Question about Ventamatic Direct Drive Whole House Fan With Univer
Attic fan stops running after one hour
We installed Cool Attic Fan CX30BD2SPD two weeks ago and haven't really used it much. Last night after running one hour on low, it stopped. Turned it off and tried it later, it did the same thing. Is this normal? Haven't ran it on high yet. Does it regulate itself and restart or is this defective?
  • Anonymous Apr 27, 2009
    only when the fan is on medium or low speed does it shut off. in about 15-20 minutes it starts working again.
    if it is the motor, would it be cheaper just to replace the whole fan unit?
Whole house attic fan motor overloading/heating shutting down and then resets itself -- it runs for several hours and stops and then restarts on its own. John C. Flood Plumbing quoted me $300 to fix it and then upped the charge to $900 for just the motor.
Do I have a fire risk with this happening? How much should it cost to replace the motor?
Posted on Jul 04, 2011
Why is the fan only working on low speed
Posted on Sep 19, 2010
The Question that needs that needs an answer is; Is a belt driven fan motor? If yes than the fan motor Belt Tenxion on the motor is critical. The tighter the Fan Belt the motor amperage will increase and will exceed the motor rating. The motor is designed with a thermistor that protects the motor from burning up, plain and simple. While tightening the fan blade you must check the actual reading with an amprobe to stay within the name plate reading.
John
www.AMScontractor.com
Posted on Jul 21, 2009
    Scholar:
  • 121 Answers
I need to verify you have adaquate air flow, to cool the motor. If you have a window open, and the crawl hole open is there enough air flow into the the attic? It there is enough air flow and it still stops after about an hour, does this unit have a humidistate and a temperature switch on the housing or extension.
If all the switches are working correctly then I could be the motor overloading/heating shutting down and then reseting.
InMrFixIt
Posted on Oct 13, 2008
2002 4 ton Bryant air conditioner shuts off, fan still runs but not cooling is problem in the controls in the attic or in the AC unit or both?
With a non heat pump it is a simple 24 volt AC control circuit. In the attic there is a relay that is actuated via the fan control wire directly from the thermostat. On the thermostat there is an auto/man switch that controls the fan. Manual the fan runs all the time. Auto fan turns on and off with the outside compressor.
If the system is not calling for cool and the fan continues to run the fan relay is sticking. common problem. Sometimes after running for several days the relay will stop sticking if not, replace relay.
If the system is calling for cool and the compressor stops I would still expect the fan to run until thermostat tells the A/C to off. Some compressor units include a safety switch or high-pressure cut-out switch A blocked internal valve bad control board or external fan in outside unit defective no air flow in outside unit.
High pressure cut out not good,
Suggest turning temp max cool and observe. If acceptable cool and the compressor runs without interruption all is good, except for the blower in the attic. Safely check relay in attic blower circuit.
Hope this helps.
Jun 28, 2017 | Bryant Heating & Cooling
Ruud ubha-21j00nuaa
Can you see the condition of the coil itself? If it is blocked this could be a cause for the frozen coils. Also, check the condition of the blades on the indoor fan. Dirt and dust accumulation on the blades reduces airflow.
Jul 14, 2014 | Ruud Handler Air Conditioner
Wiring a master flow PT6 thermostat to attic fan
I had a roofer install Master Flow PRO 3 and he did the initial wiring incorrectly. The black wire pairs were incorrectly connected and caused the fan to run 24-hours. I switched the black wires pairings and the fan shuts off if less than 100-degrees (the setting I chose) and comes on if more than 100-degrees. You may want to be sure that the black wire from the power source is connected to the black wire for the thermostat (black wire nearest the thermostat setting switch and closest to the power source wire). The black wire from the fan motor should be connected to the black wire closest to the fan motor's wire.
Aug 01, 2012 | Cars & Trucks
Blower in attic & AC unit outside continuously run
Sorry to hear about your miss-fortune, you are right it is an wiring problem. Can you turn off the blower with the thermostat (cool-off-heat) or what happens when you switch the fan to (auto or on) When you say the outside unit is "rigged" is it mechanically being jammed or electrically? If its mechanically that should be removed (what a crappy thing to do) other wise it will run continuously as you may already know. That is what it sounds like, you should just be able to shut the entire system down by turning off the switch to the furnace. If it is electrically being held closed, he changed some of the wiring around in the attic unit, you better hope he was lazy and jammed a stick in the contactor in the outside unit or else you may need to learn more about HVAC wiring, none the less I would double check the thermostat wires going to the attic furnace there should be nomenclature on the unit or at least somewhat marked. This was probably disturbed when the new blower was installed, by the way that was your initial problem. Good luck and becarful
Aug 17, 2009 | Ruud Matching Split Air Conditioner
The outside unit is not working on my Heil Air conditioner
The attic fan is not a part of your a/c system, and you should not run it while you are running the a/c. If you are currently using the attic fan, it is possible that someone wired it so that the a/c won't turn on while the attic fan is on. Otherwise if the thermostat is set below room temp, and says it is calling for cool, then the problem is most likely coming from an issue at the outside unit itself. Make sure to check your fuses, at the fuse panel and outside breaker. Hope this helps
FYI.. the only part of the system that might use batteries is the thermostat.
Jul 28, 2009 | Heating & Cooling
I just installed a master flow attic fan. I ran
Sounds like it could be a bad capacitor (black box on side of motor).
Jul 19, 2009 | Cool Attic Dryers
Ventamatic Direct Drive Whole House Fan With Univer Logo
895 people viewed this question
Top Ventamatic Dryers Experts
Are you a Ventamatic Dryer Expert? Answer questions, earn points and help others
