Question about Dell Dimension 4600 PC Desktop
Audio No sound. This is a used computer and have no setup guide. How are speakers connected? Perhaps I'm missing something here. Thanks for any help.
  • Dell Master
  • 4,338 Answers
Speakers are connector in the back, the light green connector. If you have no sound, you need to download the drivers.
Here is the driver page from Dell for your computer. You can download and install the drivers you need:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid=
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 13, 2008
Ext in problem
if you are using the ext in then it has to be something wrong with the setup from the pc. The receiver does nothing to the ext in input except amplify it and put it out to the speakers.
Jan 14, 2014 | Denon AVR-1907 Receiver
A gift was just given to me. They are the Logitech Z623 speakers. But, they came with no documentation. When I plug them in as intended with either my HDTV or my desktop pc, only one of the satellite...
I checked Logitech's website and they don;t have any downloadable documentation for this product. Anyway, let's just try and fix it.
First, make sure your left and right speakers are connected properly to the bass speaker.
Next, the wire from the bass should be connected to your soundcard's line out port (light green) or into your TV's audio lineout.
You can also adjust the volume of your bass separately on the right speaker.
Update me if this worked or if you are still having trouble.
Thanks for using Fixya!
Jun 12, 2011 | Computers & Internet
I am facing audio problem after installing widows xp kindly guide me is it a driver problem or something else. if it is driver problem the how to get the driver. mother board intel FW8288IEB. with...
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 24, 2011 | Intel Motherboard
Computer not recognizing speakers
There should be something in your sound, video, and game controllers that says something like "Realtek High Definition Audio". Double click on that, and make sure that it is enabled. If this entry is completely missing, reboot, and enter the BIOS setup (I'm not sure how that works on your specific PC) and make sure that the onboard sound is enabled there.
Jan 05, 2009 | Compaq Presario SR1000T (568657) PC...
Computer speakers
I have experience with that model of speakers. When they give up the ghost, the volume is VERY low.Since they work well on another system, try this- check the volume properties to make sure nothing is set too low. Start>Control Panel>Sounds and Audio Devices. Check the slider bars here, check in the Advanced area as well to make sure nothing is low and check the Speaker Volume as well. If all the bars are set to their maximum, there is something else we're missing. Let me know what you come up with.
Thanks for using fixya.com. If you like my answer, please help me out and rate me accordingly.
Nov 09, 2008 | Dell A215 Computer Speakers
Speakers
Hi c-king,
Ah, cavaet emptor the dreaded used computer. I'm going to assume that it had speakers that worked in it's previous life. Check all cable connections, make sure system is not muted, speaker control knob is on. In windows, most editions, follow: start, control panel, sounds and audio devices, volume tab-speaker settings-advanced settings. Here you can configure and choose your speaker setup(it may be set at headphones) i.e. 5.1, 7.1 etc.. Also check the audio tab to make sure you have a digital audio device installed i.e. Sigma Tel Audio or what ever is installed in your computer. I hope this helps a little, if not, hit me back, we have other options i.e. new audio drivers.
Thanks for using FixYa.com
Sincerly, cyyyd7
Oct 09, 2008 | HP Audio Players & Recorders
Rear speakers do not connect
Hi
Hi
Check out Dell WL6000 Setup and Quick Reference Guide - https://support.dell.com/support/edocs/acc/P121646/multlang/srg/DAO/srg_dao.pdf
Try re-synchronize the wireless link. If there is still no audio form the rear speaker, check if speaker mode in your computer is set to 5.1 channels. Click Start Control Panel Sounds and Audio Devices. Under Speaker Setting, click Advanced and select 5.1 surround sound speakers.
NOTE: The rear speaker will not have audio output if the source audio does not have surround sound.
Mike
Mar 08, 2008 | Dell WL6000 Computer Speakers
Compaq wf 1907 monitor speakers--no sound
No sound from monitor speakers
If the built-in speakers on the monitor do not produce sound, perform each step that follows, testing for sound after each step, until you can hear sound:
  1. Close the software program you are using that is experiencing the sound problems. Test for audio using another software program.
    If the volume is adequate using another software program, the issue is with the computer, not the monitor. If the volume is still low, continue with this procedure.
  2. Check the cable connection. If the monitor-to-computer connection is a VGA cable (usually blue on both ends), an additional audio cable is needed between the monitor and the computer. Check that the audio cable is connected properly.
  3. Try to adjust the volume higher using the monitor front-panel volume button.
  4. Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and enable the speakers.
  5. Click Start c01292216.gif , Control Panel , and then click Sounds and Audio Devices .
  6. From the Volume tab, check the Device volume, and make sure it is not muted.
  7. From the Audio tab, in the Sound playback field, click the Volume button. Make sure the audio device is not muted and the volume outputs are at adequate levels.
  8. If the monitor-to-computer connection is an HDMI cable, an additional audio cable might be needed, depending on the setup and configuration of the system. To find out whether an additional audio cable is needed, go to
HP and Compaq Desktop PCs - Using HDMI Audio with a Desktop Computer
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector.
HDMI sends both audio and video through the same connection. If you want to hear audio from an HDMI connection, HDMI audio must be set through Windows . For example, if a computer is connected via HDMI to a monitor or TV and the proper HDMI audio settings are made, both audio and video will be sent to the display device.
Use the following steps to activate HDMI audio on your computer:
    NOTE: If you are setting up your computer for the first time, it may be easier to use a DVI connection or DVI-to-VGA adapter connection for the initial setup. Then, if you want to use an HDMI connection to connect a TV or monitor, activate sound for the HDMI connector using the steps that follow before connecting the HDMI cable to the TV or monitor.
    NOTE: After recovering the computer using the Recovery Manager, repeat this procedure to activate sound for the HDMI connector.
Step 1: Enabling HDMI sound in the BIOS
To hear audio through the HDMI connector to a monitor or display, enable the Onboard Audio setting in the computer BIOS settings by completing the following steps.
    NOTE: If you choose the default BIOS Setup options or upgrade the BIOS, you must repeat this procedure to enable audio for the HDMI connector.
  1. Turn off the computer.
  2. To enter the BIOS, turn on the computer and press the F10 key repeatedly until a BIOS Setup screen opens.
    A BIOS Setup screen opens.
  3. Press the right arrow key on the keyboard to select the Advanced tab.
  4. Press the down arrow key to select Onboard Audio , and then press the Enter key.
    Figure 1: Example of Onboard Audio menu
    An option window opens.
  5. Press the down arrow key to select Enabled , and then press the Enter key.
    Figure 2: Onboard Audio Enabled
  6. Press the F10 key. Select Yes to save the default settings, and then press the Enter key.
  7. The computer restarts. HDMI sound is now enabled.
Jan 03, 2008 | HP Compaq WF1907 Monitor
No sound from rear/surround speakers
What source are you using? And, do you have a surround mode selected?...accordianman
Oct 27, 2007 | Pioneer VSX-D307 Receiver
Dell Dimension 4600 PC Desktop Logo
71 people viewed this question
Alun Cox
