Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
KitchenAid Superba KUDSO1FLSS3 Not Rinsing? No Cleaning at all!
Thanks for looking into it. Everything "sounds" normal. All cycles seem to run properly. No estrange noises, water seems to come in and then I hear it drain out. But the dishes are not clean. I removed all the "spray" pieces (lower sprayer on top of motor, tubes going up, and sprayer under the top rack) and nothing is blocking them. I wash them anyway. Problem is that after I run the machine nothing is clean! I tried different soap and quantities, just in case that I was using the wrong soap. But it is not cleaning at all.
  • fiveat11 Feb 15, 2009
    I am experiencing the same problem. My technician said to add a rinse agent. Did nothing.
    Sergeant:
  • 409 Answers
Here are a couple of things that you can try:
If there is hard water residue or film left on the dishes:
Check water hardness.
If the water is hard, use maximum detergent or try pouring 1/4 cup of Dishwasher Magic into the bottom of the dishwasher. I would also recommend using the High Heat option to ensure proper cleaning. To clean the dishwasher, use a cup of vinegar and place it in the upper rack.
Detergent carryover:
If it's below 10 grains, use less detergent and the High Heat option.
It is also possible that you may have a problem with the drain loop check valve as it's not sealing. This may cause residue or food to be left on the dishes. For this, I would recommend you have a technician do it, as it requires replacing the entire drain loop.
Let me know if any of this solves the problem.
Posted on Oct 12, 2008
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
The problem is hard water in your area. www.dishwasherfilter.com has a new product out that will solve this problem. it filters the water before it goes into your dishwasher. very affordable and works amazing. get it at www.dishwasherfilter.com.
Posted on Apr 02, 2009
Kitchenaid superba making noise
Check the fan on the back and blow air through it to clear any dust accumulation.
May 04, 2017 | KitchenAid Superba KSRG25FK Side by Side...
Kitchenaid superba electric dryer doesn't dry on timed dry
Sounds like a controller problem. May be unable to start a normal dry cycle
Sep 11, 2012 | KitchenAid Dryers
Delonghi ESAM3200 performs rinse cycle each time I turn it on
Hey you may have a circuit board issue best you check with manufacturer
May 28, 2017 | Coffee Makers & Espresso Machines
Hear water running through unit.
If you hear water but dont see any leakage what your very likely hearing is the water from the melted frost of the defrost cycle,that is a normal sound that you will hear from time to time and its a great sign that everything is working exactly as it's supposed to.
GENE
Aug 28, 2011 | KitchenAid Superba® Architect® KSRP22FSMS...
Rinsing cicle is not stoping.Mashine not responding to any baton.How to stop Rinsing cicle and go to normal mode? Thanks Radan
If its is only the rinsing cycle at start up you can go into the menu and turn the rinsing cycle off.
If its the rinsing cycle for the descale, it has to run out of water to finish. Then reprime the machine and it will start to heat again.
Oct 28, 2010 | Gaggia Titanium Espresso Machine
My kitchenaid superba double oven in not woring at all after the self clean cycle finished. top oven door will not open, no lights on, nothing happens when I push buttons
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Sep 22, 2010 | KitchenAid KEBC107 Electric Single Oven
Water continuously running to fridge, overflowing?
Hi, if the only way you could stop the water was to turn it off at the water source, you need to change the water inlet valve. Make sure you check the water fill line for any leaks before you change the valve.
If I canassist you in getting the vavle, please let me know.
Thanks
Vic
Feb 18, 2009 | Whirlpool ET0WSRXML Top Freezer...
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
668 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
