Question about Whirlpool LER7646E Dryer
Whirlpool LER7646E will not stay running
I can hold down the start button and it will run. When i release the start button it stops running.
I was told to replace the HEAT RELAY (3405281)or the Module Broad, but the problem is that 48VDC is not present on the motor relay.
Posted on Oct 13, 2008
Why want this dryer stay on ?
you have a bad belt switch,if the dryer stays running while you hold the start button on and stops when you release the button its the belt switch part WD21X10261 i've seen this a few times,go here and look at part 803 this is the bad part.
www.searspartsdirect.com/model-number/DPXR473EW0WW/0432/0151200.html
Oct 03, 2017 | GE Dryers
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Dryer won't stay running
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
Lightning hit our house a month ago and the dryer was running. It stopped and now the start button won't stay engaged l We have to push the button to make it run and tape it in the run position,
your missing the voltage from the control panel timer to energize the relay to keep it energized after you push it to make it start,you need to trace this back to the control panel timer possibly thru a resistor that could have burned open due to power outage and probably replace
Nov 17, 2009 | Whirlpool LER7646E Dryer
Whirlpool 110 electric dryer will not keep running
When you press the start button you complete a circuit bringing the juice into your dryer to run the motor the igniter or heating elements and what ever else goes whee when your dryer is drying. So if you press the button to complete the circuit then when you let go of the button it would stand to reason that it break that flow and shut it all down. However in a dryer there is something of a centrifugal switch that kicks in and keeps that circuit open and flowing with juice once the drum begins to turn and you let go of the button. That's why in a normal situation if you don't hold the button down long enough the dryer will cut right back off or if you open the door to the dryer to throw something in and close it before it quits turning it will stay running. Sounds like you could add this centrifugal switch to the list of possible culprits in this mystery. O7OUT
Jun 06, 2009 | Whirlpool LER4634J Electric Dryer
Won't run. Can hear clicks when changing settings, but won't run when push start button.
Check the door switch for continuity.
Remove the rear panel and check the thermal fuse attached to the exhaust vent on the lower left side. It is 1 and 1/2 inches long by 1/2 inch wide and white in color.
If it is blown you must correct the air flow problem also.
Apr 29, 2009 | Whirlpool LER7646E Dryer
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Whirlpool Dryer (LER7646E) not working
check your power cord and the receptcal if you see any discloring on pronges of your power cord you'll need to replace cord and the receptical it could be shorting out
Dec 13, 2008 | Whirlpool LER7646E Dryer
Dryer wont run
defectvie timer,,,onthejob
Dec 07, 2008 | Whirlpool LER7646E Dryer
Dryers Logo
231 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
