Question about LG Refrigerators
Digital display on LG fridge just keeps cycling options. Showed "ER" error. Any ideas on how to get it to stop? The freezer is still cold but the refrigertor isn't cold at all
  • 750 Answers
Hello sewing6
Welcome,
You said,
digital display on LG fridge just keeps cycling options. Showed "ER" error. Any ideas on how to get it to stop? The freezer is still cold but the refrigerator isn't cold at all
Try turning the fridge and the freezer off at the controls.
Then turning off the breaker for the fridge for 5 minutes .
then turn the breaker back on and restart the fridge and freezer!
This should reset the system and solve your problem.
let me know how it goes.
Thank You,
Huuum
Please remember to leave a rating! Hopefully a "solved "one.
Posted on Oct 13, 2008
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
How do you fix icing sensor error (ER IS) on an LG lfx25974st Fridge?
My lg fridge keeps beeping saying the freezer temperature is fluctuating
Jan 20, 2015 | LG Refrigerators
Hi, My LG Smart Digital firdge has a H "error"??? on the digital display and the fridge has stopped working but the Freezer is ok. If I turn the power on and off the display behaves as normal for a li
not sure about the H code, for all I know it means hot... but my guess is that a vent to the fridge from the freezer is blocked and no air gets to the refrigerator from the freezer... As always or most of the time, doing a defrost should clear ice blocking the vent.. that is the easiest cure and hopefully will fix your problem.
Oct 07, 2014 | LG Refrigerators
What does the message "Er
Hi
Error Code "Er FF" indicates a problem with the unit's freezer fan.
The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. This can be caused by frost accumulation on or around the freezer fan. Unplug the unit for 3-4 hours to allow this to melt off. If error code persists, call Customer Service.
Please get back to us if you have further query or else please accept the solution.
Sep 02, 2011 | U-Line BI-95
I have a german LG Intellowasher 7KG and I do not know where to put the detergent, bleach, softener, there are 3 compartments and I do not know what the symbol mean in front of them
I have a LG refrigerator freezer side by side about 6 years old I fet a reading on the digital display FRZ -Er REF -Cr when I unplug the thing and replug it the display is back to normal after a few seconds it gives me the error readings fridge and freezer keep cold but ice and water dispenser doesn,t work HELP
Aug 16, 2011 | Washing Machines
Fridge and freezer, dont stay at correct temperature, there is an error code on the digital display ( freezer display says er and fridge display says dh)...... i was advised by a repair...
The control board of your refrigerator and freezer must be check and replace if found to be defective.
You already did the remedy with a short success and trouble is back again. As you know the control board has a micro-controller on its electronic board.
To be able to function it well, the temperature control and thermostat must be good, including the system refrigerant must be on the right charge of freon. Once all of that is functioning well, the problem is really on electronic control board.
Thanks for asking.
Jul 13, 2011 | Kitchen Appliances - Others
Refrigerator displaying error "ER FF".
This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service.
Hope this helps.
Jun 10, 2011 | LG LRFC25750 Refrigerator French Door
Fridge doesnt work, freezer works
You need to change the freezer fan motor. FF means problem with the Freezer Fan.
Sep 26, 2009 | LG LRFD22850ST French Door 22.4 Cu. Ft....
LG LRFD25850ST gives ER CO code on door
There is a communications error between the control board and the display board.  Check the connector located on the top hinge cover.  Remove the hinge cover and check to make sure the connector is tightly secured.
Apr 12, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
LG LRSC26923TT freezer not freezing error display
You have a defrost problem that requires a service call from a qualified LG technician.
Apr 02, 2008 | LG LRFD25850 French Door Refrigerator
Refrigerators Logo
589 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
