Question about Koss Televison & Video
Koss dvd model 3122-2 can't stop vertical rolling
While trying to play a picture disc, i was using the remote when the vertical rolling started. It turned out that the disc was damaged but the rolling won't stop.
5 Suggested Answers
SOURCE: dvd player won't play-shows "bad disc" on screen
it did the same thing to me, it started to work again. it may be a memory issue. my koss player started to work again after it was unplugged for a while. Its something to do with the dvd disc not the player. if i find out , i will post again. good luck
Posted on Jan 15, 2007
SOURCE: Need Infrared Remote Code...
I had the same problem and it took an act of Congress to solve it. However, I can tell you that through much more hard work and time than it should have taken I discovered the infrared code for my "One-For-All" remote model URC-4021B00 is--0651. Not sure if it's the same for any other remote control models, but give it a shot.
Posted on Dec 05, 2007
SOURCE: DVD picture rolls vertically
Somehow the TV setting on the DVD player was set to PALS so we changed it to the proper setting.
Posted on Dec 17, 2008
SOURCE: one for all remote urc-3220 to koss dvd player ks-4110
i need the code to program my koss player on the one for all replacement urc 4220 remote
Posted on Dec 20, 2008
Dec 15, 2008 | Digix HT1056A DVD
Re KOSS KS4110 DVD player
I have HTV with cable.I can not get this Dvd player to work with remote or with out.I hear the CD and Dvd spin but nothing else.What needs to be done?
Nov 26, 2008 | Koss KS4110 DVD Player
Picture rolls
Same as sherpi here, player was fine, and all of sudden started rolling and never stops. Rolls with or without a disc in it...seems to play the discs fine, but never quits rolling.
Mar 08, 2008 | Spectroniq PD-1100 DVD Player
Mikey52
Needs an alignment, known issue with this player.
Feb 11, 2008 | Koss KS5192 System
Koss kd 365 wont play dvd's says no disc
ACCORDING TO AN OLD MANUAL ,TO UNLOCK THE PASSWORD CODE YOU MUST FIRST BE UNDER NO DISC CONDITION THEN PRESS NUMBER # 7 KEY, NUMBER # 6 KEY,NUMBER # 4 KEY, NUMBER # 1 KEY, AND NUMBER # 8 KEY ON THE REMOTE CONTROL IN ORDER.
GOOD LUCK, I HOPE IT WORKS.
BRIAN B
Dec 24, 2007 | Koss KD365 DVD Player
Koss KS5190 Display mode stuck
I'm not ranked and I'm not a Guru, but I can solve this picture rolling when the problem is "the video was accidently changed from NTSC to PAL and you can't see what your doing to get it back". You will need the remote control unit. First, remove the disc from the tray. Now, turn the unit off with the power button. The tray will close by itself. After the display on the front of the unit goes out, turn the unit back on using the remote control. This will let you know the remote control unit is working. When the power comes back on and the display on the front of the DVD player says, "NO DISC", with the remote control and (very important) while pointing the remote at the player, (Remember to point the remote before pressing any buttons) press the "Down Arrow" button 3 times. This will take you to the "Display" box. Now, press the "Right Arrow" button 1 time. This will take you to the "TV Image"box. Now, press the "Down Arrow" 1 time, this will take you to the "PAL/NTSC" box. If you have done everything as I have tried to clearly lead you blindly to your destination. Press the "OK" button 1 time and the picture on the screen will stop rolling and change from black & white to color. You will have now changed your video output from PAL to NTSC. If you press "OK" again, it will start to roll again. If this did not take care of your problem, turn the player off and try it again.
The previous problem solvers were on the right track, but the track was rough and they just about derailed the train. Thanks to them, I had a track to follow. I had no other information, except what I found on "Fixya.com". MR. CD
Feb 03, 2007 | Koss KS5190 System
Dvd player won't play-shows "bad disc" on screen
Dec 25, 2006 | Koss KS4110 DVD Player
Picture keeps rolling
The picture rolling is simply because the PAL decoder can't lock up to the 60Hz vertical sync pulses, even if your DVD player is set to NTSC-PAL conversion and there is no vertical hold adjustment (either external or internal) on this model set to achieve this. There is a possible alternative only if your DVD player has RGB output (not component). The JVC for example has direct RGB drive capability via the SCART input on the back panel. If you get a suitable lead you could try getting a picture this way as it bypasses the decoding and sync sep circuits in the PAL decoder chip.
Oct 03, 2005 | Panasonic DVD-F87 Multi-disc DVD Player
Televison & Video Logo
Top Koss Televison & Video Experts
Henry  Thomas
Henry Thomas
Are you a Koss Televison and Video Expert? Answer questions, earn points and help others
