Question about JVC KD-S890 CD Player
Wiring problem While hooking up my KD-S890, I noticed that my black ground wire coming out of the wiring harness caused a spark when it touched the car frame under the dash.  It isn't continuous, though.  The charge seems to dissipate after about a minute but it will even turn the player on briefly, without having the positive wire hooked up. I'm pretty confused,and I don't want to damage my car or my player.  Any ideas would be greatly appreciated. Thanks, Kurt M
SOURCE: Can't set clock
hello Have radio on and then you have to hold down the SEL button on left for a few seconds. Then it will say "SET H" which is hour and turn volume dial left or right to move up or down. To set the minutes push either the left or right buttons on the selector on the far right. You can switch from minutes to hours here too. And once at "SET MIN" turn the volumes dial to go up or down. Hope it helps!! Took me a awhile to figure out (no manual here)
Posted on Jan 18, 2008
  • 30 Answers
SOURCE: What are the Wiring Schematic's for the JVC
Here is the link on the wiring codehttp://resources.jvc.com/Resources/00/00/94/GET0267-002A.pdf
Posted on Jun 09, 2009
pumpkinman
  • 1144 Answers
SOURCE: Unmarked wires
your jvc is pretty standard on hook ups.red wire is on a keyed power wire,black is chasis ground, blue is remote wire to amp.yellow also keyed power wire.speaker wires there will be 8,usually whit violet so on. white solid for exzamle is + white with black stripe is - you can figure out front and rear with an old speaker and buy fading front to rear on your head unit youll know front and rears.same for left and right.did you look on the unit usually the have the wiring diagram on the unit itself.mine all do
Posted on Jun 21, 2009
Installer1
  • 87 Answers
SOURCE: jvc kd-sx750 head unit has power but puts out no sound
bro to me it sounds like your radioi is bad you got everything hooked up right to get sound from it maybe the ant. hooked up but you should still get sound thats why I say the amp in the unit is bad!
here a little help: red: ignition when the key is turned on
yellow or orange: all time 12v
black: ground
blue: amp turn on, or auto ant.
Posted on Aug 20, 2009
Testimonial: "thx alot i was think that the radio was bad i got it off creiglist for 25 bucks i guess the deal was to good to be true "
  • 180 Answers
SOURCE: how do you change the time on the kd s890
Hi, i had a search round and found you a manual to download, gives you all the info to set the clocks and more....hope it helps.
mark
http://www.retrevo.com/support/Pioneer-DEH-2800MP-Car-Receivers-manual/id/23227bh433/t/2/
Posted on Mar 18, 2010
IS THERE A WIRE ON THE STEREO HARNESS THAT HAS TO BE GROUND. OR THE ACTUAL HANDBRAKE SWITCH TO BE GROUND. IS THIS DONE BY PUTTING THE POS WIRE TO EARTH
No, you don't want to ground your positive wires, EVER! Also, I would avoid using the hand brake switch for anything but what it was intended for. Most power harness ground wires are just plain black. If you can't find one, ground it to the chassis of the car somewhere. This is less than optimal, as it may induce a ground loop and cause a buzzing that matches the engine's RPM.
Aug 23, 2013 | JVC Kd-avx33 Exad In Dash Dvd Player
My jvc stereo will not power up but have found the black wire is live ?
hi peter, before you start using the rest of the harness cables find out if the harness you have is a jvc original for your model. the black wire is the ground/chassis cable only for a jvc kd-r411. you mite be using a compatible fitting harness whose " wire colour configuration" is incorrect for your model. cheers.
Mar 02, 2013 | JVC AM FM CD DET FACE CAR STEREO
How do you install a JVC KD-R300 radio into a 2003 Mitsubishi Galant? I got some kit when i bought the radio to make it where the radio would be able to hook up to the car but it says to plug this black...
if your got a wiring harness you should be able to hook your ground up with a pre existing wire from the new harness it should be black if not and your looking for a place to ground it just below your steering colum is always a good place to ground anything right on the metal itself good luck
Mar 04, 2010 | JVC KDR-300
Unmarked wires
Jun 21, 2009 | JVC KD-S580 CD Player
Difficulty wiring into GM harness
well if your trying to actively wire it up with the car battery still connected that is why you are blowing fuses. just a heads up too if you have a live connection while hooking up the cd player you could short out other electrical devices and you could be in alot more trouble thatn just blowing fuses. the black wire is what is blowing fuses its because you have it hooked up wrong to a wire that is sending voltage not recieving voltage. ground the black wire to the actual chassis instead of hooking it to the ground wire from the harness or whatever color its grounded to which shouldnt be anything but black if you have the black wire hooked up to ANYTHING that isnt black that is why you are popping fuses. so hook up the red yellow and make your own ground you shouldnt have any problems after that.
May 08, 2009 | Car Audio & Video
Color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Apr 24, 2009 | JVC Arsenal KD-AR560 CD Player
Having a hard time wiring a replacement taillight in 1999 Regal
You should just be able to find a hot wire 12v most likely the black wire, the ones with stripes are most likely tied in for trailoring lights. If there are only two wires 1 wire can go to a bolt or other bare metal to ground. You have a test light in the light itself, wire the 1 wire to a good ground and with the other end of the light wire touch to black wire with the appropriate turn signal on and when the light blinks in correct rhythem than viola, you have the correct wire. Direct current operates thru the light it doesn't have to be hooked up to alternate back to the power source like A/C. You could dissasemble the good/other turn signal and see which wire goes where, but with double element bulbs it is a 50/50 chance on which one is the turn lamp or the brke lamp. good luck.
Jan 11, 2009 | 1999 Buick Regal
Car cd player installation
Noooo, lol they should all have a seperate location, look at a wiring diagram from your factory speaker harness, or buy an adapter from scosche or something (available at wal-mart for like 7 bucks) to standardize them. And your speaker wire should not be hooked up to the ground EVER.
Black - Ground
Red - 12V
Yellow - Battery
The red and yellow may OCCASIONALLY be required to be at the same place, but i've only had to do this with a vehicle from the 60's.
Jun 03, 2008 | JVC KD-G310 CD Player
No power
why didnt you hook it up to your wiring harness and were is the red wire hooked up the yellow is the memory wire make sure you have a good ground
Feb 09, 2008 | JVC Sirius KD-G300 CD Player
Deck is powering off every 5 seconds
If radio stays on at low or no volume and cuts out when turning up you may have your battery backup voltage (yellow wire) droping below 10v under signal load. There is a circuit called backup check in radio that moniters Voltage It may seem ok when measuring without volume but under load it will fluctuate with the audio. Try hooking up Heavy guage Ground and Backup battery wires to prevent voltage loss across wires under load. Also check for any speaker that may not be producing proper sound when and if you can get radio working Disconnect wires to that speaker to see if radio will stay on. Just a couple of many possibilities.
kstahl65@att.net
Jan 12, 2008 | JVC KD-S890 CD Player
JVC KD-S890 CD Player Logo
46 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
