Cell Phones Logo
Anonymous Posted on Oct 13, 2008
I have a n96i mobile phone from china. i havea problem with the phone i can make 3 or 4 phone calls then i cant make or get any more calls but i have a full signal and i can send and get text messages . network failed comes up on the screen when i try and make calls .
  • 17 more comments
  • Anonymous Oct 13, 2008
    it is a nokia look a like . it is not the real deal . if you look closely enough you see the i is a small L . as i said it has full signal to my network and i can get text messages incoming and out going at all stages but after i make 3 or 4 phone calls 'network fail ' comes up on the screen .
    no its def not a battery problem !
    u mean restoring factroy setting ? i have tried that but still the same problem. as i said i have a full signal and can send and receive texts but calls ! i seen a few programs like chinese cocktail , infinty box but price wise there a good few $$$'s . its a real pitty because the phone looks class even for a fake /copy . thx for the help so far guys !!!
    anyone any other ideas ?
    even if it is a fake or copy ?
    i would have to send it back to china and thats not to say they would correct the problem ! anyone who buys from anyone in china would want to check if they do return or money back options !
    i live in ireland would this be possible ?
    so no way to fix it myself ?
    what they tell me is that it is quadband and bear in-mind i can make 3 or 4 calls before network fail comes up
    what about chinese cocktail ? or another program like that to flash the mobile . i have tried the engineering code *#3646633* but no joy cant get into engineering mode
  • Anonymous Oct 15, 2008
    i have full signal
    it will work just not not all the time or after 3 or 4 calls
  • Anonymous Oct 18, 2008
    im thinking its network problem its working on some and not others
    ic ?
Anonymous
Level 2:
Scholar:
  • Expert 84 Answers
  • Posted on Oct 18, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
84
Questions
0
Helped
18831
Points
199
On the main screen type in:
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin# \
*#7328748263373738# resets security code.
Default security code is 12345
Change closed caller group (settings >security settings>user groups) to 00000 and ure phone will sound the message tone when you are near a radar speed trap. Setting it to 500 will cause your phone 2 set off security alarms at shop exits, gr8 for practical jokes! (works with some of the Nokia phones.) Press and hold "0" on the main screen to open wap browser.
if the commands dosent work on your phone may be your phone is not a Nokia Phone sorry to say.....
thanks.
jason
Level 3:
  • Master 905 Answers
jason
Master
Level 3:
Answers
905
Questions
8
Helped
320873
Points
2511
Or after the phone has been on for a while , the circut that detects connection to the network is getting to hot and not detecting a connection , so after the phone has been on for a while a chip that controls the connection is failing. turning off the phone for about 15 min. may enable you to use it again , but only till the chip heats up again then it won't connect again
how long before you can make calls again?
Anonymous
Level 2:
  • Expert 51 Answers
  • Posted on Oct 15, 2008
Anonymous
Expert
Level 2:
Answers
51
Questions
Helped
7714
Points
123
I think this is surely a software problem, since you hav a china phone , it could make a problem like this... you contact to your dealer ,say him to change its software .. it will definitely work again.....
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 281 Answers
  • Posted on Oct 13, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
281
Questions
Helped
70489
Points
577
The problem is from the antenna, try to change it after that everything will be fine
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 435 Answers
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
435
Questions
0
Helped
164545
Points
961
Hi, Its the problem with GSM bandwidths.
Which country are you trying to use in?
The signal will be full but the phone wont work. and yes, the SMS work...
Local China phones would work on European bandwidths which do not work in country like USA.
If the phone that you own is Quadraband it should work anywhere.
But according to your problem, it doesnt sound to be quadraband and it is a bandwidth problem. I am sure about this, since I too had this problem, which cannot be solved (coz the hardware is made like that).
    You may want to dial your phone service provider to confirm the bandwidth match or mismatch.
Anonymous
Level 2:
  • Expert 81 Answers
Anonymous
Expert
Level 2:
Answers
81
Questions
Helped
40272
Points
196
Hi.
If this is a china made mobile phone then i would advice you to get it to your phone dealer
to get it checked.
Another solution could be to format your cell as this could be a virus problem.
Hope this helps.
If you have any other question do feel free to ask me.
Regards
Faraz
Anonymous
Level 2:
Sergeant:
  • Expert 208 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
208
Questions
Helped
119506
Points
604
The problem is with the network and not in the mobile........
Dial to your Customer care no and tell your problem.....
They should fix it up...
Anonymous
Level 3:
President:
  • Master 1,952 Answers
Anonymous
Master
Level 3:
President:
Answers
1952
Questions
0
Helped
697740
Points
5792
Have u get these problem in other network simcard also?
  • 2 more comments
    oh ho nokLa china piece mobile ah? yea no other go yaar...give it to local service man and get repaired that...else sell it to some one else...u surely get problem frequently hereafter..u cant solve this problem by urself yaar...i think the problem in ic...better u repaired with some local service man...don invest more money in it..its useless oly...i suggest this to u because my friend also face the same problem..he too did the same wat i told to u..
    thanks for using fixya..
  • Anonymous Oct 14, 2008
    its an china piece..so it wont work in it yaar
    check all ur ic //
    intrgrated circuit(ic)..its a chip
monk3ybidzness
Level 3:
  • Master 1,879 Answers
monk3ybidzness
Master
Level 3:
Answers
1879
Questions
Helped
763446
Points
4784
Does rebooting the phone helps?
we're looking at a hardware design flaw here, you're lucky you can even get 3 calls. don't ask how many calls i can make.
Anonymous
Level 2:
Scholar:
  • Expert 136 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
136
Questions
0
Helped
48124
Points
309
Replace the battery its a battery problem in your device.
and get checked your phone memory.
thanks.
    the chinese company normally do not provide any garantees .as there devices depends on your luck .some times it work sometimes it dont.
    still you can try.
    thanks.
Anonymous
Level 3:
Genius:
  • Master 1,689 Answers
Anonymous
Master
Level 3:
Genius:
Answers
1689
Questions
8
Helped
567292
Points
4681
Just to verify malonejamie, is this an original Nokie made in china or a china cloned n96i? http://www.nokian96i.com/
becuase if not then it sure looks like you may need to have the phone updated...
    try to go to a local cellphone repair shop, and then have them reflash / reformat the operating system of the cellphone, usually third party softwares manuf designs a compatible OS for clone phones. this may cost you a little more around 30 dollars, but it may be worth a shot.
1 Related Answer
Anonymous
  • 23 Answers
SOURCE: phones
i think you should find out whether the problem is with the mobile or with the network.. try putting the sim in some other mobile or some other sim in your mobile...
Forgot phone lock code china
try the last 4 numbers of your phone number
Mar 24, 2014 • Cell Phones
1helpful
I have a n96i from the uk and i need the unlock code for t mobile
download nss and change the product code worked 4 me
8helpful
How to reprogram nokia 6300 china hone
Hi buddy,
If u r trying to apply the nokia 6300 themes into ur 6300 china mobile then sorry to tell u that there are no themes available for china mobile only the in-built themes can be used and everything is different in the china mobiles.
I hope this will help u.
N96i china phone how to insert themes??
There is no suitable themes for china
1helpful
N96i tv china phone
For any china mobile software like N96 drivers and others, just check chinamanuals.com
1helpful
3answers
I want china mobile N96y software
hpw can we run games on zetel n96y mobile
CECT P168 No Service
i) first ask the service provider(AT&T) whether they are supporting china mobiles, since some service provider are not supporting china mobiles(since all china mobile ar having same IME code), this is making some china mobile to banned in some countries....
Thankin you
M. Sridhar
Phones
4answers
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
