Question about Ovens
Heating element remains on
Hello. I have a Frigidaire Stove, Model FEF336ASF. Recently, the oven element will not turn off through the normal method. The only way to turn it off is by unplugging it. Please advise. Thanks
  • 706 Answers
Hello JLH2433,
Depending on thebrand and model.. you may have one of several problems with your stove. Your heating element power may be get its power via a relay or contactor which may be stuck on all the time. To de-energize it, you remove main power and it actuates to the Normally Open position but when you select that element to be turned on and the contactor/relay is switched from Normally Open to energized and Normally Closed, it provises power to that element. You may have a bad relay/contactor ofr the controller is defective. Removing power will deenergize the relay/contactor but that contactor is a slave to the controller, 50/50 which component is the root cause of your problem..
Posted on Oct 12, 2008
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat '
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Don't worry! Your element probably blew out. It's no big deal. It happens. Call us for parts. 9728590929. It's really a simple repair, probably one of the easiest to do. Hope this helps!
Aug 24, 2009 | Ovens
I have 1950's Frigidaire electic oven by General Motors and the top heating element is broken. Where might I find a replacement? had the oven element for my '60s Frigidaire GM stove. They have a good "narrow your search" feature that was helpful as the model number is no longer recognized.
Give them a try. Pull your bad element and measure it to get a match.
Jul 11, 2009 | Ovens
Frigidaire model MGF331BFWA...Oven isn't lighting(heating)up
Stove wont heat up. Stove top elements are working fine. do you think it is the heating coil/element in the oven?
Mar 01, 2009 | Ovens
Oven will not turn on
remove the back panel,you might have a wire burnt off going to the switch-mike
Nov 05, 2008 | Frigidaire FEB30S6D Electric Single Oven
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Dec 18, 2007 | GE JKP20 Electric Single Oven
Ovens Logo
124 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
