Question about Singer 2250 Tradition
Singer 2250 Jammed!! My write up...
My wife just bought a new Singer 2250, she's used it about 2 or 3 nights a week for the last month. Well just last night she was sewing an apron when all of the sudden it sounded almost like a machine gun action, without the bang of course, but she was worried about it. She stopped and tried to spin the wheel by hand and it would stop rotating in two places along it's full 360 degree travel. I am not one to just box things up and give it to someone else to deal with, so I removed the covers and found the problem. (Please excuse the terms since I do not work on these machines professionally) The needle shaft has a fixed pivot point with an arm that is attached to the flywheel, one end of that arm is connected to a link on the flywheel with a splined and indexed shaft that should not turn during normal operation. The indexed shaft has a set screw that prevents it from turning, that set screw had worked itself loose and allowed a tiny bit of movement which caused the arms to swing out past their normal operating range and was impacting against the frame and brackets. Explained in the next few pics I wrote up a quick explanation to help understand the problem and solution, hope this helps....
1. http://i176.photobucket.com/albums/w170/albertophjr/Impact1.jpg
2. http://i176.photobucket.com/albums/w170/albertophjr/Impact2.jpg
3. http://i176.photobucket.com/albums/w170/albertophjr/Impactfix.jpg
So that was my story, I searched on this site and could not find anything similar so I'm hoping my write up helps anyone with a similar issue. If I am posting this in offense to anyone or procedures please accept my sincerest apologies. Thanks! Al
  • bedders81
    bedders81 Jan 08, 2012
    Mate - whoever you are, wherever you are, you are a LEGEND!!! Would never have been able to fix my machine without your root cause analysis and pictures. Awesome. Be happy you've made someone happy!
  • Kelly Aug 10, 2012
    I am so thankful that you posted this with pictures! AMAZING! I would not have been able to fix without it!! Thanks so much!
  • 6 Answers
SOURCE: sewing newbie needs help
I haven't seen this machine before but in general, the most common problem is the bobbin. Either it's not wound correctly, poor thread or put into the machine wrong. Other wise wheel number 3 looks like a stitch selection dial to me. Try turning it and see what happens to the needle. When you change from straight stitch to say zig zag it would move right or left. On dial #2 isn't there some writing? What does it say? In general there is no need to change the tension of the bottom thread unless you are sewing extreme fabrics such as leather and silk. What is the range of numbers on the dials? Try putting them in the middle of the range to see if it has an impact of the quality of the stitch. My bet is on the bobbin thread not being correct. Try taking it out and putting it in so that the thread is traveling into the bobbin case from the opposite direction. I'd try this after taking out all of the thread (if it came with the bobbin) and reloading it. A straight thread on the top happens when the top thread tension is too tight if I remember correctly. It is stronger than the bottom and doesn't move so to speak.
Posted on Feb 17, 2008
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
  • 323 Answers
SOURCE: My Singer Quantum CXL seems to be jammed
Go to this site
http://www.singerco.com/support/us_warranty.html
search for a Service Center in your state, call them for how to send in the machine and how much it will cost for repair.
sewman7
Posted on May 05, 2009
  • 136 Answers
SOURCE: Singer 7422 beeps and all lights come on when peddle is pressed.
There are several sensors on this machine that just start causing the machine to malfunction for no apparent reason. One is one the bobbin winder, one on the buttonholer, and one under the machine which workd with the feed. It is far from an exact thing. If you can get to them, sometimes loosening them, moving them about then tightening them seems to 'fix' them. Sometimes not. Wish we could be more exact in explaination but sometimes we will move them repeatedly then they start working. It is hit and miss.
Posted on Sep 08, 2009
bargainbox
  • 1388 Answers
SOURCE: my 8280 modle singer: I sewed a zipper for a
If you are not able to free this easily, you really should consider taking it to a service technician to look at it in case you do more damage to the needle bar and elsewhere trying to fix it yourself.
I can't move the needle clamp to change the needle on new Singer 2250 Traditional. Can you help?
Here's the manual with the instructions:
SINGER 2250 Instruction Manual Inserting And Changing Needles
The screw that holds the needle in place also has a slot where a screwdriver can be used to apply extra pressure.
May 07, 2017 | Singer Sewing Machines
Machine fails to operate
Ooh, do not turn the handwheel in reverse...
First, make sure your machine has not been set to wind a bobbin. When that is the case, the needle is immobilized during bobbin winding so that you do not accidentally sew over your hand or something else. (Consult page 18 of the owner's manual.)
The machine is less than a month old. If there is something seriously wrong, contact the manufacturer. I should still be under warranty.
http://www.manualslib.com/manual/364482/Singer-2250.html?page=25#manual
Apr 30, 2016 | Singer 2250 Tradition
TRADITION 2250 SINGER SEWING MACHINE HOW TO ZIG ZAG
From the pattern selector (the bigger dial), select the zig-zag stitch. Then, using the stitch length dial (the smaller dial), adjust the stitch length. The closer your stitch length is to "0", the more dense will your zig-zag stitch be.
Sep 04, 2014 | Singer 2250 Tradition
Serenade
Personally regret to hear a kind of problem that you have on the machine, however the other customers are enjoying and benefited from it for one reason they were given demonstration before/upon purchasing the 2250. If your new machine does not include a demo cd, I suggest you visit singer site thru google "singer 2250 sewing machine" and you may be able to download the video on how to use the machine. Hope that can be useful.
Jul 23, 2013 | Singer 2250 Tradition
Does the 2250 Singer Sewing Machine take a walking foot, if so how much are they, and where can I buy one?
You can buy walking feet for all machines but you may have to get that special order from Singer
Sep 14, 2011 | Singer 2250 Tradition
Hi - bought a Singer Serenade 2250. can i get an overlock foot for it? thanks
Yes, go to Amazon.com and buy one from them for about $12.
Apr 15, 2011 | Singer 2250 Tradition
I am sewing stretch jersey and my needle keeps breaking with a terrible noise - I have a singer 2250? any ideas?
you need to use a stabilizer because the needle is pushing the material into the bobbin shaft and jamming it. Clean it out and oil your machine. Insert a new needle and totally rethread.
Feb 27, 2011 | Singer 2250 Tradition
My daughter's girlfriend bought this singer 2250 and I can't get the bobber threaded correctly
Go online and download a free manual at www.singerco.com and you can enlarge the diagrams to see it. You can also print it if you want. Good luck
Oct 08, 2010 | Singer 2250 Tradition
I've just bought a Singer Serenade 2250 but the instruction manual is all in Spanish. Don't really want to pay £13 for an English one, is there anywhere I can download a free one?
you can find it on the singer website, just type the model number and download for free: http://www.singerco.com/accessories/manuals.html
Aug 06, 2010 | Singer 2250 Tradition
Jams
I make flannel square quilts for babies, it is a nightmare itself. It makes a lot of lint in the bobbin case and under the face plate, try prewashing the fabric before using it and clean out the bobbin case frequently while sewing. When i dont prewash it, i just open the bobbin area and blow the cotton dust out with my breath or i use the small brush to clean it out
Dec 12, 2009 | Singer 2250 Tradition
Singer 2250 Tradition Logo
1,462 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
