Question about Lexicon Lambda Usb Desktop Recording Interface Sound Card
Using audacity with lexicon alpha
I have the same issue described above. i record a track and it plays back just fine. Then, when I go to overdub a new track, the first one sounds distorted and garbled, I did not have this problem with another computer. Could it be a USB port issue?
  • 1 more comment
  • Anonymous Dec 22, 2008
    Exact problem...Its something simple we are missing...maybe having to do with output assignments?
  • Anonymous Jan 03, 2009
    Same here! I don think audacity and the lexicon are compatible. there is no way we are all hooking this unit up wrong. I have tryed every possible connection. NUTHIN!!!
  • Anonymous Mar 10, 2009
    Me too. Full duplex seems to work fine when using my internal sound card (but the recording quality kinda sucks), but does not work using the usb lexicon
SOURCE: lexicon lambda
push the monitor button to go mono instead of stereo.
Posted on Nov 29, 2007
SOURCE: Trouble getting started
There is a menu in the control panel where it say cpu more or less, change it to the lowest, and see what happens.
Posted on Jul 02, 2008
SOURCE: Lexicon Omega will not play any sound on Windows XP
Bye the way, I was having the same trouble but had not remembered to upload the Omega CD that came with the Lexicon.
Posted on Dec 27, 2008
jaranya8
  • 238 Answers
SOURCE: gravely distorted sound on recording
You have to download updated audio codec for your system. Go to this link:
http://www.free-codecs.com/XP_Codec_Pack_download.htm
Download it. When a box appears, Click Run button.
Best regards
Posted on Jan 03, 2009
SOURCE: Lexicon lambda no sound during playback
AFTER you open a new poject go to "Devices" then "Device Setup" click on "VST Audio System" then on he right side where it says "ASIO DRIVER" make the selection say "Lambda ASIO" then click OK
Posted on Aug 08, 2009
Can i use my alpha lexicon with audacity instead of cubase?
you SHOULD be able to.
Just use Direct Sound in the host tab.
Mar 16, 2017 | Lexicon Music
How to transfer vinyl to cd-simply-I have manual but very confusing-simple step by step needed-thank you-Al B
The popular recording software known as Audacity is a good choice for getting all sorts of sounds saved in a digital format. The easy-to-use features of this program will help you to create complex musical compositions, or just record incoming audio streams. One of the basic things you can do with Audacity is to record sound from vinyl records. Many people still keep vinyls on hand, though the production of this medium has diminished. Here are the basic steps that will help you to use Audacity to record vinyl.
Steps
  1. Get your phonograph or record player. Assemble your collection of records and make sure that your record player is in good functioning condition.
  2. Use a cable to connect your record player to the computer with Audacity installed on it. In order to record from vinyl, you'll need to make sure you have accurately connected your record player as an incoming audio stream into the microphone jack of your computer.
    • Use hardware adapters to secure your cable connection. Many older record players utilize a 1/4-sized input jack. The modern laptop computer, as well as many desktop models, use a smaller, 1/8-sized input jack. You can buy simple adapters at your local electronics store to fix this problem.
    • Make sure that your cables and adapters support stereo.
  3. Open the Audacity program on your computer. You will see the signature Audacity screen, with controls at the top, and an empty space to accommodate created tracks.
  4. Start playing the record on your record player.
  5. Hit the red circle that represents the "record" button in Audacity.
  6. Observe the sound coming into Audacity. You should see the track being populated with sound, represented by a fluctuating line as the cursor moves along.
  7. Hit "Stop" to stop the recording.
  8. Stop the record player.
  9. Repeat this process with the entire track. Reset the record player, start playing and hit the Audacity "Record" button again, allowing the entire track to populate with the sound of the vinyl record.
  10. Save your project in your desired format. Audacity supports a number of file formats for the finished product. You can select one of these when you have recorded the entire track. Make every song its own track, or simply record the entire side of the record on one track.
