket and blew the mainboard fuse. I took the camera apart, found the fuse (labelled K) about under the set button area) I bridged the fuse with a bit of solder, straightened out the pin in the socket, put it all back together and it's working fine. The fuse is under the right side shield cover, it's labelled with a letter K. There is another fuse on the power inlet board (below the shutter button) and it's labelled 'P'...
Aug 01, 2009 | Canon Rebel XT / EOS 350D Digital Camera
CANON REBEL XT -CF card error
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, you may elect professional repair (likely more than you'd be willing to pay), or you might want to try the following.
Remove batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. The jeweler's screwdrivers that you see at the dollar store will work fine. Another tool that I sometimes use is a stiff wire with a bent hook on the end to get very flattened pins started. Take your time and use as much patience as you can muster (take a breather in between if needed). Just keep nudging it upward/straighter a "tiny bit at a time". Whatever you do, don't try to unbend it with one push/nudge, you won't be able to do it.
It doesn't have to be perfect, just as close as you can get it. When it's the best that you can get it, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Jul 02, 2009 | Canon Rebel XT / EOS 350D Digital Camera
CF Card Err
Sounds like you have bent pins on your CF reader. Open the door, take out the card and look inside. Is there damage to the pins?
You maybe able to fix it with pincers and a needle just align the pin or pins that are out of place, i did this and it worked for me and now my camera is working fine. and for free.
Good luck
Mattias
Oct 29, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Card error with both cf and xd cards
check the pins in your cf slot.. you may have one bent. either straighten it out or send to repair
Sep 28, 2008 | Olympus EVOLT E-500 Digital Camera
Memory card error
Hi, I kept getting a "memory card error" on my Canon PowerShot S500 as well. It turns out that one of the pins in the CF memory card slot was bent. Maybe I accidentally bent it while changing the memory card one day. Anyway, I had to take apart the whole camera to get in there and straighten out the pin, but when I put it all back together, it works great! No more errors. Take a look with a flashlight and see if one of your pins are bent. And if you decide to take it apart, be very careful about keeping track of where each screw goes... they are tiny and they are different sizes.
Jul 10, 2008 | Cameras
CF Card Error
Sounds like it might be a bent pin. Remove the CF card and look down inside the card slot for any bent pins. If you discover some, then also remove the camera's batteries. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. Take your time and use as much patience as you can muster (take a breather in between if needed).
It doesn't have to be perfect, just as close as you can get it. When it's there, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Jun 23, 2008 | Canon PowerShot A95 Digital Camera
Card wont read
The pin is bent on the camera? This unit card reader in the camera needs to be replace or maybe the card is uncompatible for the camera. it sould be and sx or sd card for a camera.
Nov 22, 2007 | Nikon Coolpix 2100 Digital Camera
CF Error - Card cannot be used
Your problem sounds as if there's a bent pin in the CF card holder inside the camera. To fix it you will have to be very careful with a long blade fine screwdriver. Remember you'll have to straighten it in one go. If you bend them twice you can bet they'll break. A powerfull light to see the bottom where the pins are is needed too. If you're not willing to do the job yourself there's a guy on Ebay USA who straightens them. BMW
Jul 04, 2006 | Nikon Coolpix 5700 Digital Camera
Cameras Logo
220 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
