Question about Whirlpool Refrigerators
Whirlpool fridge getting water from upper freezer compartment
Water is occasionally dripping into the fridge from the freezer. The freezer has water frozen in the bottom of the compartment.
  • Anonymous Mar 30, 2014
    2001
  • 120 Answers
Well if you hat the freezer on top normaly air leaks inside freezer through the drain tube, that air turns into condensation and creates a ice and cloges your drain. now water can drain down to pan everytime ref goes into defrost , and water leaks to bottom section to air ducts and air returns. there are several ways to solve this problem the cheapeste way is to unplug refrigerator for 2 days then plug back up and it should go back to normal another way is to install a heat probe on your drain attached to your defrost heater , and add a grommet on drain tube that will let water drain but it will keep air out and that will solve your problem.
Posted on Oct 12, 2008
Water is dripping into fridge compartment from section separating fridge and freezer compartments, otherwise, both seem to be working fine. unit was new in 2001, model ET21PK.
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Aug 09, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Model et18pkxfno1 serial eg4024334 type c18tfa97\r\nwater drips into refrigerator compartment somewhere from freezer (inside). Occurs daily. Tried to adjust temp in both refrigerator and freezer but...
The problem is that your fridge's drain line (which is located in the freezer) is iced over. So water can't drain out of the freezer when your fridge enters it's defrost cycle. The freezer and drain line needs to be defrosted by hand. Or you can unplug the fridge and open the doors for a 2-3 hours. Eventully, if no action is taken, the ice build up in the freezer will block the cold air flow to the refrigerator compartment .
Feb 19, 2011 | Whirlpool Refrigerators
Water dripping in the refrigerator and freezes on the top shelf. It seems to be coming from the freezer compartment. There is a square piece of metal missing from the top of the main compartment. One can...
Removed everything from the freezes. Removed a false bottom from the freezer floor, 2 screws. There was an ice build up under this plastic bottom. I let the ice melt with the de-frost cycle (or frost free cycle). No more water dripping into the refrigerator compartment.
Dec 15, 2009 | Whirlpool Refrigerators
My Whirlpool Refrigerator Model ER8MHMXML02 isn't as cold. Help!
Freezer drain plugged and froze up also froze the air returns to frig
Aug 22, 2009 | Whirlpool Refrigerators
Whirlpool Fridge makes a loud dripping sound all the time G56SHE
Erin,
The water you hear sounds like it's coming from the automatic defroster in the freezer compartment. It runs down a drain tube into the pan you describe under the fridge. The pan is heated and evaporates the water.
Just some possible explanations if you are hearing "lots" of water"
* You may be in a warmer, more humid climate
* The temperature and humidity in your dwelling is elevated
* The door gasket on the freezer may be leaking
* The freezer is too full
* The freezer door is not closing properly
* The freezer door is being left open for extended periods
* There is a problem with the defrost cycle
If you are hearing water running all the time, check the ice maker water line and fill valve (if you have an ice maker) - there could be a leak or other malfunction.
Apr 15, 2009 | Whirlpool ED5VHGXM Side by Side...
Having a water dripping from top of fridge!! p
The problem could be a number of things but you have to know the top of the fridge is the bottom of the freezer (usually) and this surface must be colder than the air that's being circulated in the refg compartment. Obviously Side by Side or bottom freezer would be differant.
4 items to check :
1your air damper switch is set to give you a colder freezer and not allowing enough cooling and dehumidification in the fridge compartment (explanation below of the reason you have to have air flow unobstructed)
2 the defrost on the freezer is not taking place (Explained below)
3 the door seals are not sealing. Use a piece of paper like a $1.00 and slide between the door gasket and the frame if you can pull and push it and it not fold up the seal is open and not working.
4 some fridges have a energy saver switch which is a heater. This switch turns the heater off. It is not needed in everyone's home or locality so the switch may be set to "save energy" and thus not keeping the "dew" off the fridge (usually these heaters are only on the doors and possible on the outer sides of the fridge and not the ceiling, so I doubt this is it, but I do like to eliminate this).
One of the more common things is the defrost not taking place and this can be a verity of thing Ive seen drain lines stop up and refreeze eventually to the point where the upper part of the fridge is too cold not to drip when the humidity come up like in the spring time. A faulty defrost timer / initiator or a bad element or safety switch, bad wire can also cause non defrost.
Defrost is required because the freezer is where the coldest part of the refrigeration circuit is and it requires air from the fridge to move over the coil. When this movement stops a cold ceiling can result. It will eventually follow with warmer fridge temps as humidity and time progresses.
Hope this helps with the mystery of most common problems associated with:
having a water dripping from top of fridge!!
Please grade ma accordingly and GOOD luck!.
Mar 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator whirlpool model wrx38rwh6
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Oct 26, 2008 | Freezers
Refrigerators Logo
237 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
