Question about Dewalt Self-Leveling Line Laser Horizontal&Vertical - DW087K
DW087K hello, I bought brand new DW087K. I tried to operate and I was wonder-struck that laser beam thickness is not the same at different distances. For example, I put DW087K 7 m 40cm from the opposite wall, and siwtched on horizontal laser, the thickness of the beam was about 9 mm - 10 mm and the beam was not clear, blur. Is this normal? then I tried to put from the opposite wall at a distance of 2 m. the laser beam thickness was normal about 1 or 2 mm and the laser beam was clear. It was outside, temprature was +10 C, battery indicator was ok. I tried also indoor, distance was 5 meters, but the thickness was about 4-6 mm, and near the DW087k the thickness was ok. Where could be the problem?
Was the lens clean mine gets steamy and makes the line bigger
Posted on Oct 26, 2008
DeWalt DW088 wont work wont switch on why
Immediatly go back to your dealer.is not the way for you but if you are have this problem and read this and if you can in your case replace it in between 8 days do not let repair. go for replace thats the way to handle.
Only thing you can do in this cause is to control your batteries on their dc. 1,4 til 1.6 V
Have allways clean battery contacts
Mar 27, 2013 | Dewalt Dw087k Selfleveling Line Laser...
Dewalt laser faults
The lases will not turn on , I ave tried new batters
Jan 24, 2013 | Dewalt Self-Leveling Line Laser...
DEWALT LASER LEVEL SELF LEVELING THE LIGHT LASER IS VERY LOW (VERY HARD TO SEE) CAN BE FIXED? THANKS.
This is one of the cheeper lasers and is designed for predominantly indoor use this Dewalt DW087K unit has a visibility range of 14 yards. Although from experience they do drain the batteries quicker than you would think and cause the laser to be hard to see as well. Hope it works for you!!
May 25, 2011 | Dewalt Dw087k Selfleveling Line Laser...
Laser won't light
you can have a try below suggestions:
  1. Use new batteries.
  2. Use quality wooden matches. Some low quality matches are very difficult to ignite.
  3. Color the tip of the match black.
  4. Keep you hands steady or use a tripod to ensure a steady beam.
  5. Shorten the distance between our portable laser unit and the match.
  6. Use a lens to further focus the lens (try our convex lens).
Apr 14, 2011 | Laser by Nebo LASER
How do i calibrate a dw 087k laser
Here is a link for the owners manual for that particular laser. http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/593338-00,DW086.pdf
In there are the instructions for a Field Calibration Test. These units should be sent to DeWalt Factory Service for Calibration. If the unit is less than 1 year old they should calibrate it for free under their "1 Year Free Service" warranty.
Oct 09, 2010 | Dewalt Dw087k Selfleveling Line Laser...
How do I calibrate my stanley laser level
to calibrate you need to have an area 75 to 100 feet in distance. place laser on tripod 20 feet from one end, take measurements on short and long end, then move laser to center of range and take measurements on both ends . the distance between both sets of marks should be within + or - 1/4 inch if not move level screw to move beam to center then center bubble
Jun 17, 2010 | Stanley 77 156 RL100 Manual Leveling Dual...
My Onkyo DVD/CD Player CP704 plays CD's with no problem, but DVD's are a problem: I get "loading" but does not play and I get "no disc" on many occasions. What gives, any solutions? Thank you.
Laser Beam could be dirty, use disc cleaner or clean the eye beam on the laser pickup but the Laser ickup could also be bad, Mats has them
1-800-628-1118 First try Cleaning Eye Beam.
Jun 02, 2010 | Onkyo DV-SP404 DVD Player
I have a WRT300N router. I was wondering what the maximum distance that laptop with a WPC300N can be too still get a good signal?
Coverage
We tested the router’s coverage at different distances and with different obstacles. We measured the signal level in five points:
Point 1: Near the WRT300N
Point 2: At a distance of 4 meters without obstacles
Point 3: At a distance of 5 meters + two thin gypsum wallboards
Point 4: At a distance of 6 meters + one brick wall, about 30cm thick
Point 5: At a distance of 17 meters + one thin gypsum wallboard and one 30cm brick wall
Here are the results...
Nov 21, 2009 | Linksys WRT300N Wireless Router
DW087K
check first the connection male & female if not loose.
if not` have to send unit in state for repair.
Apr 12, 2008 | Dewalt Self-Leveling Line Laser...
Dewalt Self-Leveling Line Laser Horizontal&Vertical - DW087K Logo
358 people viewed this question
Top Dewalt Measuring Tools & Sensors Experts
ka4iup
ka4iup
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Dewalt Measuring Tool and Sensor Expert? Answer questions, earn points and help others
