Question about Amana Dishwashers
Amana dishwasher, model adb2200aws, ser #, 26650464e. history: quit running, no lights, nothing. replaced the door switch, ran for three days, replaced the switches on both sides of door switch, ran three days, quit. replaced the circuit panel , ran one time, quit. not lights, nothing. when I take it apart sometimes, that is take off inside cover on door, it might run or not. seems like the current isn't getting in as no lights will come one.
    Problem Solver:
  • 11 Answers
I have the same problem with mine as well but I found out that if you take a space heater to it and warm the control panel up for about 5 minutes, everything works great. This model of dishwasher seems to be problematic in any environment under 70-75 degrees.
Posted on Nov 13, 2009
  • 298 Answers
The person or persons that crimped on your spade push on) terminal ends, either cut thru most of the wire when stripping it for the terminal connector, leaving only very few wires, and /c they cannot carry the current, they simply vaporize leaving a terminal securely attached to plastic insulation - but no wire to carry the current.or he/she/it failed to properly prepare the wire end to expose enough wire, and crimped onto the insulation, leaving the wire hanging.
Pull the plug
Grab each of the power-related wire ends in turn and with your fingers, try to pull the crimped-on end off. Do not pull hard, although IF it was correctly stripped and crimped at the factory, you would not be able to. I am sure you will find one that feels very limp.. thats the culprit. Nip over to Home Depot or ACE and buy a Wire Termination kit ($10-20.00) which will contain all sizes andtypes you may need + a Cut/Strip and crimp tool.
It was either a MON or FRI job. Too hungover from the weekend... or too jumpy to go home.
Posted on Jan 15, 2009
No power seen at controls. Circuit breaker ok.
We had the same problem less than a year after we got ours. After two visits from the repairman, and a better business bureau complaint, they finally told us that there was a small opening on the inside of the door that allowed steam to escape into the area where the main circuit board is housed, causing it to short out. Replacing the circuit board and running a bead of silicone along the gap solved the problem. Hope that helps some!
Sep 24, 2011 | Amana 24 in. ADB2200AW Built-In Dishwasher
The water will not drain out of the bottom of the dishwasher Model Number - GSD3400G00BB
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Mar 13, 2011 | Amana 24 in. ADB2200AW Built-In Dishwasher
Not cleaning properly and water build up on bottom of unit when done.
heatman101
Feb 07, 2011 | Amana 24 in. ADB2200AW Built-In Dishwasher
Will not drain water
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 13, 2010 | Amana 24 in. ADB2200AW Built-In Dishwasher
My Dishwasher starts as usual,,,fills with water then starts the wash cycle and quits after 5 seconds or so. it then does this 2 more times and shuts off completely. when i turn it on again it drains and...
Check the user guide manual. If resetting procedure is shown, follow it.
Otherwise the problem is with micro controller board. You have to contact the service provider as this is a computer program related fault.
If mechanical timer is used you can try cleaning them. But I doubt as the mechanical timers are no longer in use for the past few years.
Hope your incoming mains voltage is as per the recommendations!
110 V or 220 V as per your country standards.
Some times voltage fluctuations causes this problem. Should not be less than 10 % in any standard.
Sep 21, 2010 | Amana 24 in. ADB2200AW Built-In Dishwasher
No power to dishwasher
Do the following:
  1. Check the power from the wall outlet or the branch circuit itself.
  2. Check for a blown fuse or a tripped circuit breaker.
  3. Check the wiring connections of the dishwasher from the house wiring.
  4. Check the door switch. Remove the control panel cover or the interior liner of the door whenever it is applicable. Replace if defective.
  5. Check the timer or selector switch. replace if defective.
Aug 30, 2009 | GE Nautilus 24" Built-in Dishwasher
Amana dishwasher #ADB2200AWS. Top rack sticks
look for a bend in the rails the rack slides back into
Jul 21, 2009 | Amana 24 in. ADB2200AWS Built-in...
Ge dishwasher not drying
1 make sure heated dry is on.
2 run your cycle and when it says drying open the dishwasher. see if it has steam coming out.
3 give me your whole model number.
4. if heater is not turning on then you may have one of three issues.
1. Bad door switch
2. Wire off element or bad thermistat
3. No power going through the control. to the heating circuit.
Jan 07, 2009 | GE ADW1100N Built-in Dishwasher
POWER ON-PROGRAM WONT WORK
1. No power to the dishwasherMake sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Aug 10, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Dishwashers Logo
225 people viewed this question
Top Amana Dishwashers Experts
Oloyede Monsuru
Mike
Kolbrun...
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
