I keep getting message insert ribbon parameter card and below it resolve error to resume printing
  • taylah59 Apr 01, 2009
    I have the same message and i dont know what it means or wants me to do
The "ribbon parameter card" is a little chip that is delivered with every newly bought pack of ribbons. You need to insert this card in the fitting slot of the printer (at the backside I assume), and let the printer read the contents of the chip. Once finished, you can remove the card.
You need to follow this procedure for the printer to be able to work with the new ribbon. If you do not have the chip for that ribbon you can not use it.
Posted on May 05, 2009
Ribbon fault error
First of all sorry for the problem.
It seems to be a logic card problem . Kindly contact with lipi for replacement of the logic card.
Aug 16, 2012 | Tally T6215 Matrix Printer
My printer show the error 99 Ribbon Break/Jam but the ribbon is ok is not broken and i can not see some jam. Can you help me
Pls do the following:-
Ribbon Break/Jam
(PC Error Message No. 99, 108 and 109)
The Ribbon is not able to find the next panel correctly. Check for jams/breaks.
If jammed, clear the jam. If broken, repair by taping the Ribbon back on to the take-up core.
Press Resume to continue or Cancel to abort.
Thank You...........
Jul 26, 2011 | Fargo HDP5000 Thermal Printer
Cannon IP2000 won't print. Error message says ," waste ink absorbers full". What is best solution? Thanks
Follow the steps below to resolve the issue.
1 - press resume button and then press power button
2 - realese the resume button and press 2 more times then realese both
3 - press and release resume 4 times and power 2 times...
Regards,
Shawn.
Jan 31, 2011 | Canon Office Equipment & Supplies
I have a Fargo DTC550 Printer and laminator which i just got yesterday and after setting it up by carefully following every instruction in the manual it keeps displaying "Wrong Ribbon Installed" "An...
in windows 7 go to start>Devices and Printers> Right click on DTC550 and go to printing preferences then click the Device Options tab and click auto ribbon select
Oct 20, 2010 | Office Equipment & Supplies
SD card - memeory card parameter error
Some camera's, especially older ones, have a limit as to the maximum size of the memory card that they support. Look in the manual to see what the camera can support.
Jun 12, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Keep getting replace yellow ink cartridge error message
Where did you get the error message on printer or computer?
If you get the message on printer remove all cartridges and reinsert the cartridges and align the ink cartridges. If the alignment page prints successfully then the problem is resolved.
If you get the message on the computer disconnect the usb from computer. uninstall the software and reinstall the full feature software by selecting connect USB later.
May 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Error / Ribbon Jam/Broken
When you open and close the lid on this printer, it tries to realign the ribbon. If you are getting this error, I suggestion you Calibrate the print ribbon through the print driver printing preferences on the Calibrate tab.
Dec 12, 2008 | Fargo DTC550 Thermal Card Printer
Printing
Hi,had the same problem, phoned the helpline, the fix is a new ink ribbon, basically it has run out of ink (or dried up)
Aug 13, 2008 | Cameras
"warning Ribbon In" error message
Had the same problem with a ZM400. As stated in the User manual (can be downloaded http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html?FRRBarcodePrinters=6882), warning "Ribbon in" is usually caused by the wrong printing method (thermal direct instead of thermal transfer [which should be selected for ribbbons]). My error disappeared after choosing "thermal transfer" directly on the printer. For network printers this needs to be set by an admin in the network settings for the the printer to solve the problem permanently.
May 07, 2008 | Zebra 105SL Thermal Label Printer
FRAGO DTC550 ID MACHINE
The is usually resolved by replacing the head lift motor or sensor.
Dec 17, 2007 | Fargo DTC550 Thermal Card Printer
299 people viewed this question
jasbo
jasbo
