Question about GPS
My acer e300 travel companion is saying map not found how do i loud new maps to the device
  • 5 more comments
  • dslhobby Nov 10, 2008
    strange, for me also (happend also in october)
    strange, same problem also happend in october...
  • Brendan Reilly
    Brendan Reilly Dec 14, 2008
    its almost a conspiracy, i was ready 2 hop mine off the wall til i saw ur messages,
  • Anonymous Jan 11, 2009
    It seems the e300 (series) kinda like reformats my card without removing the contents. I had about 1.5 GB of maps on my 2GB card.. And now the device says I don't have any maps installed and there is 0.5GB space left on the card.
  • ChrisLar Feb 20, 2009
    Same problem here, think it was around October as well. Maybe licence related?
  • Anonymous Apr 08, 2009
    and how can we solve this problem?
  • debs1102 Apr 22, 2009
    My Acer e300 is also telling me map not found what do I do not very technical at the best of times this is really frusterating
SOURCE: TOMTOM ONE 3rd edition NO Maps found
noob
Posted on Sep 09, 2008
SOURCE: no maps found on tom tom one new edition
this problem just happened to me. i'd just bought my new tomtom one and tested it on the journey home. all was well and i was really impressed. that was until I got it home and went to update it to get the latest maps for my area. I installed all the software as instructed by the on screen prompts and downloaded the latest updates. i then went to turn the device on, and was greeted by a message stating ''no maps found!''
after almost two hours of complete frustration, i then tried probably the easiest solution anyone could think of:
First of all, connect the device to your computer and close down tom tom home. (making sure it isn't even open in the system tray).
Now, open my computer and find the device. it will be labelled as a storage device (mine was drive G). Open it up and find where the maps are saved to. Something like, UK and Ireland, or something similar relating the place you live. Once located, delete them manually.
Now, reopen tomtom home and go to tools. Click ''use latest map guarantee''. It will then download the maps again and install them onto the device.
Next disconnect using the option 'disconnect device'' from the device menu.
Finally turn on your tom tom if it doesn't automatically, and you should be back in business. This worked for me, after trying numerous way more complicated solutions I found in various forums.
Hope it works for you too!
xx
Posted on Jan 01, 2009
SOURCE: garmin nuvi says, "no detailed maps found to support routing."
I am very sorry to hear that you are having problems with the unit. You
may need to switch the unit on and press and hold the centre of the
screen until the message ?No detailed maps? message disappears.
If your map detail is missing, then the map information may have been
disabled. To check to see if the mapping has been disabled, follow the
steps below:
From the Where to? and View Map page, touch the Spanner icon, settings
(Tools).
Touch Map.
Touch Map Info.
The unit should display the name of the map that is loaded to the unit.
The box in front of the map name should have a tick in it. If it does
not, touch the box to place a tick in it.
Then please test by searching for an address.
Posted on Apr 02, 2009
E61N
  • 515 Answers
SOURCE: Brand new TomTom says no maps found after I tried to update
http://www.tomtom.com/support/index.php?Language=1&query=no+maps+found&FID=9838
Posted on Apr 13, 2009
  • 21 Answers
SOURCE: Updating maps
Press the power bar in the upper right c orner for 10 sec. and You will go into servicemood. Ther You can reset and run memorytests, Otherwise Use the lttle pihole under the tape on the bottom side
Posted on Nov 10, 2009
I keep getting a message on my tomtom one saying no map found. i`ve formatted the sd card many times but cant get map up. can you help please?
If your device is saying no maps found, what you need to do is to download new maps on the SD or on your device. That way your device should be able to read maps, or better still, you can reset your tom tom by using a paper clip, to press and hold the reset button.
Or you can hold the power button for about 15 seconds, that way the unit will restart, once it restarts, then you will be able to access your maps and other things on your device.
Hope this information helped you solve your problem.
Jan 05, 2011 | Tomtom ONE GPS Receiver
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
My garming says no detailed maps found that support routing what can i do to fixed
Press Tools, then press Settings, then press Map, then press Map Info. There should be a tick beside the map name. If not press the map name and a tick will appear. The problem should then be solved.
If that doesn't solve the problem it may be because the map is locked. If so go to www.garmin.com and if the satnav is registered click on My Garmin, then on Maps where you'll find the unlock code. If the satnav is not registered you'll need to connect it to the computer and register it first.
Jul 30, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
No detailed maps found that support routing
reason being you may not have an SD card inserted with maps otherwise your maps have been deleted. try running the map update on the unit and it should reinstall the maps for you... if the SD card is not missing you may have a faulty SD card or SD card slot.
May 18, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
Tomtom says "No maps found"
It could be the new map is not registered to work with your device.
Every tomtom device has a unique ID wich must be used to register the new map.
If you download the map from tomtom site with your device attached through TomTomHome it must works.
Jan 01, 2010 | Tomtom ONE XL GPS
I have an acer e300 and it is saying map not found how can i solve this
If you have loaded Destinator Console onto your PC from the original disc that contains the maps simply attach the SatNav to your PC and take the following steps
1. From "My Computer" identify the SatNav device from those listed in "Items with Removable Storage".
note. if your PC doesn't recognise the device try putting the memory card into a camera that you can connect to your PC.
2. Right hand click the relevant icon, and select "Format" from the drop down menu.
3. From Start Manu, All Programs - select Navigation (this will depend upon how you origianlly loaded Navigation) then select Destinator Console.
4. In the bottom right hand corner of the subsequent window there should be a box named "Target Device" - click "Change"
5. From the pop-up window select the device you have just connected. This device should now appear as the target device and it will show how much available space is on the disk.
6. Finally from the top left hand box named "Standard Maps" select - UK_Ireland-177.0 MB and click on Install/Remove Maps.
Sep 22, 2009 | Acer n50 Pocket PC
While traveling to Nova Scotia last week, my Garmin Street Pilot c530 was telling that i was on an unpaved road, but i was on route 2 in New brunswick Canada
Don't believe everything you see on a GPS. Garmin does not update their maps as they should; I found this even after I purchased their map update. I drove 48 states in a big rig, over many new roads not found or shown on the Garmin maps. My streetpilot usually went into a hiccup mode, recalculating -- recalculating -- recalculating. All the while, it tried to get me to detour on whatever spurious local roads happened to show up along the way.
Aug 07, 2009 | Garmin StreetPilot c530 GPS Receiver
My Garmin nuvi says ''maps unavailable''
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear for the following reasons:
  2. Select myMaps
  3. Select Manage Maps
  4. Select the device from the drop down menu
  5. The unlock code is located under the "Maps installed on this device" section
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Enabling maps on the GPS device:
    1. Touch the wrench icon on the Where to/View map screen
    2. Touch Settings
    3. Touch Map
    4. Touch Map Info
    5. Select the checkbox next to the maps to be enabled on the device
Mar 21, 2009 | Garmin nuvi 260W GPS Receiver
GPS Logo
2,410 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
