Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Blinking 12 and I have no manual to indicate what that means.
I have a Rinnai energysaver 1004f. It came with the house that I purchased. I do not have the owners manual and it keeps blinking 12 in the set temp/room temp box. Can you please let me know what this indicates?
  • Anonymous Dec 22, 2008
    turns out i wasn't out of gas...but deep blowing snowdrifts had covered the exhaust pipe leading out of my basement. once i dug that free and turned it on and off a few times, it began running again just fine. good luck!
  • Anonymous Feb 20, 2009
    Same problem, think I was just low on fuel.
A 12 code indicates a "Flame Failure" check that the gas valve on the right side of the unit is turned on. If you are using propane have you confirmed that the tank has fuel? You may be able to download the owners manual from the Rinnai website.If not you can contact themat 1-800 621-9419.
This is a great heater and the Rinnai people will be helpful. good luck!
Posted on Nov 08, 2008
What is the average expected lifespan of the Rinnai Energysaver 1004F
http://www.rinnai.com.au/media/4357111/05604_Rinnai_Energysaver_Brochure_WEB.pdf
At the end of the document, notice there is a 10 pro rata warranty on the heat exchanger. The fact that they would offer you any money at all on a failure nine years into domestic use suggests they consider that part rather dependable. I have no access to Mean Times Between Failures on equipment. Such documents vary in calculations as what is considered a critical failure must be defined.
May 31, 2017 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai energysaver 556f manual
Here is a link to the 556FTR from Australia.
They are all pretty much the same. The US site has similar info. Just google Rinnai. Open the site, go to resources tab and click downloads. The manuals are easy to locate.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Energysaver/556&431FTR.pdf
Jul 27, 2010 | Panasonic Heating & Cooling
Where is the pilot light on Rinnai EnergySaver 1001F
If you smell gas in a Rinnai you have a big issue. This heater is what is called a direct vent heater with an electronic ignition so the combustion chamber is sealed and the smell of gas is an indication that you have a gas leak. Please call a professional today.
Oct 13, 2009 | Rinnai Heating & Cooling
Rinnai 556 ftr keeps flashing code 12
Hi
Thanks for using FixYa. Error code 12 on a rinnai 556ftr means Flame failure. Check gas is turned ON.
Also see this error manual.
Please refer to this user manual for more details --
Rinnai 556ftr User manual
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Rinnai EnergySaver 556 Air Conditioner
I have a Rinnai Energysaver 1001 without a manual, we have just moved into our new house and manual not left. Where can I get manual from? TA
all energysavers have the same controls so any manual will do. www.rinnai.co.nz navigate to Tradesmart, space heating, energysavers.
Jun 13, 2009 | Heating & Cooling
I am needing an instruction manual for rinnai energysaver 556/FTR as have purchased and moved into property recently and am having trouble operating the heater and am concerned with a red filter light that...
www.rinnai.co.nz
navigate to tradesmart, space heating, energysavers.
Red filter light means the filter is blocked.
its located directly on the back of the heater and the wall spacer, from the control panel, its about 4 inches back.
Pull it up, clean reinstall
Apr 27, 2009 | Heating & Cooling
Rinnai Energysaver 1004F on indicator light is red (usally green)
If its not producing heat, yep! If it is, it indicates that there is an error code stored in memory.
Feb 18, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai energysaver 1004F
Sorry friend!
I think this is it.
www.rinnai.us
Feb 13, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
586 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
