Question about Casio Exilim EXZ75 Digital Camera
Battery when i put the battery in the charger the red like stay blinking it just happened to me right now! somebody help me please! what's wrong with my charger!?
  • 477 Answers
It is not your charger it is a common issue with casio batteries you can get then on ebay for around 5 to 10 $
Posted on Oct 16, 2008
I have a TK-280 and when i put it on the charger the red charging light comes on the starts flashing red after about a min. I am on the fire dept. where i live and kinda need it charged up. I wanted to...
  • Couple things this could be.
  1. First thing is to make sure the radio is seated properly in the charger and that all the contacts are making contact and not dirty.
  2. The other thing this could be is that the battery is bad. Or in the least the capacity for the battery is extremely bad and not reliable.
  3. If the contacts look good and it's sitting on the charger proper than you will need to get another battery pack. Sorry.
  • Hope this helps and thank you for using FixYa.
Regards, Tonyu
Jul 14, 2011 | Kenwood KNB-17AM, TK-280, TK-290, TK-380,...
Dewalt battery charger won't charge
As you know, solid red on your charger means that the battery is fully charged and the BLINKING red light means the battery is charging. Unless the light is blinking irradically everything is working the way it is supposed to. If the light is blinking irradically, the battery may just be too hot or too cold to charge ( like when you are driving many lags and your battery dies) and in this case simply wait 15 minutes to charge. If you get a fast blinking light still, the problem probably is with the battery.
Oct 07, 2009 | Dewalt DW056 18 Volt Cordless Impact...
My 15 min. Duracell charger keeps blinking-won't work...
When the duracell lights blink during charging, AT YOUR OWN RISK, try a reverse charge. Instead charging positive to positive and negative to negative, try positive to negative and negative to positive. I did this for 2 minutes. This solved the problem. After the 2 minutes, I gave the batteries a normal charge. You will have to force the battery and charger contacts to touch.
Jul 08, 2009 | Duracell AAA NiMH Battery Charger with 4...
Is the red light on the charger suppose to stay on or blinking for the battery to charge?
It is supposed to stay on. If it is blinking then your battery has gone completely dead. You can force the charger to charge the battery by applying a voltage (AA battery w/ wires worked for me) across the charging terminals while inserting the battery. You'll have to take the charger apart for this.
May 17, 2009 | Vtech Cameras
RED LED BLINKING WHILE CHARGING THE BATTERY
It is normal. Just push both sides of the charger in. It happens all the time.even though it might stay blinking its normal
May 04, 2009 | Olympus FE-230 Digital Camera
Battery charger flashing red light
Clean contact points of both battery and charger with q-tips dipped in rubbing alcohol. This solved my problem with blinking lights and not charging of the batteries.
Nov 03, 2008 | Olympus Stylus 710 Digital Camera
Charger blinks red and does not charge
This maybe a solution. I had the same issue just now. Pulled battery, put back in, placed on dock, and still blinking red. So I removed the camera from the dock, pulled battery, put same old battery back in, placed on the dock and turned the mode switch on right away before it started blinkin red. It seems to be charging now with one bar and has not gone blinking red for 15 minutes.
I was outside with the camera in 10 degree weather taking pics of my dogs but had been inside for 20 minutes before placing it on the doc. I think something may have happened with the charging circuit and turning it on right away with it on the doc may have reset the charging. Try it. Hope it works for you.
Oct 23, 2008 | Kodak EasyShare DX6490 Digital Camera
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Exz700 wont charge
When you put in on the charger the light should stay a solid red color. If it blinks that means you are having a battery issue. If the light doesn't come on at all then you either don't have it plugged into the wall outlet or you are having a charger issue. Either way you need to call tech support and they can either replace the battery for you or have you send in your charger to have repairs look at it to see if there is something wrong with it.
Apr 26, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Camera Will NOt Charge
go for the new charger. Keep the battery, always good to have a couple of batteries[I have 3 lions and when I was using AA's I had 6 sets of 4.
Aug 19, 2007 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Casio Exilim EXZ75 Digital Camera Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
