Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Water leak lsq9244eqo whirlpool imperial 9 cycle washing machine is leaking from what appears to be the pump area, no leak from the pump or hoses, do you know how to remove cabinet
  • te0705 Nov 05, 2008
    I have a whirlpool Imperial which appears to be leaking from somewhere other than the hoses. Suggestion on how to troubleshoot? The Washer is old (10 yrs) so if replacement is the solution fine, if there is a cheaper alternative I'd love to know what that is. I do aprox 2-3 loads of laundry a week.
    Sergeant:
    Champion:
  • 324 Answers
Remove the 2 screws holding the console in, they may have trim on them.flip it up and you will see 2 metal brackets on left and right. pop thos off taking note how they are on there, disconnect connector on the top of the cabinet(door switch wires)lean cabinet foward pull towards you.it is know free of the rest of the machine. put back reverse of these directions making sure the back lines up properly with the cabinet.
Posted on Nov 05, 2008
Amana tandem 7300
What does it mean when a washer leaks from the bottom?
The pump will have an outlet or drain hose, an inlet from the tub and may have a circulating hose outlet as well. If you have water leaking from the washer during a wash or drain cycle, check the area of the drain pump. Look for signs of a loose hose clamp or a leaking hose connected to the pump first. Washer Repair Diagnostic Leaking Water Amana Whirlpool NFW7300WW
Jan 18, 2018 | Washing Machines
I have a Whirlpool Imperial Series Ultimate Care II. It will not drain after the wash cycle. This happened suddenly. I have not noticed leaks and no water backed up in the hoses.
it will be something blocking the water exit system usually a sock gain access to the drum assembly normally at the rear of the unit you should see the exit hose if you sqeeze it and there is water in it the block is there about . Get something to collect the water and remove the assembly between the drum and the pump do it from the highest piont to allow the water to be release slowly as possible. Usually a sock !!!
Aug 23, 2010 | Washing Machines
During the wash cycle of the 24" combo washer dryer, it leaked
A hose inside the washer is your most likely culprit. On older whirlpool washers they used a plastic hose to run from the pump to the back case of the machine that was pretty susceptible to cracking.
Jun 28, 2010 | Whirlpool LTE6234D Top Load Stacked...
Leaking washer drain pump
Yes, the drain pump is a common leak area.
2 clips, 2 hoses and it pulls off.
If it has leaked for a long time you will have to get aggressive to get it off.
Feb 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LSQ9244EQO washer is leaking
IN FRONT? IF SO, PULL IT OUT AWAY FROM WALL 2 FEET AND LEAN BACK AGAINST WALL. LOOK UNDER MACHINE IN FRONT, PUMP HAS 2 HOSES ATTACHED. IF LEAKING THROUGH PUMP, REPLACE THE PUMP.
Jan 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer is leaking from underneath....
lean washer back against wall ck pump under front in center for leaks or dark gray area in pump face remove hoses remove clamp top and bottom of pump slide forward off shaft
Jul 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
99 people viewed this question
Dan Webster
Dan Webster
Sal De