Aug 26, 2015 | Audio Players & Recorders
Lexicon alpha and gxl2200 microphone
Are you trying to use the mic input on the back or plugging it into the instrument input on the front? If you use a low impedance mic with a quarter inch instrument input cord, you would need a transformer adapter to make the mic work on high impedance. Even if you put it on line in, you would still have to convert it. Only the XLR socket on the back will work on a low impedance mic.
Mar 05, 2013 | Lexicon Alpha Personal Recording Studio
There is a delay with the sound I play it but the green light is,nt in sync the same time I play its a little bit delayed.
The green light is NOT a tempo light and will not be in sync with applied audio. If you need a tempo indicator, turn on a click track in your computer or use a metronome.
Jan 31, 2011 | Lexicon Alpha Personal Recording Studio
I'M TRYING TO USE ALPHA STUDIO WITH AUDACITY BUT CAN'T GET IT EVEN STARTED- IS IT POSSIBLE ??
yes, it is possible. the first thing u shoul do is go to edit/preferences within audacity and make sure the alpha is selected as the recording source. if that isnt the problem, then contact lexicon directly. if they arent helping you very well, ask if "jamie cohen" is still supervising- he is the best with computer issues, if he still is a tech support supervisor there.
Nov 25, 2010 | Lexicon Alpha Personal Recording Studio
Hi, i have the Lexicon Alpha Personal Recording Studio connected to my mac via USB. im running two powered speakers via phono to phone lead. When i try play music through the speakers it doesnt play...
Make sure you have NO antivirus/antispyware/antiadware or other resource hogging background programs running while processing the audio. These programs hog resources to the point that the buffering within the audio devices is overrun causing gaps.
Nov 22, 2010 | Lexicon Alpha Personal Recording Studio
I was tring to record with audacity and my mic
Make sure the mic level is correct. Many of these units require line-level inputs which is much higher voltage than a mic puts out. You MAY need an impedance matching transformer for your mic.
Mar 28, 2010 | Lexicon Alpha Personal Recording Studio
My DVD-rw drive can't install the DVD programs
Make sure the disk is for version 2.5 if you are using Vista. You can download it from the web.
Feb 15, 2010 | Lexicon Alpha Personal Recording Studio
CAN'T GET ALPHA TO WORK IN CUBASE OR AUDACITY ?
See if this info here will help you:http://www.lexiconpro.com/knowledgebase.php?product=7 Let me know if this helps.
Nov 30, 2009 | Lexicon Alphaâ„¢ Desktop Recording Studio
Vocal effects on Tascam 2488 MK 2 portable studio
Hi again,
The easiest way to record using an external Lexicon effects unit (without an external mixer) is to connect your mic onto one of the 2488's inputs and assign that input to a channel strip (track). You should have the 2488 sends (output) going to the Lexicon's inputs. Then connect the Lexicon outputs back into another set of inputs on your 2488 and assign those inputs to two empty channel strips (tracks).
Then you will have to take that channel that has your mic input assigned to it and press send and set the levels there to send the signal out the sends (to the Lexicon).
Now you have a channel strip assigned to the mic input which contains your dry signal, and you have the two inputs returning from the Lexicon which contains your wet or effected signal.
You then have some options. You can control the amount of effected signal you hear while recording by adjusting the faders of the two wet tracks and you can either record the dry signal or the wet signal (or both) onto separate tracks.
Typically when recording the singer will want to hear an effect (say reverb) on his voice, but the engineer wants to record only the dry track at recording time (because effects can always be added later, but they can't be taken out). To accomplish this you would use the setup above, but only arm the mic input track for recording. In this way the singer hears the reverb, but only the dry vocals get recorded and the engineer can add reverb to that track again later as desired (and mix it back with the dry vocal etc).
On the other hand if you want to record only the effected signal you would simply arm the two channels to which the inputs coming back from your Lexicon are assigned for recording. This will get you a recording of the effected signal only.
Hope this helps you do what you are trying to do.
Cheers.
bd.
Aug 30, 2008 | Tascam 2488 Portastudio Multitrack...
Lexicon Lambda Usb Desktop Recording Interface Sound Card Logo
1,372 people viewed this question
Top Lexicon Computers & Internet Experts
Tony
aftab Nawaz
aftab Nawaz
Alun Cox
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
