Got new computer and printer won't connect - Computers & Internet
    Sergeant:
  • 352 Answers
There may be a compatibility issue between the printer and the new pc. Check the xp/vista compatibiliy list to see if your printer is on it. If not you may need to add a patch to make it compatible. Check the website of printer manufacturer and see if the offer downloads for drivers and patches: If you decide to try this follow the following instructions:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Posted on Oct 13, 2008
Cannot print off computer. says not connected. got a replacement used printer on ebay.same model . worked ok on my previous printer ?
Could be the printer is faulty or the lead. I have never found epson printers to be much use and have learned the hard way to avoid secondhand ones.
If it is a dual drive you could try using a parallel port and 2-way lead but usb is generally reliable and if your computer says the printer isn't there it is probably because it really isn't.
If the "found new hardware" wizard doesn't show up when it is plugged in...
You could try uninstalling the printer and then reinstalling it before actually connecting the printer but I advise against optimism.
Feb 20, 2015 | Epson Office Equipment & Supplies
Won't print. Power is on, cable attached, computer says it is going to print. Says there is no 2 way communication between the printer and ?
You must firmly insert the cables that connects b/w PC and printer or buy new connector. Or, you may reinstall the driver..
Oct 20, 2012 | HP Deskjet D4360 InkJet Printer
Canon Pixma 560 won't turn on
make sure all leads connecting to your printer have dust free secure seating
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you
might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click to update driver
hope this helps
Jul 28, 2012 | Canon PIXMA MP560 CLR INKJET P/S/C/F FB WL...
I installed new cartridges (Lexmark brank both black and color) and my printer won't work now.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 15, 2012 | Lexmark X5650 All-in-One InkJet Printer
Computer won't detect printer
  4. Reboot computer.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/nJ7AgN. Select your operating system, download and execute the file.
Feb 10, 2012 | Lexmark X1290 All-In-One InkJet Printer
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
Nov 30, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
Won't print
Check and see if the USB cable is connected from the computer to the printer and it is powered. The computer will detect a new hardware. You can If the drivers of the printer are installed
  1. go to start then printers and faxes if you are using windows xp
  2. an icon of the printer will be seen with the name of the printer
  3. you can right and set it as default if not set
Jun 27, 2011 | HP Officejet 5610 All-In-One InkJet...
My cannon pixma MP150 just won,t print or do anything, it is connected to the computer alright & the computer says that it is connected but it just won,t print or scan, can you please suggest anything...
probably you need to download the driver for windows 7 in the canon website.(www.canon.com.sg) if this doesnt solve your problem check the led and display of your printer. if the led blinks alternately in orange and green it means that your printer needs to be brought to an authorized service center for resetting and diagnostic.
Feb 13, 2010 | Canon Office Equipment & Supplies
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
