Question about Garmin GPS III
Garmin V I have a Garmin V that looks like the pictures of the Garmin III. I can turn on the Garmin V but soon the screen goes blank with a narrow black vertical line apparent on the screen. I read some of the solutions regarding internal battery, possible screen problems but no real solutions appeared. Any ideas on how to correct this problem?
  • rawsonboy Oct 20, 2008
    I have exactly the same issue
I think I may have found the solution.
A reply for a post on another site:
I visited the Garmin Corp office to seek help with that problem. If the shut down occurs right after satellite acquisition and the screen may show just a narrow black line going across it, it is likely due to some program changes the sattelite folks did without telling the software programmers. Garmin web site has a free download fix for the problem. Another option is to go into your settings and turn off the WAAS. Hope this helps. Go to the web site, check downloads, find your model gps and there you go. Good luck.
I disabled WAAS and so far so good.
I couldn't find the fix on the Garmin site.
HTH.
Posted on Oct 20, 2008
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Screen goes blank after locating sattilites.
Accordingto Garmin, this problem can be fixed by disabling the WAAS feature in teh set up menu. There is an incompatibility between the old Garmin software and latest WAAS upgrades. Later software from Garmin is supposed to fix this problem.
May 21, 2009 | Garmin eTrex Legend GPS Receiver
Just quits
I had the same problem (blank screen, vertical line). Per Garmin, turn off the WAAS function. Disable it for now, because the government has changed the WAAS signal coming from the satillite, and Garmin has not yet come out with a remedy to correct this problem yet. It should be out in a software update sometime in the future...............I did this and it corrected my problem immediately. The unit performs perfectly now, however, the accuracy is not as good, due to the lack of WAAS.......................
Dec 04, 2008 | Garmin MAP76 handheldS GPS Receiver
Screen goes blank except for a verticle streak
I had the same problem (blank screen, vertical line). After speaking with Garmin, I was told to make sure I was using the latest software version, and to turn off the WAAS function. Disable it for now, because the WAAS signal, coming from the satellite, has changed, and Garmin has not yet published a remedy to correct this problem. A fix should be out in a software update, sometime in the future, hopefully. I also did the software update, to the latest version 4.0. The unit performs perfectly now, however, the accuracy is not quite as good, due to the lack of WAAS. Good Luck!!
Nov 03, 2008 | Garmin GPSMAP 76S GPS Receiver
Screen goes blank except for a black line
I had the same problem with my 76S. Called Garmin to send it back for service. They said it was a problem with new WAAS signals that causes the freeze/black line. Disabling WAAS using menu/system solved it for now. They are working on a software update Real Soon Now.
Oct 29, 2008 | Garmin GPS 76 GPS Receiver
Garmin gpsmap 162 turns on, works for about two minutes, then a thin black vertical line comes across screen and screen goes blank with the line remaining. I have to unplug and start over. Same things...
Possible Solution found on google....
My old Garmin 162 chartplotter was mounted on the binnacle guard and served me
well for many years. Lately, it started getting very slow to refresh screens.
At times, it would shut down with only a black vertical line on the screen. On
our last cruise, the screen froze at a very critical moment. Too old to
repair, I bought a new Garmin 440, which I am very disappointed with, but
that's another story.
I read an article in the GoodOldBoat newsletter about the Department of Defense
making changes to the WAAS satellites that have caused problems in Garmin 72
and 76. Garmin's tech support recommended to turn the WAAS function off on
affected units. So I got out my old 162 and turned the WAAS off and it works
fine. To make sure it wasn't a fluke, I turned it off and on several times,
and it always slowed down with WAAS turned on. With it turned off, the
position error or accuracy, increases 1-2ft, not a big deal. I hooked the unit
up on my truck and drove around. Not a problem. Further reading indicates
that other brands of GPS are also having problems with the new WAAS
transmissions.
So if you are having problems with your GPS and it is new enough to have WAAS,
try to turn it off
Sep 28, 2008 | Garmin GPS
Unit shut down
I have run into the same problem and it may be related to the WAAS (Wide Area Augmentation System) feature. Try disabling this feature (under MAIN MENU / Setup). I used this receiver overseas (Asia and Europe) last year for 35 days straight with no problems. During this time WAAS was disabled as none of these satellites are visible overseas. The problem occurred intermittently prior to the overseas trip, and has reoccurred after returning. I was running into the same problem this past weekend and noticed the screen blanking out (with the vertical line) shortly after differential corrections were applied to the GPS signals. I disabled the WAAS and let the receiver run for over an hour. The problem did not return. Hope this helps.
Sep 25, 2008 | Garmin GPSMAP 76 GPS Receiver
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Screen Blanks
11-08-07
I had the same problem with an etrex Vista. I spoke with Garmin, they said that a recently launched WAAS satellite is interferring with some models (he mentioned it is the models with a black and white screen). Garmin tech support said that they're working on a software patch but for the meantime switch WAAS off.
Call Garmin tech support with any questions or to find out about the software patch, 1-800-800-1020
Nov 04, 2007 | Garmin eTrex Vista Cx GPS Receiver
Screen Blanks
SailorMan,
Contacted Garmin Tech Support and they verified the problem with the WAAS. They said the engineers were looking at the problem. Estimated the fix would be ready in 2 to 3 months. I turned the unit on inside where the unit could not receive any satellites then disabled the WAAS and the unit works without problems. It is just not as accurate.
Oct 19, 2007 | Garmin GPS 72 GPS Receiver
Garmin GPS III Logo
295 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
