Question about Frigidaire Kitchen Ranges
Model FGFL87DSG error code F13 - Frigidaire Kitchen Ranges
  • MIKEC785 Nov 11, 2008
    I TURN THE BROILER ON AND AN F13 CODE FLASHES ALONG WITH AN ANNOYING ALARM. I WAS TOLD TO REPLACE THE E.O.C ELECTRONIC OVEN CONTROL. BUT EVERONE SAID TO REPLACE THE CLOCK/TIMER. 198.00 GUESS JOB IS NOT FOR ME.
    THANKSGIVING IS JUST AROUND THE CORNER AND IT MY FIRST TIME GOING TO HAVE THE PARENTS OVER FOR THE HOLIDAY.
    I DO NOT MIND BUYING IT IF THATS WHAT I NEED.
    THANKS MIKE.
    Sergeant:
  • 409 Answers
the F13 error is related to the clock. this error can occur when the clock looses communication between the keypad or any of the sensor in the stove, including the heat probe. sometimes resetting the power will fix the problem.
here is what you can do:
disconnect power to the stove completely and flip the corresponding breaker on and off on the breaker box.
wait 30 seconds and than turn everything back on.
if the problem returns after power-up, replace the clock.
let me know if this helps.
Posted on Oct 12, 2008
I WAS TOLD THAT THE F13 CODE WAS A SHORT WITH THE E.O.C ELECTRONIC OVEN CONTROL. SO I WAS TRING TO FIND IT AND THEY ALL SAID TO ORDER THE CLOCK UNIT.
198.00. I SAID WOW. BUT IT ALL SEEMS TO BE THE SAME, THATS ALOT OF MONEY FOR GUESSING. AND IT LOOKS FARLY EASY TO RELACE
Posted on Nov 11, 2008
F13 and F11 codes pop up
F13 is
Dispenser Circuit Error
If the dispenser motor is not able to be driven to it's proper position.
Check mechanical linkage from dispenser motor to the top of the dispenser
Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
Check Dispenser Motor
i snagged this answer from another site
i think its a worn bit of plastic
as it becomes britten when not always wet
much like a boat out of water
Mar 05, 2015 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
What is error code f13?
The F13 fault code on this type of range indicates that the EEPROM (Electrically Erasable Programmable Read-Only Memory) on the control board is bad. This can be caused by a power surge or glitch through the electrical lines. You can try to reset the control board by completely unplugging the range (or shutting off the breaker) for 5 minutes. If the error code returns after plugging the range back in, then the control board for the range will need to be replaced.
Feb 05, 2015 | Thermador C301U Electric Single Oven
Frigidaire fault code f13 kitchen range what does that mean ?
Thank you for your inquiry, raymond bouley!
I understand that your Frigidaire range is displaying an error code of "F13". An "F13" error code typically stands for a bad EEPROM (Erasable Programmable Memory) identification or check sum error. The best way to clear this code is to disconnect power from your range for roughly ten minutes. If you continue to experience an issue it could be a possible that you have a faulty board or wiring harness. I would then recommend having a professional out to perform a diagnosis on your range. Hope this helps. -Matt
Jan 13, 2015 | Frigidaire Kitchen Ranges
F13 code
Hello friend, thank you for your post!
Based off the information you have provided your question is under an "F13" error code but you also stated that it is showing you an "F1" error. I have researched both error codes for you. "F13" usually indicates error identification, which could be an issue within your control board. "F1" typically can indicate that the range has detected an issue with the runaway temperature (overheating). Both codes could be corrected with a reset, which you can do by flipping the household circuit breaker for roughly ten minutes. If that does not correct the issue I would recommend contacting a professional. I hope this is helpful. -Matt
Aug 07, 2014 | Frigidaire Ovens
I have a sears kenmore elite slide in range model number 790.46613500 that has a f13 err can anyone help with this
Unfortunately, the F13 error indicates that the oven control has failed. First unplug your range and wait 30 seconds or more to reset the code.
If the error recurs, this part will need to be replaced. See http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Range-Parts/Model-79046613500/0583/0124160/R0507023/00001?blt=06&prst=0&shdMod=79046613500 for the parts list.
I'm not exactly sure if your unit needs part 97 or 97A.
I hope this helps.
Dec 08, 2012 | Kenmore Elite Sears & Other Brands...
Error code F13 Bauknecht washer front loading
error codes washer machine bauknecht f13
Nov 15, 2011 | Washing Machines
F13 error code on Ariston washer dryer combo
Model ARMF 125 with same error code F13 how to fix please advise Thks
Nov 06, 2011 | Hotpoint-Ariston ARWDF129NA Washer
It appears F13 error
hi sir we have ARISTON washer and DRYER model : AQXXMD129EX its a error coming F13 please help me soon
Dec 21, 2010 | Ariston Technologies AWD120 13 lb. Washer...
I get a error f13 when i turn on broiler
http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx
Above are the codes and meanings.
The "F13" error code means "Bad EEPROM identification/Checksum error".
If reseting the power does not help then according to Frigidaire suggested corrective action the electronic oven control (aka EOC) has to be replaced.
- The part number for the EOC is AP3874704
Dec 13, 2010 | Frigidaire Kitchen Ranges
My kenmore elite electric slide in range displayed error and F13 and the oven won't turn on
i phoned Sears about error code f13 on a gas range, and was told to unplug the range for 30 minutes. i think she meant 30 seconds - to reprogram the microchip. i unplugged it for 15 minutes or so, then reconnected, and it worked.
Jul 09, 2008 | Kitchen Ranges
Kitchen Ranges Logo
1,031 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
