Question about LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher
Top rack is not level. Glasses and cups roll forward
  • 423 Answers
I assume that the bottom rack is level and the upper rack is not.
On the LG dishwashers, you can remove the upper rack by removing the little gray clip at the front of the rails. Each will fall off in your hands. You can then pull the basket out.
Place it on the floor and confirm that all wheels roll properly and all touch evenly. Resolve any problems on the rack via LG service parts.
Inspect the rails still inside the dishwasher, confirm that they are paralel and level.
Replace the upper basket carefully, making sure the wheels all slide into the rail evenly.
Please update me on what was done to finally resolve the problem.
Posted on Mar 31, 2009
My dishwasher doesn't clean the all the dishes, esp on top rack
Check the jet holes on the sprayer arms. The outside holes usually plug first from calcification and centrifugal force causing only the center areas to clean. Remove these arms and shake out all of the "little white rocks" and then run the machine empty with a de-calcifying cleaner.
Sep 15, 2014 | Bosch Dishwashers
Kenmore dishwasher ultrawash debris on glasses
Fill the soap cup with vinagar and run it while its empty.
Mar 09, 2012 | Kenmore Dishwashers
I have a whirlpool diswasher. The dishes in the top rack do not come clean. Also I can see gritty sandy matter on the glasses and inside of the diswasher walls. I use the r inse agent.
Rise Aid is good to use however it sounds like you have another issue. Here are a few steps you can take to get your Dishwasher working:
  1. Check to see if your getting water to the top rack. Test this by runing a cycle and open the door and place a cup right-side up. Close the door. It should fill the cup up to the top with in 20 seconds. If it does you have to clean out your dishwasher with a cleaner like Dishwasher Magic.
  2. If the cup doesn't fill to the top then you have a circulation problem. Either your not getting enough water Or the filter in the pump is clogged. Water should cover the bottom of the dishwasher tub and then just reach the float.
  3. If your going to clean the filter/chopper you need to take out the racks and tube and sprays. And then take the screws out of the top. You have one screw for the filter/chopper housing take this off and clean it. Pull the blade forward and up. Do the reverse to install it should just stamp back on the bearing.
Good Luck. Please take a minute to rate your experience.
Have a great day!
Dec 10, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
The glasses and cups in the top rack have a sediment on them after the cycle is over. The dishes in the bottom rack are fine. Thanks
open the door and look inside the top of machine.
might be a rubber plug there. if plug is not water tight
or missing water will go thru and hit countertop. wet wooden countertop
equals sawdust like material thru to dishes
Oct 12, 2010 | GE Dishwashers
GE Potscrubber 650 does not drain and top rack not washed
your not draining the washed dirty water out. its leaving crud on dishes. check drain pump and drain line for restrictions
Jun 22, 2009 | Dishwashers
Top rack dirty with debris not on glasses when I put them in the dishwasher in the first place. feel like food particles may be spraying out of spinning mechanism.??
put a cup upright in your top rack. see if the water is filling it up give it about 2 minutes. If no water is getting up there let me know.
Jun 04, 2009 | Dishwashers
TOP RACK DOESN'T RINSE
I would suggest you buy some CLR and run it through a full heavy cycle with the washer empty. Be sure to put it in all dispenser areas and sprinkle about 1/4 cup into the washer before starting.
Feb 16, 2009 | GE 24 in. Profile PDW7800 Built-in...
Top rack not cleaning
load 4 cups right side up in all four corners of top rack, move all wash arms to a known positon(pointing foward just want to check there rotaiton). start diswasher, when you hear it start washing give it 30 sec or so andpop it open try to focus on middle spray arm when opening, shlould be turning quite well. and glasses sould be starting to fill. at least thats how it SHOULD operate
Feb 25, 2008 | Dishwashers
LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher Logo
349 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
