Question about Proview PL926WBi 19" LCD Monitor
On the moniter the brightness window keeps coming upevery second
The brightness window keeps coming up on the screen
    Novelist:
  • 159 Answers
The buttons sometimes stick on these. You may have to remove the front trim and take out the button set, then clean around them really well.
They are only plastic spring loaded, So the tension can be increased a little by bending it in the reverse direction slightly.
If when apart you find they still seem tight the slot in the front trim that they come through can be enlarged a bit with a small file or exacto knife etc.
To remove the front trim,
Remove the 4 bottom edge screws
These trims SLIDE upwards to release the catches. You will need to lift the top of the trim away from the lcd screens surface a little bit as you slide the trim upwards.
Shout if you need anymore info.
ebaypowerseller
bammbammfran
Posted on Oct 14, 2008
MY MONITER DELL E771A MONITER SCREEN IS VERY DARK I ALKREADY SAVE 100% BRIGHTNESS HOW TO SOLVE THIS PROBLEM
That's an old fashioned CRT. I'd increase contrast at well since it affects how bright the tones get and see if it helps. It should never be dark. It's may be dying.
Jan 10, 2012 | Dell Computers & Internet
Viewsonic sreen isn't displaying the picture
More likely to have bad caps, see example here: http://s807.photobucket.com/home/budm/allalbums
Common problems to ALL brands, they all failed after a couple of years.
Jan 17, 2010 | ViewSonic VX2235WM Monitor
Contrast menu keeps popping up in my moniter,it is a hcl moniter,the menu is not the normal adjustment menu that appears in the moniter which has all options like colour,brighteness etc.its just like a...
mmm look you have a setting problem reset the screen to it's defulat if it didn't solve the problem you will have to change the press bottoms and you will need some who know electronics to help you with the board but first try to rest it to the defulat settings
Nov 15, 2009 | ViewSonic VA721 17" LCD Monitor
Negative effect on Bright areas of Monitor/TV
Try demagitizing the moniter. In the monitor's menu it will have a picture of a magnic , select it. Sometimes it is listed as degrous. After selecting this, your screen will seem to spin then settle. If your still have problems, a magnic may have come close to the moniter while it was being stored, and that will ruin the picture.
Sep 21, 2009 | Computers & Internet
Dell moniter, brightness adjustment keeps coming on
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
Jun 06, 2009 | Dell UltraSharp 2407WFP 24" LCD Monitor
Brightness decrese when i plugin the power cord.
Check your power settings, where the little battery is in your righthand lower tray,look for change screen brightness or something like that,there should be 2 columns, make sure u pick the one that says"plugged in" instead of the while running on battery setting.Adjust accordingly.
Dec 16, 2008 | Compaq Presario Notebook
Moniter brightness
Have you tried using the manual controls on the keyboard for changing the brightness (Fn right arrow)?
I think the epower management is crap, usually I just uninstall them all and adjust things manually.
Jan 12, 2008 | Acer Aspire 5100 Notebook
Magic Bright
Problem is made by switches which are bad quality, you have to take your monitor to the nearest samsung service center or if you want you can change this switches by yourself. You can find them in conrad stores named phap3363 and art.nr: 700310 - 62
Dec 11, 2007 | Samsung Syncmaster 17" 720N Monitor
E173FP 17" LCD Monitor Problem
I have the same problem. It seems like a virus to me, but my anti-virus doesn't find anything. I went to the main menu on the moniter and changed the display time to five seconds and locked the OSD display. Now all the appears is a smaller box showing a lock which goes out in five seconds. It is still annoying, but less intrusive then before. Hopefully, some one will determine a permanent fix for this problem.
Oct 26, 2007 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Proview PL926WBi 19" LCD Monitor Logo
48 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
