Question about Canon PC-940 Black and White Copier
Transparency is stuck inside copier
I tried to use a transparency today and it appears to have wrapped itself around the last roller bar. I am not sure if it is melted onto it or not. I cannot see anyway to get the bar out of there. Help
    Problem Solver:
  • 12 Answers
The transparency probably melted to the the fuser roller (Did you use a transparencies sheet that was rated for use in copier?) Some copiers have a set function to allow transparencies sheets to run through. If transparencies is wrapped around the roller it maybe removed, but in most cases it needs to be replaced. If your in Maryland you can contact Innovative Copy Products if not contact your local copier dealer and they can help.
Posted on Oct 13, 2008
I cannot retrieve FABRIC from inside machine. I was printing labels and now one is rolled around the roller inside.
About 1,350,000 results (0.86 seconds) Search Results
    [PDF]How To remove a stuck label from the LabelWriter? 1. the ...
    global.dymo.com/.../cRydqiFncuah2s6Pf5DxrozTFs...
    DYMO Corporation1. the labelwriter. 2. ... The cover is now completely removed. 7. lift up the innerguidance ... Make sure the rubber transport roller ... under the stuck labels with the cutter ... the front is completely in place. 31. Your LabelWriter is now ready to print.
    [PDF]Instructions & Troubleshooting - Pelikan Artline
    www.pelikanartline.co.nz/images/.../5InstructionsTroubleshooting.pdf
    Page 1 ... E Labels. F Platen Release Knob. G Ink Roller Loading Catch. H PrintHead. I String. Lift off the ... Determine whether the label roll is the ... on the roller inside the label ... Label Loading is now complete ... Index Bands all around.
    [PDF]Label Path Diagram - Primera
Jan 18, 2016 | Office Equipment & Supplies
I have a Dell 1320c printer and there is a part that I need to replace but I have n idea what it is called. When you open the front it is on the very top. It is the last roller the paper goes through
the last set of rollers are fuser rollers you have a heat roller and a pressure roller the pressure roller is made of rubber and the heat roller is made of aluminium.from the your question im guessing that the paper is wrapped around the heat roller. if this roller has scratches in the serface it does need replacingalso if the pressure roller is damaged it also will cause a papetr jam.
also you should check that all of the picker fingers are all in place and clean.
Feb 12, 2015 | Dell 1320c Laser Printer
How to fix error code c3102 konika minolta bhizub c754
Sir/Mam, Something is preventing one of the fuser (Hot Part) roller from turning had this happen at a school teacher melted a transparency in the fuser by using a ink jet printer type transparency on this model copier cost the school 2000 dollars. Anyway hope you did not melt a transparency any way check the fuser the hot part for paper that may have wrapped it self around the orange rollers in the Fuser (The hot part of the copier if so you need a new fuser or have a tech come out and see if he can remove it. IF you use any type of tool you can damage the roller and your copies and prints will have marks all over them. Trying to reset the code prior to verifying the motor can turn allows the possibility of burning the motor out and taking the control board that controls it now your talking 3 to 4 thousand dollars
Feb 11, 2015 | Minolta Office Equipment & Supplies
Why does the label wrap around the bar every other label I print?
possible becouse the tear off position stop the gap on the wrong spot and wen you cut the label, left some label with glue expose, and wen you send other print, the printer make the backfeed and the label go stuck on the white rollar.
go througt the setings to TEAR OFF, and ajust to the front or back, untill hav the best gap/label rest possition and cut proply. don't forget to save (press setup button twice)
May 10, 2010 | Zebra Z4Mplus Label Printer
Try a different roll of labels. Clean with 100% alcahol
Apr 06, 2010 | Zebra Z4Mplus Label Printer
LAST LABEL ON ROLL HAS WRAPPED ITSELF AROUND ROLLER
Move the green plastis swith on the front sid printer move green plkastic swith forward
be carefull there is one on each side
If box does not open the green switch is broken
Mar 26, 2010 | Zebra LP 2844 Thermal Printer
Paper wrapped around inside of printer and no obvious way to remove it--too tight to get hands in and it appears there are no levers to loosen roller and pull paper out --next option is throw in trash and...
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 05, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Ink film wrapped round roller
Hi
Unplugged and try to access inside of the printer, be extra careful because you might damge the sensors. If its hard to get the film around. have it service instead.
Hope this helps
Nov 08, 2008 | Kodak EasyShare Thermal Photo Printer
Easyshare printer dock seris 3
TRY THIS
UNPLUG POWER CORD/USB TO COMPUTER IN BACK OF DOCK.TAKE OUT PAPER TRAY.
LIFT DOCK (LOOK INSIDE (DEEP INSIDE AND SEE IF YOU SEE THE CARTRIDGE FILM ON A STEEL ROLLER,WRAPPED AROUND IT.)A FLASHLIGHT MIGHT HELP IN THAT STEP).
IF CARTRIDGE IS WRAPPED AROUND TAKE TO SERVICE PROVIDER(I TRIED TO FIX IT LIKE THAT AND IT WAS A HASSEL)
IF NOT WRAPPED AROUND GO TO CARTRIDGE OPEN DOOR/LIFTGREEN TAB UP.SHOULD EJECT(IF NOT TRY A BUTTER KNIFE AND PRY UNDER SLIVER DOT)NOT HARD BUT WITH ALITTLE FORCE SHOULD POP OUT.
REMEMBER TO LIFT GREEN TAB WHILE PRYING.
IF STILL STUCK MAY BE STUCK IN PRINT MODE
THATS BEYOND ME. GOOD LUCK.
Mar 19, 2008 | Kodak EasyShare Thermal Photo Printer
Reporting my inactive printer
To clear this error: Power the printer off and let it stand for at least 30 minutes to allow the fuser to cool. Remove the coating roller from the top of the fuser unit to reveal the orange fuser rollers underneath. Check to see if any paper/transparency has become wrapped around the fuser rollers or jammed in or above the fuser unit itself. Since some paper jams can be very difficult to see with the fuser installed, remove the fuser and check for paper/transparency jams under the unit as well. A jam in that area can cause 993 errors. If there is no media jam and the error remains after the printer is restarted, try replacing the Oil Coating Roller (OCR). The OCR comes with the black toner cartridge. (It can also be purchased separately. Click here to do so.) If the error remains after the OCR has been replaced. If that does not help I would highly recommend taking it back to the place you bought it from
May 06, 2007 | Lexmark Optra C710 Laser Printer
Canon PC-940 Black and White Copier Logo
201 people viewed this question
old marine
old marine
