Question about Whirlpool GEW9250P Electric Dryer
Dryer won/t work
My control lock light is lit. dryer will not work
  • janiceireid Oct 14, 2008
    Same problem. Tried unplugging for  5 minutes, then a few hours, then more than 24 hours. Nothing has helped.
  • cphcwh53 Oct 15, 2008
    control lock still on won' t work
  • 750 Answers
Hello chuhunghuang
Welcome
You said, your control lock light is lit. dryer will not work
Let me know how it goes!
Try ,
Pressing STOP/CANCEL to clear the display.
If this does not work.
pull the plug for 5 minutes or if you can't reach the plug you can turn the power off form th breaker for 5 minutes.
This should reset the system.
Bless You huuum
Please leave a rating before you leave the site!
Posted on Oct 13, 2008
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 | GE Dryers
Tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer duet... the control lock light is on and the dryer won't work
this is the car and truck section - you may want to repost this in the dryer section
Aug 28, 2012 | Cars & Trucks
"Controls Locked" light lit, unlock button has no effect
Have you tried unplugging the machine for awhile to let the board reset?
Nov 14, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Gas duet. Mod: GGW9250PWO Ser: MR3604435. Front panel under Status: "Control Locked" light is lit..nothing else works, including Control On button. Dead. Can the dryer be reset??
is the other lights DIM(partially lit)?
If so it could be one of the following.
1.) Intermittent ribbon cables between the control board and the Interface board (one with the buttons) Reseat all four cables.
2.) faulty control board.
3.) faulty Input board.
Nov 11, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
The Dryer says "Control Locked"
Try pressing an holding the "End of Cycle Signal" button on the front panel in for 3 seconds. This button is used to lock/unlock the control panel to keep small children from manipulating the controls when the dryer is not in use. A designed safety feature. If this does not work for you, please post back and let me know. I hope this helps you.
Jun 25, 2009 | Whirlpool GEW9250 Electric Dryer
Control locked light is lit not allowing any operation of the dry
Did you try unlocking it by pressing on the "End of cycle" button for 3 seconds.
If that doesn't solve the issue, it might be the control board (user interface) might have gone bad.
I had the same issue with my GEW9250 and I had followed these steps to repair the board. I am not sure if it works for you, but you can try it out.
Open the User interface control board
Then remove the PCBS (the green control boards)
Check the led bulbs, for me one of them is fried. You can use volt meter to test it.
Remove the bulb(s) that are fried (not working)
That should fix it...
Apr 05, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet washer dryer, Dryer is stuck on control lock
look to the far right buttons labled control lock, hold it in for 3-5 secs, to unlock
Mar 23, 2009 | Whirlpool ET8CHEXSQ Dryer
Controls locked
Hello
Welcome to Fixya
My name is Huum,
To disable the control lock, hold the OPTIONS and SELECT buttons at the same time until the control lock light turns off.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 23, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool GEW9250P Electric Dryer Logo
146 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
